Reposting the same message, because I announced my problem to be solved, so the topic was closed, but it isn’t solved (so in the end it wasn’t just about the connectivity check) :
I’ve a connectivity issue : My Endeavour session get perfect connection on boxes and home routers wifi, but 99% of the time (don’t why, but it seems, in some occasion it works), I’ve a yellow sign on wifi label, written “Limited connectivity” and no access to internet when I connect to phone tethering (who works perfectly on other device, and even on my laptop with an other session booted)
I’ve dig around my firewall config, unsuccessfully (but maybe it come from it, I’m sure of nothing).
So, if any has any idea of where to look to fix it, it would be awesome, ‘cause this issue is kinda pain in the *** when I’m away from proper wifi connexion.
Thanks
P.S. : My system isn’t perfectly up to date right now, but I’ve been throught several full update with this issue still being here…
Just for reference for others, the other thread I assume @jokoko is referring to:
Can you clarify this please. Do you mean that when signed in as userA, the tethering does not work, but on the same device when signed in as userB, it does?
Also, have you tried USB tethering instead, and confirmed if that does, or doesn’t work?
Well, I only tried with only one user, the successfully try was at home, but maybe I tested it a bit quickly… Maybe your user question was about my others sessions on the same laptop : this are other OS session in dual boot (bazzite OS, based on fedora).
And the USB try was a smart idea, but it doesn’t work any better. At least it show us that it might not be about wifi config but about connexion sharing between my two devices.
Still experiencing this issue, which is quite anoying when I’m away from home. So updating the post to check if anyone might have any idea of how to understand from where it might come and find a way to fix it.
Problem still here, and I think it might be pretty basic about Wifi config or something, but I don’t know where and how to dig to find and fix it. This issue is sometimes very annoying, would there be anyone with some network skills to guide me?
Are you 100% sure this is the case? I have slow internet and get issues from this at times due to it with brave browser and the solution is to disable shields for me. When speeds are better these sites work fine.
Ping like @Nyan said to confirm
ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) octets de données.
64 octets de 8.8.8.8 : icmp_seq=1 ttl=116 temps=40.3 ms
64 octets de 8.8.8.8 : icmp_seq=2 ttl=116 temps=39.0 ms
64 octets de 8.8.8.8 : icmp_seq=3 ttl=116 temps=38.0 ms
64 octets de 8.8.8.8 : icmp_seq=4 ttl=116 temps=57.0 ms
64 octets de 8.8.8.8 : icmp_seq=5 ttl=116 temps=35.6 ms
64 octets de 8.8.8.8 : icmp_seq=6 ttl=116 temps=34.1 ms
64 octets de 8.8.8.8 : icmp_seq=7 ttl=116 temps=63.7 ms
64 octets de 8.8.8.8 : icmp_seq=8 ttl=116 temps=61.2 ms
64 octets de 8.8.8.8 : icmp_seq=9 ttl=116 temps=39.5 ms
64 octets de 8.8.8.8 : icmp_seq=10 ttl=116 temps=38.4 ms
64 octets de 8.8.8.8 : icmp_seq=11 ttl=116 temps=35.8 ms
64 octets de 8.8.8.8 : icmp_seq=12 ttl=116 temps=63.6 ms
64 octets de 8.8.8.8 : icmp_seq=13 ttl=116 temps=42.5 ms
64 octets de 8.8.8.8 : icmp_seq=14 ttl=116 temps=48.1 ms
64 octets de 8.8.8.8 : icmp_seq=15 ttl=116 temps=40.3 ms
64 octets de 8.8.8.8 : icmp_seq=16 ttl=116 temps=189 ms
64 octets de 8.8.8.8 : icmp_seq=17 ttl=116 temps=187 ms
^C
--- statistiques ping 8.8.8.8 ---
17 paquets transmis, 17 reçus, 0% packet loss, time 16024ms
rtt min/avg/max/mdev = 34.074/61.943/189.332/47.058 ms
tracepath 8.8.8.8
1?: [LOCALHOST] pmtu 1500
1: _gateway 158.501 ms
2 : aucune réponse
3: ??? 269.438 ms asymm 2
4: ??? 228.689 ms asymm 3
5: ??? 228.848 ms asymm 4
N.B. : “aucune réponse” means ‘no answer’
Also my terminal tells me that traceroute is an unknown command. Shall I install it?
Alright, here it is traceroute on my home router connection :
traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 60 byte packets
1 _gateway (192.168.1.1) 3.564 ms 3.468 ms 3.508 ms
2 * * *
3 10.5.0.121 (10.5.0.121) 27.494 ms 26.269 ms 26.654 ms
4 10.202.11.1 (10.202.11.1) 29.148 ms 27.859 ms 42.832 ms
5 82.4.118.80.rev.sfr.net (80.118.4.82) 43.309 ms 86.4.118.80.rev.sfr.net (80.118.4.86) 42.962 ms 82.4.118.80.rev.sfr.net (80.118.4.82) 43.486 ms
6 49.146.6.194.rev.sfr.net (194.6.146.49) 45.189 ms 38.405 ms 39.667 ms
7 57.44.65.81.rev.sfr.net (81.65.44.57) 38.123 ms 22.694 ms 61.11.128.77.rev.sfr.net (77.128.11.61) 22.138 ms
8 * * 74.125.252.255 (74.125.252.255) 29.337 ms
9 142.251.49.131 (142.251.49.131) 31.908 ms dns.google (8.8.8.8) 34.254 ms 29.732 ms
And on my phone tethering :
traceroute 8.8.8.8
1 _gateway (192.168.51.225) 42.960 ms 45.026 ms 46.276 ms
2 * * *
3 10.3.4.111 (10.3.4.111) 94.172 ms 101.973 ms *
4 * * *
5 * * *
6 * 194.6.146.49 (194.6.146.49) 57.418 ms 58.278 ms
7 * * *
8 * * 74.125.252.255 (74.125.252.255) 97.951 ms
9 8.8.8.8 (8.8.8.8) 96.231 ms 96.551 ms 96.515 ms
It looks normal altho a bit slow to reach your phone.
It may bee wifi shinanigams, so try to look into hotspot settings ans set there to use 2.4GHz frequency imstead on 5. Or. If it setted to 2.4 try to swith to 5Ghz.
But ping and traceroute shows that internet works.
As you mention you use it outside on the go, it may be just poor mobile internet.
Unfortunately I don’t have any option allowing me to change the frequency. But I doubt it might come from the wifi in itself as I have the very same problem in USB tethering (BTW, here is my traceroute with USB tethering) :
traceroute 8.8.8.8
1 * _gateway (192.168.16.212) 1.165 ms *
2 * * *
3 10.3.4.111 (10.3.4.111) 41.878 ms 42.136 ms 42.675 ms
4 10.205.66.1 (10.205.66.1) 42.645 ms 42.620 ms 42.765 ms
5 194.6.142.253 (194.6.142.253) 43.905 ms 194.6.142.249 (194.6.142.249) 42.578 ms 194.6.142.255 (194.6.142.255) 42.708 ms
6 194.6.146.49 (194.6.146.49) 43.885 ms 194.6.146.51 (194.6.146.51) 43.083 ms 194.6.146.49 (194.6.146.49) 34.449 ms
7 * * 77.128.11.61 (77.128.11.61) 23.285 ms
8 108.170.235.235 (108.170.235.235) 29.654 ms 34.810 ms *
9 8.8.8.8 (8.8.8.8) 28.758 ms 34.663 ms 28.598 ms
Also, It doesn’t work any better on any other phone device sharing his connection with my laptop (on endeavourOS, because, as said before, on the same laptop but with another OS boot -bazziteOS based on fedora- it runs perfectly fine -with any phone devices, mine included).
Well, maybe there’s something about that. I used to have NordVPN app (from AUR) running, but removed it when the problem appeared for the first time some times ago. It didn’t changed anything.
To be clearer about my actual statut here is my pacman -Qs vpn search outpout:
sudo pacman -Qs vpn
local/networkmanager-openconnect 1.2.10-4
NetworkManager VPN plugin for OpenConnect (with GUI)
local/networkmanager-openvpn 1.12.5-1
NetworkManager VPN plugin for OpenVPN (with GUI)
local/networkmanager-vpn-plugin-openconnect 1.2.10-4
NetworkManager VPN plugin for OpenConnect (VPN plugin only)
local/networkmanager-vpn-plugin-openvpn 1.12.5-1
NetworkManager VPN plugin for OpenVPN (VPN plugin only)
local/openconnect 1:9.12-4
Open client for Cisco AnyConnect VPN
local/openvpn 2.7.0-1
An easy-to-use, robust and highly configurable VPN (Virtual Private Network)
local/vpnc 1:0.5.3.r539.r239-1
VPN client for cisco3000 VPN Concentrators
I think those are distro pre-installed packages but I may miss something.
Also, I discovered a weird behavior investigating and testing: If my (or any) phone device sharing his network is wifi connected to my router, it works, but when it only share his own network data (disconnected from my home router), it doesn’t work.
So, what sites exactly you having problems acessing?
Well, this question led me to test more intensely, and found out that :
There are no website working within any browser (neither firefox nor chromium), also, command like “pacman -Syu” stay stuck to the repo synchro step, but commands like “pacman -Ss anyname” give me the output instantly. So indeed, internet seems to work.
