Linux-firmware >= 20250613.12fe085f-5 upgrade requires manual intervention
Important announcement on the Archlinux mailing list:
With 20250613.12fe085f-5, we split our firmware into several vendor-focused packages. linux-firmware is now an empty package depending on our default set of firmware.
Unfortunately, this coincided with upstream reorganizing the symlink layout of the NVIDIA firmware, resulting in a situation that Pacman cannot handle. When attempting to upgrade from 20250508.788aadc8-2 or earlier, you will see the following errors:
linux-firmware-nvidia: /usr/lib/firmware/nvidia/ad103 exists in filesystem
linux-firmware-nvidia: /usr/lib/firmware/nvidia/ad104 exists in filesystem
linux-firmware-nvidia: /usr/lib/firmware/nvidia/ad106 exists in filesystem
linux-firmware-nvidia: /usr/lib/firmware/nvidia/ad107 exists in filesystem
To progress with the system upgrade, first remove linux-firmware, then reinstall it as part of the upgrade:
# pacman -Rdd linux-firmware
# pacman -Syu linux-firmware
URL: https://archlinux.org/news/linux-firmware-2025061312fe085f-5-upgrade-requires-manual-intervention/
Update with care!
Just wanted to share that after doing this, it uninstalled the AMD drivers for 7900xtx GPU. LACT no longer detected the GPU after reboot. I checked octopi and found linux-firmware-amdgpu package, which I installed then rebooted.
GPU now being detected properly.
edit: profiles in LACT got reset. Had to redo them
Strange. While I was doing the update as described above linux-firmware-amdgpu was installed without manual intervention … :thinking:
Thanks for the info. Updated my PC with an old GTX 1060 and all went well :slight_smile:
Thank you, @TheRaOct! You’ve saved me a lot of trouble.
Hello and many thanks @TheRaOct for posting the information! With that I was able to successfully complete the update process on my parents’ laptop and on my system. :+1:
Probably just coincidental or my settings are just weird. :man_shrugging:t2:
Exactly. By following the steps above, it automatically installed all the other linux-firmware* packages.
pacman -Q | grep '^linux-firmware'
linux-firmware 20250613.12fe085f-5
linux-firmware-amdgpu 20250613.12fe085f-5
linux-firmware-atheros 20250613.12fe085f-5
linux-firmware-broadcom 20250613.12fe085f-5
linux-firmware-intel 20250613.12fe085f-5
linux-firmware-mediatek 20250613.12fe085f-5
linux-firmware-nvidia 20250613.12fe085f-5
linux-firmware-other 20250613.12fe085f-5
linux-firmware-radeon 20250613.12fe085f-5
linux-firmware-realtek 20250613.12fe085f-5
linux-firmware-whence 20250613.12fe085f-5
$ pacman -Q | grep linux-firmware
linux-firmware 20250613.12fe085f-6
linux-firmware-amdgpu 20250613.12fe085f-6
linux-firmware-atheros 20250613.12fe085f-6
linux-firmware-broadcom 20250613.12fe085f-6
linux-firmware-intel 20250613.12fe085f-6
linux-firmware-mediatek 20250613.12fe085f-6
linux-firmware-nvidia 20250613.12fe085f-6
linux-firmware-other 20250613.12fe085f-6
linux-firmware-radeon 20250613.12fe085f-6
linux-firmware-realtek 20250613.12fe085f-6
linux-firmware-whence 20250613.12fe085f-6
These are weird ways to not use pacman -Qs;
pacman -Qqs linux-firmware
This too:
$ expac -Ss "%n|%v" linux-firmware | column -t -s'|'
linux-firmware-cirrus    20250613.12fe085f-6
linux-firmware-liquidio  20250613.12fe085f-6
linux-firmware-marvell   20250613.12fe085f-6
linux-firmware-mellanox  20250613.12fe085f-6
linux-firmware-nfp       20250613.12fe085f-6
linux-firmware-qcom      20250613.12fe085f-6
linux-firmware-qlogic    20250613.12fe085f-6
Wish I knew this at 1:20am :rofl: Managed to bumble my way through it!!!
I probably have to many installed:
core/linux-firmware-broadcom 20250613.12fe085f-6 (12.9 MiB 12.9 MiB) (Installed)
core/linux-firmware-mediatek 20250613.12fe085f-6 (22.0 MiB 22.8 MiB) (Installed)
core/linux-firmware-atheros 20250613.12fe085f-6 (41.6 MiB 41.7 MiB) (Installed)
core/linux-firmware-realtek 20250613.12fe085f-6 (5.3 MiB 5.4 MiB) (Installed)
core/linux-firmware-nvidia 20250613.12fe085f-6 (98.8 MiB 103.5 MiB) (Installed)
core/linux-firmware-whence 20250613.12fe085f-6 (39.8 KiB 332.1 KiB) (Installed)
core/linux-firmware-amdgpu 20250613.12fe085f-6 (24.1 MiB 24.7 MiB) (Installed)
core/linux-firmware-radeon 20250613.12fe085f-6 (2.3 MiB 2.3 MiB) (Installed)
core/linux-firmware-other 20250613.12fe085f-6 (24.8 MiB 25.0 MiB) (Installed)
core/linux-firmware-intel 20250613.12fe085f-6 (104.5 MiB 109.0 MiB) (Installed)
core/linux-firmware 20250613.12fe085f-6 (2.4 KiB 0.0 B) (Installed)
Legion5 RTX/Ryzen, probably do not need:
  • broadcom
  • mediatek
  • atheros
Unsure about:
  • whence
  • other
going to remove some and reboot :crossed_fingers:
Removing may not be so easy since linux-firmware is (currently) a meta package. Would need option -Rdd with pacman.
Realised that, was just rebuilding dracut after Rdd’ing all the ones I shouldn’t need, rebooted all good so far.
What hardware do marvell make? , vague memories of the name, but no ideas what they do.
Thank you very much for this information.
I haven’t had an error message yet, but I used these instructions as a precautionary measure.
Herzlichen Dank fĂĽr diese Info.
Hatte bisher zwar noch keine Fehlermeldung, diese Anleitung aber gleich als VorsichtsmaĂźnahme angewandt.
Thanks. I got the weird way command from chatGPT :rofl:
Thanks for this info!
Did a mirrorlist refresh (pacman showed some errors, now gone), then sudo pacman -Rdd linux-firmware, followed by yay -Syu linux-firmware.
Went through, but unsure if I can safely reboot, because one error shown (broken pipe):
dracut[I]: *** Creating initramfs image file '/efi/664531f55f9042f8a48ed91e9a322052/6.15.3-arch1-1/initrd' done ***
Fehler: konnte nicht in Weiterleitung schreiben (DatenĂĽbergabe unterbrochen (broken pipe))
(10/14) Reloading system bus configuration...
Complete output
$ yay -Syu linux-firmware
:: Paketdatenbanken werden synchronisiert …
 endeavouros ist aktuell
 core ist aktuell
 extra ist aktuell
 multilib ist aktuell
:: Durchsuche AUR nach Updates...
:: Durchsuche Datenbanken nach Updates...
:: 31 Pakete zu upgraden/installieren.
31  core/ca-certificates-mozilla     3.112-1             -> 3.113-1
30  core/iana-etc                    20250502-1          -> 20250612-1
29  core/linux                       6.15.2.arch1-1      -> 6.15.3.arch1-1
28  core/linux-firmware                                  -> 20250613.12fe085f-6
27  core/linux-firmware-whence       20250508.788aadc8-2 -> 20250613.12fe085f-6
26  core/linux-headers               6.15.2.arch1-1      -> 6.15.3.arch1-1
25  core/nss                         3.112-1             -> 3.113-1
24  core/pam                         1.7.0-2             -> 1.7.1-1
23  core/pkgconf                     2.4.3-1             -> 2.5.0-1
22  extra/enchant                    2.8.2-2             -> 2.8.9-1
21  extra/haskell-haddock-library    1.11.0-85           -> 1.11.0-86
20  extra/haskell-pandoc             3.1.12.1-75         -> 3.1.12.1-76
19  extra/haskell-pandoc-lua-engine  0.2.1.2-158         -> 0.2.1.2-159
18  extra/haskell-pandoc-server      0.1.0.5-180         -> 0.1.0.5-181
17  extra/libblockdev                3.3.0-1             -> 3.3.1-1
16  extra/libblockdev-crypto         3.3.0-1             -> 3.3.1-1
15  extra/libblockdev-fs             3.3.0-1             -> 3.3.1-1
14  extra/libblockdev-loop           3.3.0-1             -> 3.3.1-1
13  extra/libblockdev-mdraid         3.3.0-1             -> 3.3.1-1
12  extra/libblockdev-nvme           3.3.0-1             -> 3.3.1-1
11  extra/libblockdev-part           3.3.0-1             -> 3.3.1-1
10  extra/libblockdev-swap           3.3.0-1             -> 3.3.1-1
 9  extra/liburcu                    0.15.1-1            -> 0.15.3-1
 8  extra/pandoc-cli                 3.1.12.1-91         -> 3.1.12.1-92
 7  extra/pandoc-crossref            0.3.19-12           -> 0.3.19-13
 6  extra/perl-io-socket-ssl         2.089-1             -> 2.094-1
 5  extra/perl-uri                   5.31-1              -> 5.32-1
 4  extra/perl-xml-twig              3.52-13             -> 3.54-1
 3  extra/python-argcomplete         3.5.3-1             -> 3.6.2-1
 2  extra/python-urllib3             2.4.0-1             -> 2.5.0-1
 1  extra/udisks2                    2.10.1-5            -> 2.10.1-6
==> Pakete zum AusschlieĂźen: (z.B. "1 2 3", "1-3", "^4" oder Repo-Name)
 -> Das Ausschließen von Paketen kann zu teilweisen Aktualisierungen führen und Systeme beschädigen.
Sync Dependency (26): nss-3.113-1, enchant-2.8.9-1, haskell-pandoc-3.1.12.1-76, perl-xml-twig-3.54-1, iana-etc-20250612-1, udisks2-2.10.1-6, libblockdev-swap-3.3.1-1, perl-uri-5.32-1, libblockdev-crypto-3.3.1-1, liburcu-0.15.3-1, libblockdev-loop-3.3.1-1, ca-certificates-mozilla-3.113-1, pkgconf-2.5.0-1, libblockdev-3.3.1-1, pam-1.7.1-1, perl-io-socket-ssl-2.094-1, haskell-pandoc-lua-engine-0.2.1.2-159, libblockdev-part-3.3.1-1, haskell-haddock-library-1.11.0-86, libblockdev-mdraid-3.3.1-1, libblockdev-fs-3.3.1-1, python-urllib3-2.5.0-1, libblockdev-nvme-3.3.1-1, linux-firmware-whence-20250613.12fe085f-6, python-argcomplete-3.6.2-1, haskell-pandoc-server-0.1.0.5-181
Sync Explicit (5): pandoc-crossref-0.3.19-13, pandoc-cli-3.1.12.1-92, linux-6.15.3.arch1-1, linux-firmware-20250613.12fe085f-6, linux-headers-6.15.3.arch1-1
 core ist aktuell
 extra ist aktuell
:: Vollständige Systemaktualisierung wird gestartet …
Abhängigkeiten werden aufgelöst …
Nach in Konflikt stehenden Paketen wird gesucht …
Warnung: Zu wenig Spalten fĂĽr Tabellenanzeige vorhanden
Pakete (40) ca-certificates-mozilla-3.113-1  enchant-2.8.9-1
            haskell-haddock-library-1.11.0-86  haskell-pandoc-3.1.12.1-76
            haskell-pandoc-server-0.1.0.5-181  iana-etc-20250612-1
            libblockdev-3.3.1-1  libblockdev-crypto-3.3.1-1
            libblockdev-fs-3.3.1-1  libblockdev-loop-3.3.1-1
            libblockdev-mdraid-3.3.1-1  libblockdev-nvme-3.3.1-1
            libblockdev-part-3.3.1-1  libblockdev-swap-3.3.1-1
            liburcu-0.15.3-1  linux-6.15.3.arch1-1
            linux-firmware-amdgpu-20250613.12fe085f-6
            linux-firmware-atheros-20250613.12fe085f-6
            linux-firmware-broadcom-20250613.12fe085f-6
            linux-firmware-intel-20250613.12fe085f-6
            linux-firmware-mediatek-20250613.12fe085f-6
            linux-firmware-nvidia-20250613.12fe085f-6
            linux-firmware-other-20250613.12fe085f-6
            linux-firmware-radeon-20250613.12fe085f-6
            linux-firmware-realtek-20250613.12fe085f-6
            linux-headers-6.15.3.arch1-1  nss-3.113-1  pam-1.7.1-1
            pandoc-cli-3.1.12.1-92  pandoc-crossref-0.3.19-13
            perl-io-socket-ssl-2.094-1  perl-uri-5.32-1  perl-xml-twig-3.54-1
            pkgconf-2.5.0-1  python-argcomplete-3.6.2-1  python-urllib3-2.5.0-1
            udisks2-2.10.1-6  linux-firmware-20250613.12fe085f-6
Gesamtgröße des Downloads:             543,01 MiB
Gesamtgröße der installierten Pakete:  821,19 MiB
Größendifferenz der Aktualisierung:    347,60 MiB
:: Installation fortsetzen? [J/n]
:: Pakete werden empfangen …
 linux-headers-6....    51,2 MiB  2,18 MiB/s 00:23 [----------------------] 100%
 linux-firmware-a...    41,6 MiB  1683 KiB/s 00:25 [----------------------] 100%
 linux-firmware-o...    24,8 MiB  1965 KiB/s 00:13 [----------------------] 100%
 linux-firmware-n...    98,8 MiB  2,59 MiB/s 00:38 [----------------------] 100%
 linux-firmware-i...   104,5 MiB  2,66 MiB/s 00:39 [----------------------] 100%
 linux-6.15.3.arc...   141,2 MiB  3,41 MiB/s 00:41 [----------------------] 100%
 linux-firmware-a...    24,1 MiB  1417 KiB/s 00:17 [----------------------] 100%
 linux-firmware-m...    22,0 MiB  2,64 MiB/s 00:08 [----------------------] 100%
 linux-firmware-b...    12,9 MiB  1651 KiB/s 00:08 [----------------------] 100%
 haskell-pandoc-3...     7,9 MiB  1121 KiB/s 00:07 [----------------------] 100%
 linux-firmware-r...     5,3 MiB  1024 KiB/s 00:05 [----------------------] 100%
 linux-firmware-r...     2,3 MiB   659 KiB/s 00:04 [----------------------] 100%
 nss-3.113-1-x86_64   1653,0 KiB  1349 KiB/s 00:01 [----------------------] 100%
 udisks2-2.10.1-6...   750,0 KiB  1471 KiB/s 00:01 [----------------------] 100%
 pam-1.7.1-1-x86_64    595,5 KiB  2,81 MiB/s 00:00 [----------------------] 100%
 haskell-pandoc-l...   545,4 KiB  2,06 MiB/s 00:00 [----------------------] 100%
 iana-etc-2025061...   399,3 KiB  1344 KiB/s 00:00 [----------------------] 100%
 ca-certificates-...   386,4 KiB  1740 KiB/s 00:00 [----------------------] 100%
 pandoc-crossref-...   374,9 KiB  2005 KiB/s 00:00 [----------------------] 100%
 libblockdev-3.3....   252,9 KiB  2,31 MiB/s 00:00 [----------------------] 100%
 haskell-haddock-...   234,8 KiB  1940 KiB/s 00:00 [----------------------] 100%
 python-urllib3-2...   233,8 KiB  1646 KiB/s 00:00 [----------------------] 100%
 perl-xml-twig-3....   176,4 KiB  1897 KiB/s 00:00 [----------------------] 100%
 perl-io-socket-s...   162,9 KiB   740 KiB/s 00:00 [----------------------] 100%
 liburcu-0.15.3-1...   131,7 KiB   599 KiB/s 00:00 [----------------------] 100%
 pandoc-cli-3.1.1...   106,7 KiB   523 KiB/s 00:00 [----------------------] 100%
 haskell-pandoc-s...   106,2 KiB   481 KiB/s 00:00 [----------------------] 100%
 perl-uri-5.32-1-any    93,8 KiB  1117 KiB/s 00:00 [----------------------] 100%
 enchant-2.8.9-1-...    76,2 KiB   976 KiB/s 00:00 [----------------------] 100%
 libblockdev-fs-3...    41,5 KiB   922 KiB/s 00:00 [----------------------] 100%
 pkgconf-2.5.0-1-...    74,0 KiB   691 KiB/s 00:00 [----------------------] 100%
 linux-firmware-w...    39,8 KiB  1022 KiB/s 00:00 [----------------------] 100%
 python-argcomple...    72,9 KiB   900 KiB/s 00:00 [----------------------] 100%
 libblockdev-cryp...    26,5 KiB   662 KiB/s 00:00 [----------------------] 100%
 libblockdev-nvme...    24,9 KiB   654 KiB/s 00:00 [----------------------] 100%
 libblockdev-part...    15,8 KiB   360 KiB/s 00:00 [----------------------] 100%
 libblockdev-mdra...    13,8 KiB   255 KiB/s 00:00 [----------------------] 100%
 libblockdev-swap...     8,7 KiB   223 KiB/s 00:00 [----------------------] 100%
 libblockdev-loop...     8,4 KiB   155 KiB/s 00:00 [----------------------] 100%
 linux-firmware-2...     2,4 KiB  43,1 KiB/s 00:00 [----------------------] 100%
 Gesamt (40/40)        543,0 MiB  11,3 MiB/s 00:48 [----------------------] 100%
(40/40) SchlĂĽssel im SchlĂĽsselbund werden geprĂĽft  [----------------------] 100%
(40/40) Paket-Integrität wird überprüft            [----------------------] 100%
(40/40) Paket-Dateien werden geladen               [----------------------] 100%
(40/40) Auf Dateikonflikte wird geprĂĽft            [----------------------] 100%
:: Pre-transaction-Hooks werden gestartet …
(1/4) Creating Timeshift snapshot before upgrade...
Mounted '/dev/sda2' at '/run/timeshift/5076/backup'
Creating new snapshot...(RSYNC)
Saving to device: /dev/sda2, mounted at path: /run/timeshift/5076/backup
Linking from snapshot: 2025-06-22_11-44-05
Syncing files with rsync...
Created control file: /run/timeshift/5076/backup/timeshift/snapshots/2025-06-22_11-50-11/info.json
RSYNC Snapshot saved successfully (9s)
Tagged snapshot '2025-06-22_11-50-11': ondemand
Mounted '/dev/sda2' at '/run/timeshift/5221/backup'
Removing '2025-06-19_10-52-04'...
Removed '2025-06-19_10-52-04'
(2/4) Remove DKMS modules
==> dkms remove --no-depmod cp210x/0.1 -k 6.15.2-arch1-1
==> dkms remove --no-depmod v4l2loopback/0.15.0 -k 6.15.2-arch1-1
==> depmod 6.15.2-arch1-1
(3/4) Removing kernel...
:: kernel-install removing kernel 6.15.2-arch1-1
(4/4) Unregistering Haskell modules...
:: Paketänderungen werden verarbeitet …
( 1/40) Aktualisiert wird linux-firmware-whence    [----------------------] 100%
( 2/40) Installiert wird linux-firmware-amdgpu     [----------------------] 100%
( 3/40) Installiert wird linux-firmware-atheros    [----------------------] 100%
( 4/40) Installiert wird linux-firmware-broadcom   [----------------------] 100%
( 5/40) Installiert wird linux-firmware-intel      [----------------------] 100%
( 6/40) Installiert wird linux-firmware-mediatek   [----------------------] 100%
( 7/40) Installiert wird linux-firmware-nvidia     [----------------------] 100%
( 8/40) Installiert wird linux-firmware-other      [----------------------] 100%
( 9/40) Installiert wird linux-firmware-radeon     [----------------------] 100%
(10/40) Installiert wird linux-firmware-realtek    [----------------------] 100%
(11/40) Installiert wird linux-firmware            [----------------------] 100%
Optionale Abhängigkeiten für linux-firmware
    linux-firmware-cirrus: Firmware for Cirrus Logic audio devices
    linux-firmware-liquidio: Firmware for Cavium LiquidIO server adapters
    linux-firmware-marvell: Firmware for Marvell devices
    linux-firmware-mellanox: Firmware for Mellanox Spectrum switches
    linux-firmware-nfp: Firmware for Netronome Flow Processors
    linux-firmware-qcom: Firmware for Qualcomm SoCs
    linux-firmware-qlogic: Firmware for QLogic devices
(12/40) Aktualisiert wird iana-etc                 [----------------------] 100%
(13/40) Aktualisiert wird pam                      [----------------------] 100%
(14/40) Aktualisiert wird ca-certificates-mozilla  [----------------------] 100%
(15/40) Aktualisiert wird enchant                  [----------------------] 100%
(16/40) Aktualisiert wird haskell-haddock-library  [----------------------] 100%
(17/40) Aktualisiert wird haskell-pandoc           [----------------------] 100%
(18/40) Aktualisiert wird haskell-pandoc-lua-e...  [----------------------] 100%
(19/40) Aktualisiert wird haskell-pandoc-server    [----------------------] 100%
(20/40) Aktualisiert wird libblockdev              [----------------------] 100%
(21/40) Aktualisiert wird nss                      [----------------------] 100%
(22/40) Aktualisiert wird libblockdev-crypto       [----------------------] 100%
(23/40) Aktualisiert wird libblockdev-fs           [----------------------] 100%
(24/40) Aktualisiert wird libblockdev-loop         [----------------------] 100%
(25/40) Aktualisiert wird libblockdev-mdraid       [----------------------] 100%
(26/40) Aktualisiert wird libblockdev-nvme         [----------------------] 100%
(27/40) Aktualisiert wird libblockdev-part         [----------------------] 100%
(28/40) Aktualisiert wird libblockdev-swap         [----------------------] 100%
(29/40) Aktualisiert wird liburcu                  [----------------------] 100%
(30/40) Aktualisiert wird pkgconf                  [----------------------] 100%
(31/40) Aktualisiert wird linux                    [----------------------] 100%
(32/40) Aktualisiert wird linux-headers            [----------------------] 100%
(33/40) Aktualisiert wird pandoc-cli               [----------------------] 100%
(34/40) Aktualisiert wird pandoc-crossref          [----------------------] 100%
(35/40) Aktualisiert wird perl-uri                 [----------------------] 100%
(36/40) Aktualisiert wird perl-io-socket-ssl       [----------------------] 100%
(37/40) Aktualisiert wird perl-xml-twig            [----------------------] 100%
(38/40) Aktualisiert wird python-argcomplete       [----------------------] 100%
(39/40) Aktualisiert wird python-urllib3           [----------------------] 100%
(40/40) Aktualisiert wird udisks2                  [----------------------] 100%
:: Post-transaction-Hooks werden gestartet …
( 1/14) Reloading system manager configuration...
( 2/14) Restarting marked services...
( 3/14) Creating temporary files...
( 4/14) Reloading device manager configuration...
( 5/14) Arming ConditionNeedsUpdate...
( 6/14) Rebuilding certificate stores...
( 7/14) Updating module dependencies...
( 8/14) Install DKMS modules
==> dkms install --no-depmod v4l2loopback/0.15.0 -k 6.15.3-arch1-1
==> dkms install --no-depmod cp210x/0.1 -k 6.15.3-arch1-1
Deprecated feature: CLEAN (/usr/src/cp210x-0.1/dkms.conf)
==> depmod 6.15.3-arch1-1
( 9/14) Running kernel-install...
Running kernel-install for 6.15.3-arch1-1
dracut[I]: Executing: /usr/bin/dracut --no-hostonly --force /efi/664531f55f9042f8a48ed91e9a322052/6.15.3-arch1-1/initrd-fallback 6.15.3-arch1-1
dracut[I]: *** Including module: bash ***
dracut[I]: *** Including module: systemd ***
dracut[I]: *** Including module: systemd-ask-password ***
dracut[I]: *** Including module: systemd-battery-check ***
dracut[I]: *** Including module: systemd-cryptsetup ***
dracut[I]: *** Including module: systemd-initrd ***
dracut[I]: *** Including module: systemd-journald ***
dracut[I]: *** Including module: systemd-modules-load ***
dracut[I]: *** Including module: systemd-pcrphase ***
dracut[I]: *** Including module: systemd-sysctl ***
dracut[I]: *** Including module: systemd-tmpfiles ***
dracut[I]: *** Including module: systemd-udevd ***
dracut[I]: *** Including module: modsign ***
dracut[I]: *** Including module: i18n ***
dracut[I]: *** Including module: systemd-sysusers ***
Creating group 'nobody' with GID 65534.
Creating group 'audio' with GID 996.
Creating group 'disk' with GID 995.
Creating group 'input' with GID 994.
Creating group 'kmem' with GID 993.
Creating group 'kvm' with GID 992.
Creating group 'lp' with GID 991.
Creating group 'optical' with GID 990.
Creating group 'render' with GID 989.
Creating group 'sgx' with GID 988.
Creating group 'storage' with GID 987.
Creating group 'tty' with GID 5.
Creating group 'uucp' with GID 986.
Creating group 'video' with GID 985.
Creating group 'users' with GID 984.
Creating group 'systemd-journal' with GID 983.
Creating user 'root' (Super User) with UID 0 and GID 0.
Creating user 'nobody' (Kernel Overflow User) with UID 65534 and GID 65534.
dracut[I]: *** Including module: btrfs ***
dracut[I]: *** Including module: crypt ***
dracut[I]: *** Including module: dm ***
dracut[I]: *** Including module: dmraid ***
dracut[I]: *** Including module: kernel-modules ***
dracut[I]: *** Including module: kernel-modules-extra ***
dracut[I]: *** Including module: lvm ***
dracut[I]: *** Including module: mdraid ***
dracut[I]: *** Including module: multipath ***
dracut[I]: *** Including module: nvdimm ***
dracut[I]: *** Including module: qemu ***
dracut[I]: *** Including module: qemu-net ***
dracut[I]: *** Including module: fido2 ***
dracut[I]: *** Including module: pkcs11 ***
dracut[I]: *** Including module: hwdb ***
dracut[I]: *** Including module: lunmask ***
dracut[I]: *** Including module: resume ***
dracut[I]: *** Including module: rootfs-block ***
dracut[I]: *** Including module: terminfo ***
dracut[I]: *** Including module: udev-rules ***
dracut[I]: *** Including module: virtiofs ***
dracut[I]: *** Including module: dracut-systemd ***
dracut[I]: *** Including module: usrmount ***
dracut[I]: *** Including module: base ***
dracut[I]: *** Including module: fs-lib ***
dracut[I]: *** Including module: shell-interpreter ***
dracut[I]: *** Including module: shutdown ***
dracut[I]: *** Including modules done ***
dracut[I]: *** Installing kernel module dependencies ***
dracut[I]: *** Installing kernel module dependencies done ***
dracut[I]: *** Resolving executable dependencies ***
dracut[I]: *** Resolving executable dependencies done ***
dracut[I]: *** Hardlinking files ***
dracut[I]: *** Hardlinking files done ***
dracut[I]: *** Generating early-microcode cpio image ***
dracut[I]: *** Constructing GenuineIntel.bin ***
dracut[I]: *** Store current command line parameters ***
dracut[I]: *** Stripping files ***
dracut[I]: *** Stripping files done ***
dracut[I]: *** Creating image file '/efi/664531f55f9042f8a48ed91e9a322052/6.15.3-arch1-1/initrd-fallback' ***
dracut[I]: *** Creating initramfs image file '/efi/664531f55f9042f8a48ed91e9a322052/6.15.3-arch1-1/initrd-fallback' done ***
dracut[I]: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/664531f55f9042f8a48ed91e9a322052/6.15.3-arch1-1/initrd 6.15.3-arch1-1
dracut[I]: *** Creating image file '/efi/664531f55f9042f8a48ed91e9a322052/6.15.3-arch1-1/initrd' ***
(11/14) Checking for old perl modules...
(12/14) Check if user should be informed about rebooting after certain system package upgrades.
(13/14) Registering Haskell modules...
(14/14) Checking which packages need to be rebuilt
@TheRaOct : Hello Alex,
thanx for the warning and hint.
Worked perfectly and my sytem runs fine after the update. :+1:
