Installation Issues {Online and Offline}
First Online. It freezes at 36% {the pictures/info thing still moves just the progress bar does not} and I get this error “The package manager could not make changes to the installed system. The command pre>pacman</pre returned error code 1.” {with pre in <>}
I’ve tried multiple Desktop Environments and all were the same.
here is the logs from my last attempt https://termbin.com/hcg3
Now Offline my issue is with updating, First I click update mirrors that goes perfectly fine then I click Update system {in the Welcome screen}. Logs of that after the package list is here {Y or n on the replacing is the same even tried reinstalling to test that}
Summary
:: Synchronizing package databases…
core 155.5 KiB 399 KiB/s 00:00 [--------------------------------] 100%
extra 1690.4 KiB 2.81 MiB/s 00:01 [--------------------------------] 100%
community 6.5 MiB 8.09 MiB/s 00:01 [--------------------------------] 100%
multilib 169.8 KiB 439 KiB/s 00:00 [--------------------------------] 100%
endeavouros 30.8 KiB 36.2 KiB/s 00:01 [--------------------------------] 100%
:: Starting full system upgrade…
:: Replace crda with core/wireless-regdb? [Y/n] Y
:: Replace hwids with core/hwdata? [Y/n] Y
resolving dependencies…
looking for conflicting packages…
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: jack2 and pipewire-jack are in conflict
AUR update check:
:: Searching AUR for updates…
→ Missing AUR Packages: hwids
there is nothing to do
I’ve tried a few things I read on the forums to fix the jack2 issue {like removing it} but it added a new list of issues. I’m using a Ryzen 1600X CPU and GTX 980TI GPU {I did select Nvidia/Proprietary}
If there is more info I can supply please let me know and possibly how to supply it as I am kinda new to linux
first off all welcome here :enos:
The packages used for offline installation on ISO are already a bit older and the conflict is there because of this, but easy to resolve and common to need to solve such little issues from time to time.
The log shows that it was not able to create a mirrorlist and it was not able to download any packages.
Could be a very slow internet connection or that it uses default mirrorlist and this was causing timeout on fetching packages.
I tried that on a previous install {forgot to mention sorry} but just tried again
sudo pacman -Syu pipewire-jack lib32-pipewire-jack
and
sudo pacman -Syu
did the same as previously until I ran
sudo pacman -Rdd jack2
Then I start getting the error below
Summary
(368/368) checking package integrity [--------------------------------] 100%
error: libmfx: key “80247D99EABD3A4D1E3A1836E85B8683EB48BC95” is unknown
:: Import PGP key 80247D99EABD3A4D1E3A1836E85B8683EB48BC95? [Y/n] Y
:: File /var/cache/pacman/pkg/libmfx-22.1.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] Y
:: File /var/cache/pacman/pkg/vmaf-2.3.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lightdm-slick-greeter: signature from “Alexander Epaneshnikov email@alex19ep.me” is unknown trust
:: File /var/cache/pacman/pkg/lightdm-slick-greeter-1.5.6-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: spice-vdagent: key “35BAE1BF9A6B317021E690C26E7CE0B0A36DA2AE” is unknown
:: Import PGP key 35BAE1BF9A6B317021E690C26E7CE0B0A36DA2AE? [Y/n] Y
:: File /var/cache/pacman/pkg/spice-vdagent-0.22.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
:: File /var/cache/pacman/pkg/tldr-3.1.0-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
Also before I forgot to mention this as well the Online installer did work fine a couple days ago I just borked something {researching on it seemed it was an nvidia problem} and went to reinstall
And thanks for trying to help much appreciated
sudo pacman -Sc
sudo pacman -S archlinux-keyring
sudo pacman -Syu
That worked, and solved the Offline Installer, Thank you.
for reference.. till we go to release a new ISO :wink:
yes fine. Hopefully the Next ISO release will bring a lot of improvements. and the systemd.backlight@service daemon is enabled by default in future releases. I only have a problem with the backlight. every time I shutdown or restart the brightness always returns to 100% and is very annoying at night.
ok i will wait for the upcoming release and do a clean install.
