Laptop not resuming from hibernation
I have a recent install of eOS on my laptop(Lenovo Ideapad 3, AMD Ryzen 5 5500U, 12GB RAM) and every time I try to hibernate it shows the login screen, then the screen goes black for a few seconds, then it turns on again, and then the computer turns off after a couple seconds. After turning it on again it just boots normally as if it didn’t hibernate at all. Suspending works fine.
I tried linux, linux-lts and linux-zen but all three show the same behaviour. The swap partition seems to be properly configured, I did a very standard install of eOS, with plasma, sytemd-boot and btrfs partitions. There’s no dual boot, only eOS is installed.
Welcome to the world of EndeavourOS and the forum. I hope you enjoy your time here.
Have you enabled suspend in ‘System Settings’ ?
In the above image, suspend is NOT enabled.
Pudge
EDIT:
If you are new to KDE Plasma, I suggest you open ‘System Settings’ and browse through every catagory to see what options are available. The great thing about Plasma is you can configure just about everything. The worst thing about Plasma is you can configure just about everything.
Hi, thanks for reaching out so fast.
That option only makes it so that the system suspends after some time of inactivity. I can already suspend normally as I please, but on the other hand the hibernation function does not work.
From what I gathered on the internet the problem seems to be that it’s not able to resume from the hibernation for some reason
Sorry, I guess I didn’t read your post well enough.
Pudge
swap partition maybe configured, but is hibernation configured as well?
Did you install with dracut, or mkinitcpio? There was a difficulty for hibernation with dracut IIRC.
Post file contents that show a proper hibernation configuration.
Also, post journal logs from a boot session that you tried hibernation and failed.
I haven’t done any additional steps to configure hibernation, I guessed it would work out of the box as long as the swap partition was being used.
I’m pretty sure I’m using dracut
I tried adding resume=swap_device to the systemd-boot entry as it’s told in the Arch wiki(added my swap partition UUID accordingly) and ran dracut-rebuild but nothing changed.
which logs do you need? dmesg?
dmesg.odt (80.3 KB)
For dracut + resume, we call for @dalto
:wink:
This is a bug in the Cassini ISO, it was fixed in Cassini Neo.
To fix it in your install, create a file called /etc/dracut.conf.d/resume.conf with the following contents
add_dracutmodules+=" resume "
Then run sudo dracut-rebuild.
After that reboot. Once you reboot, you should be able to hibernate after that.
Earlier today I found a thread mentioning the same, I made this file earlier today but it still doesn’t work no matter what I try
What does lsinitrd -m show?
Image: /efi/e200588f17e64ac19ec266f7cb7c703a/6.1.11-arch1-1/initrd: 17M
Early CPIO image
drwxr-xr-x   1 root     root            0 Feb 24  2022 .
-rw-r--r--   1 root     root            2 Feb 24  2022 early_cpio
drwxr-xr-x   1 root     root            0 Feb 24  2022 kernel
drwxr-xr-x   1 root     root            0 Feb 24  2022 kernel/x86
drwxr-xr-x   1 root     root            0 Feb 24  2022 kernel/x86/microcode
-rw-r--r--   1 root     root        50574 Feb 24  2022 kernel/x86/microcode/AuthenticAMD.bin
Version: dracut-056
dracut modules:
systemd
systemd-initrd
i18n
btrfs
kernel-modules
kernel-modules-extra
rootfs-block
terminfo
udev-rules
dracut-systemd
ostree
usrmount
base
fs-lib
shutdown
You don’t have resume.
What does cat /etc/dracut.conf.d/* show?
Either the conf wasn’t added properly or you didn’t run sudo dracut-rebuild as described above.
Did you rebuilt?
I have run sudo dracut-rebuilt multiple times at this point. I just rebuilt it again before posting this reply just to make sure and the problem persists
omit_dracutmodules+=" network "
compress="zstd"
# Copyright (C) 2013 Colin Walters <walters@verbum.org>
# This library is free software; you can redistribute it and/or
# modify it under the terms of the GNU Lesser General Public
# License as published by the Free Software Foundation; either
# version 2 of the License, or (at your option) any later version.
# This library is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
# Lesser General Public License for more details.
# You should have received a copy of the GNU Lesser General Public
# License along with this library. If not, see <https://www.gnu.org/licenses/>.
add_dracutmodules+=" ostree systemd "
reproducible=yes
Can you share the output of sudo dracut-rebuild
dracut: Executing: /usr/bin/dracut --force --hostonly --no-hostonly-cmdline /usr/lib/modules/6.1.11-arch1-1/initrd 6.1.11-arch1-1
dracut: dracut module 'dash' will not be installed, because command 'dash' could not be found!
dracut: dracut module 'mksh' will not be installed, because command 'mksh' could not be found!
dracut: dracut module 'busybox' will not be installed, because command 'busybox' could not be found!
dracut: dracut module 'dbus-broker' will not be installed, because command 'dbus-broker' could not be found!
dracut: dracut module 'rngd' will not be installed, because command 'rngd' could not be found!
dracut: dracut module 'network-wicked' will not be installed, because command 'wicked' could not be found!
dracut: dracut module 'tpm2-tss' will not be installed, because command 'tpm2' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsi-iname' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsiadm' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsid' could not be found!
dracut: dracut module 'nvmf' will not be installed, because command 'nvme' could not be found!
dracut: dracut module 'biosdevname' will not be installed, because command 'biosdevname' could not be found!
dracut: dracut module 'memstrack' will not be installed, because command 'memstrack' could not be found!
dracut: memstrack is not available
dracut: If you need to use rd.memdebug>=4, please install memstrack and procps-ng
dracut: dracut module 'squash' will not be installed, because command 'mksquashfs' could not be found!
dracut: dracut module 'squash' will not be installed, because command 'unsquashfs' could not be found!
dracut: *** Including module: systemd ***
dracut: *** Including module: systemd-initrd ***
dracut: *** Including module: i18n ***
dracut: *** Including module: btrfs ***
dracut: *** Including module: kernel-modules ***
dracut: *** Including module: kernel-modules-extra ***
dracut: *** Including module: resume ***
dracut: *** Including module: rootfs-block ***
dracut: *** Including module: terminfo ***
dracut: *** Including module: udev-rules ***
dracut: Skipping udev rule: 40-redhat.rules
dracut: Skipping udev rule: 50-firmware.rules
dracut: Skipping udev rule: 50-udev.rules
dracut: Skipping udev rule: 91-permissions.rules
dracut: Skipping udev rule: 80-drivers-modprobe.rules
dracut: Skipping udev rule: 70-persistent-net.rules
dracut: *** Including module: dracut-systemd ***
dracut: *** Including module: ostree ***
dracut: *** Including module: usrmount ***
dracut: *** Including module: base ***
dracut: *** Including module: fs-lib ***
dracut: *** Including module: shutdown ***
dracut: *** Including modules done ***
dracut: *** Installing kernel module dependencies ***
dracut: *** Installing kernel module dependencies done ***
dracut: *** Resolving executable dependencies ***
dracut: *** Resolving executable dependencies done ***
dracut: *** Hardlinking files ***
dracut: Mode:                     real
dracut: Method:                   sha256
dracut: Files:                    799
dracut: Linked:                   2 files
dracut: Compared:                 0 xattrs
dracut: Compared:                 51 files
dracut: Saved:                    824 B
dracut: Duration:                 0.003402 seconds
dracut: *** Hardlinking files done ***
dracut: *** Generating early-microcode cpio image ***
dracut: *** Constructing AuthenticAMD.bin ***
dracut: *** Using microcode found in '/boot/amd-ucode.img' ***
dracut: *** Store current command line parameters ***
dracut: *** Stripping files ***
dracut: *** Stripping files done ***
dracut: *** Creating image file '/usr/lib/modules/6.1.11-arch1-1/initrd' ***
dracut: *** Creating initramfs image file '/usr/lib/modules/6.1.11-arch1-1/initrd' done ***
dracut: Executing: /usr/bin/dracut --force --no-hostonly /boot/initramfs-linux-fallback.img 6.1.11-arch1-1
dracut: dracut module 'cifs' depends on 'network', which can't be installed
dracut: dracut module 'fcoe' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'lldpad' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoemon' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoeadm' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'lldpad' could not be found!
dracut: dracut module 'nbd' will not be installed, because command 'nbd-client' could not be found!
dracut: dracut module 'nfs' depends on 'network', which can't be installed
dracut: *** Including module: modsign ***
dracut: *** Including module: crypt ***
dracut: *** Including module: dm ***
dracut: Skipping udev rule: 64-device-mapper.rules
dracut: Skipping udev rule: 60-persistent-storage-dm.rules
dracut: Skipping udev rule: 55-dm.rules
dracut: *** Including module: dmraid ***
dracut: *** Including module: lvm ***
dracut: Skipping udev rule: 56-lvm.rules
dracut: Skipping udev rule: 60-persistent-storage-lvm.rules
dracut: *** Including module: mdraid ***
dracut: Skipping udev rule: 64-md-raid.rules
dracut: *** Including module: multipath ***
dracut: Skipping udev rule: 40-multipath.rules
dracut: *** Including module: nvdimm ***
dracut: *** Including module: qemu ***
dracut: *** Including module: qemu-net ***
dracut: *** Including module: lunmask ***
dracut: Mode:                     real
dracut: Files:                    2050
dracut: Linked:                   9 files
dracut: Compared:                 513 files
dracut: Saved:                    1.42 MiB
dracut: Duration:                 0.020641 seconds
dracut: *** Creating image file '/boot/initramfs-linux-fallback.img' ***
dracut: *** Creating initramfs image file '/boot/initramfs-linux-fallback.img' done ***
dracut: Executing: /usr/bin/dracut --force --hostonly --no-hostonly-cmdline /usr/lib/modules/6.1.11-zen1-1-zen/initrd 6.1.11-zen1-1-zen
dracut: Mode:                     real
dracut: Files:                    799
dracut: Compared:                 37 files
dracut: Duration:                 0.003370 seconds
dracut: *** Creating image file '/usr/lib/modules/6.1.11-zen1-1-zen/initrd' ***
dracut: *** Creating initramfs image file '/usr/lib/modules/6.1.11-zen1-1-zen/initrd' done ***
dracut: Executing: /usr/bin/dracut --force --no-hostonly /boot/initramfs-linux-zen-fallback.img 6.1.11-zen1-1-zen
dracut: Mode:                     real
dracut: Files:                    2051
dracut: Compared:                 504 files
dracut: Duration:                 0.021181 seconds
dracut: *** Creating image file '/boot/initramfs-linux-zen-fallback.img' ***
dracut: *** Creating initramfs image file '/boot/initramfs-linux-zen-fallback.img' done ***
Ahh…did you install eos-dracut at some point because it looks like you are using systemd-boot but generating your boot images at the wrong location.
Yeah, eos-dracut 1.1-1 is installed
But if you are using systemd-boot, it shouldn’t be.
It conflicts with kernel-install-for-dracut. So if you installed it, it would have asked if you wanted to remove kernel-install-for-dracut.
If you answered yes to that, you removed the automation for systemd-boot that properly generates the initrds.
I installed it manually a few hours back exactly because of the hibernation problem. kernel-install-for-dracut was intalled before and the problem was already happening so I thought the eos specific package could fix it but nothing changed. But I’ll go back to that package and redo the process and see if it works
