worked nice in i3wm
but now in this new endeavouros installation, when I send to print, it doesn’t print.
CUPS job status says: *Waiting for printer to become available."
Now, the interesting thing is that, when I reboot computer, just after login screen, printer prints whatever I sent to it on last session (although I suspect it is not using the right colors).
Tried
sudo systemctl restart cups.service
to no avail
Tried unplugging and plugging USB in another USB port, but nothing happens.
Tried turning off and then back on printer, but nothing happens.
Yes I did! (I left HP printing drivers unchecked though, as mine is not HP)
And printer did work some weeks ago, when I tested print after driver installs, it did print. And I also think I printed some documents, it might not have worked at first but after switchung USB port, it did
How did you install the drivers and set it up. It should have been as easy as installing
the package from the AUR because it is hooked to usb.
yay -S brother-mfct910dw
Edit: After installing and printer is plugged into usb and turned on it should automatically find it. Otherwise go into print settings and you can add it if it doesn’t automatically and select usb as the port.
Sure you can install the printer through the CUPS web interface but you may be doing it incorrectly. Are you telling me the install of the AUR package works? Or it doesn’t build? If it does then check the cups web interface again. You may have to remove the printer and add it again but check what you are selecting. Sometimes it has more than one entry for a printer.
Edit: Also have you looked at the wiki as now there is a firewall also to contend with.
Edit2: I read over the previous post and the AUR package was loaded by @joekamprad so it should work.
The AUR package installs OK but printer won’t print in duplex mode. Haven’t tried it on this install of endeavourOS but have tried before, and reviewed the whole issue with @joekamprad in the forum link I mailed before. Finally talked closely to a brother service agent and then we concluded that for some strange reason the AUR package was not working ok, but if I install by using the rpm provided by brother, using rpm-tools, everything worked OK in my last EndeavourOS i3wm install.
You can check this exact comment at the forum post for clarification:
Well that has to be an issue with the usb port? Do you have usb autosuspend turned off? Or some other reason? Have you checked sudo dmesg and or boot logs when trying the printer using journalctl commands?
I haven´t done any specific usb port config
this autosuspend off you mean at the BIOS level? If so, I will check
I haven’t checked any journalctl/dmesg messages
would you recommend any specific commands to try? this would be just after sending the thing to print to cups?
