Laptop not resuming from hibernation
Yes, you need to reinstall that package and then run sudo dracut-rebuild.
Then do lsinitrd -m and resume should be on the list.
If it is reboot.
After rebooting, try hibernating.
Still no resume :confused:
Version: dracut-056
dracut modules:
systemd
systemd-initrd
i18n
btrfs
kernel-modules
kernel-modules-extra
rootfs-block
terminfo
udev-rules
dracut-systemd
ostree
usrmount
base
fs-lib
shutdown
Can we see the output from sudo dracut-rebuild now?
Running dracut for linux-6.1.11-arch1-1
dracut: Executing: /usr/bin/dracut --force --hostonly --no-hostonly-cmdline "/efi/e200588f17e64ac19ec266f7cb7c703a/6.1.11-arch1-1/initrd 6.1.11-arch1-1"
dracut: dracut module 'dash' will not be installed, because command 'dash' could not be found!
dracut: dracut module 'mksh' will not be installed, because command 'mksh' could not be found!
dracut: dracut module 'busybox' will not be installed, because command 'busybox' could not be found!
dracut: dracut module 'dbus-broker' will not be installed, because command 'dbus-broker' could not be found!
dracut: dracut module 'rngd' will not be installed, because command 'rngd' could not be found!
dracut: dracut module 'network-wicked' will not be installed, because command 'wicked' could not be found!
dracut: dracut module 'tpm2-tss' will not be installed, because command 'tpm2' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsi-iname' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsiadm' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsid' could not be found!
dracut: dracut module 'nvmf' will not be installed, because command 'nvme' could not be found!
dracut: dracut module 'biosdevname' will not be installed, because command 'biosdevname' could not be found!
dracut: dracut module 'memstrack' will not be installed, because command 'memstrack' could not be found!
dracut: memstrack is not available
dracut: If you need to use rd.memdebug>=4, please install memstrack and procps-ng
dracut: dracut module 'squash' will not be installed, because command 'mksquashfs' could not be found!
dracut: dracut module 'squash' will not be installed, because command 'unsquashfs' could not be found!
dracut: *** Including module: systemd ***
dracut: *** Including module: systemd-initrd ***
dracut: *** Including module: i18n ***
dracut: *** Including module: btrfs ***
dracut: *** Including module: kernel-modules ***
dracut: *** Including module: kernel-modules-extra ***
dracut: *** Including module: resume ***
dracut: *** Including module: rootfs-block ***
dracut: *** Including module: terminfo ***
dracut: *** Including module: udev-rules ***
dracut: Skipping udev rule: 40-redhat.rules
dracut: Skipping udev rule: 50-firmware.rules
dracut: Skipping udev rule: 50-udev.rules
dracut: Skipping udev rule: 91-permissions.rules
dracut: Skipping udev rule: 80-drivers-modprobe.rules
dracut: Skipping udev rule: 70-persistent-net.rules
dracut: *** Including module: dracut-systemd ***
dracut: *** Including module: ostree ***
dracut: *** Including module: usrmount ***
dracut: *** Including module: base ***
dracut: *** Including module: fs-lib ***
dracut: *** Including module: shutdown ***
dracut: *** Including modules done ***
dracut: *** Installing kernel module dependencies ***
dracut: *** Installing kernel module dependencies done ***
dracut: *** Resolving executable dependencies ***
dracut: *** Resolving executable dependencies done ***
dracut: *** Hardlinking files ***
dracut: Mode:                     real
dracut: Method:                   sha256
dracut: Files:                    799
dracut: Linked:                   2 files
dracut: Compared:                 0 xattrs
dracut: Compared:                 51 files
dracut: Saved:                    824 B
dracut: Duration:                 0.003641 seconds
dracut: *** Hardlinking files done ***
dracut: *** Generating early-microcode cpio image ***
dracut: *** Constructing AuthenticAMD.bin ***
dracut: *** Using microcode found in '/boot/amd-ucode.img' ***
dracut: *** Store current command line parameters ***
dracut: *** Stripping files ***
dracut: *** Stripping files done ***
dracut: *** Creating image file '/efi/e200588f17e64ac19ec266f7cb7c703a/6.1.11-arch1-1/initrd 6.1.11-arch1-1' ***
dracut: *** Creating initramfs image file '/efi/e200588f17e64ac19ec266f7cb7c703a/6.1.11-arch1-1/initrd 6.1.11-arch1-1' done ***
dracut: Executing: /usr/bin/dracut --force --no-hostonly "/efi/e200588f17e64ac19ec266f7cb7c703a/6.1.11-arch1-1/initrd-fallback 6.1.11-arch1-1"
dracut: dracut module 'cifs' depends on 'network', which can't be installed
dracut: dracut module 'fcoe' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'lldpad' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoemon' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoeadm' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'lldpad' could not be found!
dracut: dracut module 'nbd' will not be installed, because command 'nbd-client' could not be found!
dracut: dracut module 'nfs' depends on 'network', which can't be installed
dracut: *** Including module: modsign ***
dracut: *** Including module: crypt ***
dracut: *** Including module: dm ***
dracut: Skipping udev rule: 64-device-mapper.rules
dracut: Skipping udev rule: 60-persistent-storage-dm.rules
dracut: Skipping udev rule: 55-dm.rules
dracut: *** Including module: dmraid ***
dracut: *** Including module: lvm ***
dracut: Skipping udev rule: 56-lvm.rules
dracut: Skipping udev rule: 60-persistent-storage-lvm.rules
dracut: *** Including module: mdraid ***
dracut: Skipping udev rule: 64-md-raid.rules
dracut: *** Including module: multipath ***
dracut: Skipping udev rule: 40-multipath.rules
dracut: *** Including module: nvdimm ***
dracut: *** Including module: qemu ***
dracut: *** Including module: qemu-net ***
dracut: *** Including module: lunmask ***
dracut: Mode:                     real
dracut: Files:                    2050
dracut: Linked:                   9 files
dracut: Compared:                 513 files
dracut: Saved:                    1.42 MiB
dracut: Duration:                 0.020642 seconds
dracut: *** Creating image file '/efi/e200588f17e64ac19ec266f7cb7c703a/6.1.11-arch1-1/initrd-fallback 6.1.11-arch1-1' ***
dracut: *** Creating initramfs image file '/efi/e200588f17e64ac19ec266f7cb7c703a/6.1.11-arch1-1/initrd-fallback 6.1.11-arch1-1' done ***
Running dracut for linux-zen-6.1.11-zen1-1-zen
dracut: Executing: /usr/bin/dracut --force --hostonly --no-hostonly-cmdline "/efi/e200588f17e64ac19ec266f7cb7c703a/6.1.11-zen1-1-zen/initrd 6.1.11-zen1-1-zen"
dracut: Mode:                     real
dracut: Files:                    799
dracut: Duration:                 0.003376 seconds
dracut: *** Creating image file '/efi/e200588f17e64ac19ec266f7cb7c703a/6.1.11-zen1-1-zen/initrd 6.1.11-zen1-1-zen' ***
dracut: *** Creating initramfs image file '/efi/e200588f17e64ac19ec266f7cb7c703a/6.1.11-zen1-1-zen/initrd 6.1.11-zen1-1-zen' done ***
dracut: Executing: /usr/bin/dracut --force --no-hostonly "/efi/e200588f17e64ac19ec266f7cb7c703a/6.1.11-zen1-1-zen/initrd-fallback 6.1.11-zen1-1-zen"
dracut: Mode:                     real
dracut: Files:                    2050
dracut: Duration:                 0.021256 seconds
dracut: *** Creating image file '/efi/e200588f17e64ac19ec266f7cb7c703a/6.1.11-zen1-1-zen/initrd-fallback 6.1.11-zen1-1-zen' ***
dracut: *** Creating initramfs image file '/efi/e200588f17e64ac19ec266f7cb7c703a/6.1.11-zen1-1-zen/initrd-fallback 6.1.11-zen1-1-zen' done ***
Also, here’s lsinitrd -m after rebuilding again:
Version: dracut-056
dracut modules:
systemd
systemd-initrd
i18n
btrfs
kernel-modules
rootfs-block
terminfo
udev-rules
dracut-systemd
ostree
usrmount
base
fs-lib
shutdown
Can you try rebooting?
It looks like the module was included and it wrote the file to the correct place.
Still nothing, this time I booted with the zen kernel too and ran lsinitcpio -m and they both show the same:
Version: dracut-056
dracut modules:
systemd
systemd-initrd
i18n
btrfs
kernel-modules
rootfs-block
terminfo
udev-rules
dracut-systemd
ostree
usrmount
base
fs-lib
shutdown
What does this show?
lsinitrd /efi/e200588f17e64ac19ec266f7cb7c703a/6.1.11-arch1-1/initrd | grep resume
Nothing
What does cat /proc/cmdline show?
That is the correct UUID btw
initrd=\e200588f17e64ac19ec266f7cb7c703a\6.1.11-zen1-1-zen\initrd nvme_load=YES rw rootflags=subvol=/@ root=UUID=f2392119-e0eb-436d-9ea9-077966190a4c resume=UUID=da19ffb7-0456-473f-beaa-a1534a76fd78 rw rootflags=subvol=/@ root=UUID=f2392119-e0eb-436d-9ea9-077966190a4c resume=UUID=da19ffb7-0456-473f-beaa-a1534a76fd78 rw rootflags=subvol=/@ root=UUID=f2392119-e0eb-436d-9ea9-077966190a4c resume=UUID=da19ffb7-0456-473f-beaa-a1534a76fd78 systemd.machine_id=e200588f17e64ac19ec266f7cb7c703a
That is some serious duplication going on there.
Can you edit /etc/kernel/cmdline and leave only this:
The run sudo reinstall-kernels
Can we also see the output of swapon
This worked! Now It’s hibernating and resuming just fine.
Now lsinitrd -m shows the resume module:
Version: dracut-056
dracut modules:
systemd
systemd-initrd
i18n
btrfs
kernel-modules
resume
rootfs-block
terminfo
udev-rules
dracut-systemd
ostree
usrmount
base
fs-lib
shutdown
Many thanks!!
