Where is Gnome 44?
i might do a Arch or Endeavouros Gnome 44 vm plus play with some extensions :innocent: i do like blur my dash ( think that the name) + dash to panel .
I don’t know this one. I use Blur my shell.
Also dash to panel.
:pray: you correct … it (blur my shell)
That is a nice one. You get some nice look when you are in overview/activity.
here what i use . just simple thing
You got a minimal set of extension, enough for getting a nice looking DE.
Yours look always very nice. I like minimalist backgrounds and no “clutter” on the screen.
However, I have to confess that I use a few more extensions than you do :blush:
This is what I see currently when I log in to my Arch-GNOME:
The panel on top is set to autohide
yes panel on auto hide ( slow i remove panel from all )
i no need much a terminal (tmux ) + few browser i good for go :wink:
Yes–I build Conkys & yes, I’ve used Wayland & it works very well.
Cool… I’ll try it myself… Very nice Gnome you have over there…
Well…I’m not sure…have you loged out & back in? You can also do ALT+F2 and then r to restart the shell.
O—I see install gmenu & then recheck. https://aur.archlinux.org/packages/gmenu
Thank You…If you look at https://www.pling.com/s/Linux/browse?cat=124&ord=latest , you’ll find a large number of Conky…I have all my work there.
I only use 3 extension, pure and simple
Another point—if you use Dash to Dock…the 9 dot item on the left side opens up the overview to get all applications…I use both depending on where I’m at on the screen…nice to have multiple choices.
sudo pacman -Syu gnome-menus and it should work.
:v:
Yes—you pointed Rick the right way…my bad.
Gnome is back, everyone installing it now I see :smiley:
Not me. :laughing:
I’m just proving a point. Install is much harder than KDE. Have to deal with extensions that don’t work. KDE install and bam on the desktop! Everything just works! :rofl:
You seem to have an agenda. - Ha!
:rofl:
All depends on your poison…To me—it takes a few minutes & I am done…
I spend far more time messing with my Conkys…
