@ricklinux Wanted to try out Wayland after the plasma 5,24 update to see if it’s getting near to being really ready for prime time.
Noticed 2 undesirables:
Firefox crashes and cause a reboot (not nice)
Instead of my SDDM image it displays the KDE logo (also not nice)
will go back to X11 and try Wayland again later.
I’ve been using Wayland and Plasma on my laptop for about half a year. Performance is great and I’ve had no crashes except when I tried gaming on it: the Primehack build of the Dolphin emulator from the AUR and the GOG release of The Witcher 3 GOTY Edition via Wine work perfectly on X11, but on Wayland I only got crashes and freezes. I don’t really game on my laptop though, just thought I’d test it, so overall I’m pretty happy with Wayland+Plasma on my laptop.
I’ve only done a very small amount of gaming, but I run Wayland and haven’t had any issues with any of it. I have noticed that rearranging the desktop (moving docks/planks/bars) is kinda likely to cause a plasmashell crash under Wayland though.
for me, wayland on Plasma is almost daily-driver ready.
I say almost, because I have my taskbar at the top, and some applications using tray icons somehow trigger an additional, invisible tray icon at the top-left corner where the application menu is, making the application menu icon non-clickable. One application triggering this is rocketchat which I have to use for work and the tray icon is an essential part of its new-message-notification-system.
Firefox, Gaming and all other things work troublefree. I could move my task bar to the bottom or use rocketchat in the browser to work around the problem but I am not ready to do that.
Edit: During the 2 weeks of christmas holidays I used wayland only, no issues.
I’ve been using Plasma Wayland for nearly a month. It’s great, the new 5.24 update is even better in general user experience but there are still fairly important bugs that needs to be ironed out. Some more esthetic (ex: hovering minimize button on secondary monitor will spawn the tool tip on main monitor with some corruption around it) but other ones are annoying (ex: either an issue with SDDM or KWin, sddm starts up again after being stopped by a reboot command. kwin_x11 starts with it, not kwin_wayland. This results in slowed shutdown and reboot process, having to wait for systemd to kill it).
I also tried it, and it crashed all the time and had all sorts of weird behavior, like Firefox windows on multiple workspaces at once (one window at once on multiple workspaces). I immediately switched back to x11.
I haven’t figured it out yet. A simple example in C that opens an empty window and prints the global coordinates of the mouse pointer and position and size of its window (in global coordinates, of course) to the stdout repeatedly in a loop is pretty much all I need. But I have doubts whether that is even possible with Wayland.
Maybe I’m missing something, but most of that does not seem to be useful to what I need.
If you have figured it out, a working C/C++ example would be most welcome. It does not have to draw the eyes, that’s the easy part, it just needs to print out 6 numbers in a loop (and should work while its window is not focused).
I’m not using Plasma, and perhaps this is unrelated to your problem, but for Firefox to work for me on Sway it needs to be run with MOZ_ENABLE_WAYLAND=1.
