Even more to the point then.
Anyway. My part has been made known to try and help others understand. No need to keep going in circles.
No. In this case only 99.009901 % of those present were invited.
But then maybe you wrote mistakenly minus ?
So, is Endeavour 102% Arch? ![]()
Define Arch!
EndeavourOS is that girlfriend Arch had in high school and was a total jerk to that later became a supermodel.
Could be. Either way, itâs not Arch. And oof. Tough crowd here. Maybe this is the Arch forums.
Disclaimer: no actual math was done at any point for this thread.
This.
âNormalâ forums let people ask the same question over and over again, and that behaviour is enabled (and even encouraged) by people trying to be the first to copy-paste an answer rather than link to existing documentation.
It seems âfriendlierâ when someone individually answers your question even though you didnât bother to look for the answer, but it ends up being significantly counter-productive in the long term. Expecting someone to provide personal help to thousands of people who all ask the same question (or minor variations on a theme) ends up with an inefficient and clogged system.
Iâd actually support a moderation approach which unlisted questions which have been asked before - that way the person who asked the question can still follow up and it should help keep the forum content lean.
I partially agree - but I would suggest a slightly different ameliorationâŚ
Rather than either pointing someone to the âofficial documentationâ, OR answering the question in depth - just link a probable answer from this forum (or wiki or website), and see if that solves the problem. Actually, I see that fairly often here - maybe we need an index?
Anyway - that approach is somewhat personalized, enables follow-up if the info is not enough, and doesnât clog things up too badly. Win win win?
That works until someone immediately posts the information from the linked post as a replyâŚ
You mean someone other than a moderator?
Oh come on, we shouldnât turn this forum to Arch
I think encouraging links to wiki / FAQ & Solutions posts as best practice - is more than enoughâŚ
Yes, there will always be someone who wants to be helpful and will post the copy-paste answer (even if itâs already copy-paste in the linked post or page).
Arch Linux is an independently developed, x86-64 general-purpose GNU/Linux distribution that strives to provide the latest stable versions of most software by following a rolling-release model. The default installation is a minimal base system, configured by the user to only add what is purposely required.
Maybe a quiet message that the preferred method is to link the âanswer postâ when possible? Should keep the incidence to a minimum - after all, it happens to
I like looking good but most of the time i donât!
Edit: Comes with age.
I tell myself that, too! But, whereâs the wisdom that is supposed to join it?
I forget!
Thatâs one school of thought. I belong to a different one. There certainly are questions that I think should be considered stupid. Here is a non-exhaustive list that mentions just a few typical examples:
awk to format a USB drive?r8168 on the linux-zen kernel?
