Thanks EndeavorOS Team for taking us even higher!
It should be there soon if not already.
Mirrors unfortunately are not equal, some update themselves earlier than others.
Tradução portuguesa / Portuguese translation:
https://forum.endeavouros.com/t/a-iso-next-endeavouros-chegou/16909
No, I made a mistake by not updating the links on the download page for the Moson mirror, but it is fixed now.
@joekamprad @manuel
Thatās some top notch work on scripts and Calamares
Installation speed of net-install is rocking!
just downloaded the iso! I am work, really hard to focus
, looking forward to the install+beer (edit: or tea or soda pop) party tonight!
If youāre install is from before 6/1 then update your pacnew files. If itās after please see
Random idea: use less +F to display the log output, then thereās no scrollbar but extended scrollback and text searching is included āfor freeā.
(Main issue would be the hidden scroll functionality, which needs CTRL+C to stop following output then F to start following again.)
=> add
ParallelDownloads = 10
under Misc Options in /etc/pacman.conf
Raising awareness on social media and friends!
Quick test in a VM - Online default Full install with LTS kernel, Xfce, Printing/HP support took only 8 minutes!!
Romanian translation is on
https://forum.endeavouros.com/t/nostrul-iso-next-a-sosit/16914
Toimii hienosti
One small complaint, when installing KDE Plasma with online installer, after you log in first thing you see is Welcome with butt-ugly Gnomeās Adwaita theme instead of Breezeā¦
So first thing i did is tried:
sudo pacman -S breeze-gtk
and logout just in case, but thereās still no GTK themes available in Settings, what am i missing?
P.S. @joekamprad btw, i believe breeze-gtk should be included in minimal net-install
P.P.S. and kde-gtk-config thx to @pebcak
By EF - Linux
Dammit, i always forget about kde-gtk-config
I did a quick install of Cinnamon online edition in a virtual machine (VirtualBox) but since the reboot, I only get a white screen and a menu bar nothing else is works.
I can see applications are launching but they seem to be not creating the GUI.
Congrats to the entire EndeavourOS team for their hard work and dedication for this lovely release! Iām already very much happy with my current Gnome 40.4 setup on ext4, but Iāve just burned the new iso to USB just in case I may need it in the future for some troubleshooting
Thanks very much for all the work yāall do, and I hope this new release propels EndeavourOS further forward into (outer) space!
