Unofficial repo for older LTS kernels
Older LTS kernels
Following on from the above thread, I’m thinking about building I have built LTS kernels from the AUR to make them available in an unofficial user repo.
My current builds are now available here: https://repo.m2x.dev/current/kernel-lts/x86_64/
These are built directly from the AUR packaging files. YMMV etc.
This repo has the same stepped cadence available as the other repos if you are already using one of those (make sure you don’t mix cadences).
How to use
Add this to your /etc/pacman.conf:
[kernel-lts]
Server = https://repo.m2x.dev/current/$repo/$arch
Import my key:
sudo pacman-key --keyserver hkps://keyserver.ubuntu.com --recv-key 76C6E477042BFE985CC220BD9C08A255442FAFF0
sudo pacman-key --lsign 76C6E477042BFE985CC220BD9C08A255442FAFF0
then install whichever kernel takes your fancy:
mkinitcpio
With version 30 of mkinitcpio and linux-lts=5.10 hitting the Arch repos, the default initramfs compression was switched to zstd. Older kernels may not support this so make sure to edit your /etc/mkinitcpio.conf to set a compression method the kernel does support (e.g. gzip). I backported zstd support to the 5.4 package. Older kernels, not so much.
Popularity contest
Would you like older LTS kernels prebuilt and available in a repo?
  • Yes, and I would use it
  • Yes, it might be useful for someone else
  • No
0 voters
I need 4.19 on my laptop, so I might just use this. Thanks!
best to keep it simple to set only oldest :slight_smile: , and call Linux-legacy :slight_smile:
I don’t think kernel 3.16 is maintained any more… :crazy_face:
most lts is 2 years unles an distro prelonge the life…
It depends, quite a few are six years:
Version Maintainer Released Projected EOL
5.4 Greg Kroah-Hartman & Sasha Levin 2019-11-24 Dec, 2025
4.19 Greg Kroah-Hartman & Sasha Levin 2018-10-22 Dec, 2024
4.14 Greg Kroah-Hartman & Sasha Levin 2017-11-12 Jan, 2024
4.9 Greg Kroah-Hartman & Sasha Levin 2016-12-11 Jan, 2023
4.4 Greg Kroah-Hartman & Sasha Levin 2016-01-10 Feb, 2022
yeah that 2 years release is not so long ago before was longer but im a noob on such info :laughing:
Officially added to the Arch wiki page:
https://wiki.archlinux.org/index.php/Unofficial_user_repositories#kernel-lts
:partying_face:
linux-lts54 is now also available in the AUR:
https://aur.archlinux.org/packages/linux-lts54/
Watch out for upcoming changes to mkinitcpio from version 30:
If your LTS kernel does not support a zstd initramfs then make sure to edit your /etc/mkinitcpio.conf and explicitly set a supported compression method (e.g. gzip).
What’s that linux-nitrous btw?
Description : Modified Linux kernel optimized for Haswell (and newer) compiled using clang (tagged git version), with Clear Linux patches
Sorry, yay -Si linux-nitrous answered it :laughing:
OT
Thanks. I have to use 5.4 with my Intel HD graphics 530. All newer kernels crash when watching videos and only hard reset helps.
Just to highlight in this thread too, linux-lts510 is now also available in the AUR and this repo:
https://aur.archlinux.org/packages/linux-lts510/
hey @ValNar nice to have you here but remind not to post in very old threads… and instead mention it in new one if you want to ask something.
–closing–
