I’m running an Archlinux installation with testing enabled and today, pacman 6.0.0-2 landed on testing. Pamac-aur-git was removed. I tried to build pamac-aur-git with pacman 6.0 libs, and it doesn’t work.
It’s already starting. I went to update and cancelled. I’m more than likely going to wait a few days to update and I’m assuming it gets sorted out rather quickly. But the help threads are already starting to come in.
For those that are using pamac they will have to uninstall it first. Then uninstall yay. Then you can update and install pacman 6.0 The option after that is to wait for a new build for yay or use another AUR helper such as Trizen. Or hold off on updating pacman 6.0 until all of these packages are rebuilt? Not sure whats the best solution. I tried building yay again after updating pacman and i had errors and it messed up my KDE install.
Hmm, I updated using Pamac and it seemed to run fine, other that it wanted to delete itself.
Pamac is gone but the updated yay gives an error.
core is up to date
extra is up to date
community 5,6 MiB 1067 KiB/s 00:05 [--------------------------------] 100%
multilib is up to date
endeavouros is up to date
m-m is up to date
m-aur is up to date
m-more2 is up to date
error: could not open file /var/lib/pacman/sync/5a3d4b80-befa-11eb-91d3-184fe5c81c6e?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20210601%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20210601T083701Z&X-Amz-Expires=300&X-Amz-Signature=6ed1fd3183463f1c2ac5df1a1a9ed856f818b1ac3c6fa42213c2fb6ee50d985d&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=200632352&response-content-disposition=attachment%3B%20filename%3Dm-m.db&response-content-type=application%2Foctet-stream.sig.part: File name too long
error: could not open file /var/lib/pacman/sync/e72cca00-be52-11eb-9bb2-4889f242ae9c?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20210601%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20210601T083702Z&X-Amz-Expires=300&X-Amz-Signature=5d6c7db05796e10ff986bb7397abef231d6615fbbfa75a46ed24918ba14ceb50&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=257294958&response-content-disposition=attachment%3B%20filename%3Dm-aur.db&response-content-type=application%2Foctet-stream.sig.part: File name too long
error: could not open file /var/lib/pacman/sync/c3f8c600-9b03-11eb-990b-3f7f18a77a32?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20210601%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20210601T083703Z&X-Amz-Expires=300&X-Amz-Signature=7c74505df9ba432562afc3a8a18c88f8b1af4e7f3de4b18ca03941beabe5c142&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=255379748&response-content-disposition=attachment%3B%20filename%3Dm-more2.db&response-content-type=application%2Foctet-stream.sig.part: File name too long
there is nothing to do
:: Searching databases for updates...
:: Searching AUR for updates...
Didn´t you skip a step, cause now I have even more errors…
fout:kan bestand /var/lib/pacman/sync/5a3d4b80-befa-11eb-91d3-184fe5c81c6e?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20210601%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20210601T085858Z&X-Amz-Expires=300&X-Amz-Signature=56ca4cb640932f0e5f4b9e02c5f7f816c4c9b429e6feb4668ce176e4248d4fb0&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=200632352&response-content-disposition=attachment%3B%20filename%3Dm-m.db&response-content-type=application%2Foctet-stream.sig.part: Bestandsnaam is te lang niet openen
fout:kan bestand /var/lib/pacman/sync/e72cca00-be52-11eb-9bb2-4889f242ae9c?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20210601%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20210601T085858Z&X-Amz-Expires=300&X-Amz-Signature=97ded6822571ddcf9651af2aea1e1e2dad7dd2e887f2abf01f555081ae62b25b&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=257294958&response-content-disposition=attachment%3B%20filename%3Dm-aur.db&response-content-type=application%2Foctet-stream.sig.part: Bestandsnaam is te lang niet openen
fout:kan bestand /var/lib/pacman/sync/c3f8c600-9b03-11eb-990b-3f7f18a77a32?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20210601%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20210601T085859Z&X-Amz-Expires=300&X-Amz-Signature=4724bd35dd6cbcaff33ea75f54235310e8c759633d0bcec6c6ae9402f3449d20&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=255379748&response-content-disposition=attachment%3B%20filename%3Dm-more2.db&response-content-type=application%2Foctet-stream.sig.part: Bestandsnaam is te lang niet openen
fout:m-m: ontbrekende PGP handtekening
fout:m-aur: ontbrekende PGP handtekening
fout:m-more2: ontbrekende PGP handtekening
fout:failed to synchronize all databases (ongeldige of corrupte database (PGP handtekening))
The first command should have cleared the sync folder and nothing else. The sync folder should be rebuild by the second one. Perhaps it has revealed that the problem is somewhere else?
See if you can import the PGP keys again. Or disable those repos for the time being. Pamac’s code seems to need a makeover upstreams anyways after the latest update to pacman.
Disable those extra repos first and then repeat the commands I posted before.
