so i’ve never got any update pop ups anymore since the last few days, so i tried to run
sudo pacman -Syu
and to my surprise it’s an error, this is what i got
[caviezel@Nicolas ~]$ sudo pacman -Syu
[sudo] password for caviezel:
error: GPGME error: No data
:: Synchronising package databases…
core is up to date
extra is up to date
community is up to date
multilib is up to date
endeavouros 21,6 KiB 6,38 KiB/s 00:03 [---------------------------------------] 100%
error: failed to synchronize all databases (invalid or corrupted database (PGP signature))
What should i do to fix this?
pebcak
January 29, 2022, 9:12pm
2
Try the following steps and see if you can get it working:
If you still get some error messages please post them here.
ringo
January 29, 2022, 9:13pm
3
try :
sudo pacman -S archlinux-keyring endeavouros-keyring
just for feedback…
does it help, probably need different options.
I already tried this, doesn’t work. I have the same problem. Not only updates are blocked, getting new applications as well. Is there another link of similar problems?
Did you try updating your mirrors first?
The funami mirror seems to have something funky going on with it.
First, I removed it from /etc/pacman.d/endeavouros-mirrorlist and tried re-populating keys. What finally worked for me was
sudo rm -R /var/lib/pacman/sync
followed by
sudo pacman -Syy
ringo
January 29, 2022, 11:22pm
7
your the same person or have the same issue ?
Same issue, could update my system. I found my a solution for it
https://bbs.archlinux.org/viewtopic.php?pid=1983577 (here is the link for the solution.
same problem
[caviezel@Nicolas ~]$ sudo rm -R /var/lib/pacman/sync
[caviezel@Nicolas ~]$ sudo pacman -Syy
:: Synchronising package databases...
core 138,6 KiB 247 KiB/s 00:01 [---------------------------------------] 100%
extra 1556,0 KiB 657 KiB/s 00:02 [---------------------------------------] 100%
community 6,1 MiB 521 KiB/s 00:12 [---------------------------------------] 100%
multilib 149,0 KiB 102 KiB/s 00:01 [---------------------------------------] 100%
endeavouros 21,5 KiB 3,12 KiB/s 00:07 [---------------------------------------] 100%
EOS
January 30, 2022, 8:55am
13
Try this:
sudo pacman-key --init
sudo pacman-key --populate archlinux
sudo pacman -Sy archlinux-keyring && pacman -Su
still the same error
[caviezel@Nicolas ~]$ sudo pacman-key --init
[caviezel@Nicolas ~]$ sudo pacman-key --populate archlinux
==> Appending keys from archlinux.gpg...
==> Updating trust database...
gpg: next trustdb check due at 2022-05-06
[caviezel@Nicolas ~]$ sudo pacman -Sy archlinux-keyring && pacman -Su
core 138,6 KiB 72,5 KiB/s 00:02 [---------------------------------------] 100%
extra 1555,9 KiB 46,2 KiB/s 00:34 [---------------------------------------] 100%
community 6,1 MiB 86,4 KiB/s 01:12 [---------------------------------------] 100%
endeavouros 21,6 KiB 8,46 KiB/s 00:03 [---------------------------------------] 100%
Try
sudo pacman -Syy
sudo pacman -Scc
Then run your package install
@CAVIEZEL That’s really frustrating. Did you remove the funami mirror in your endeavouros-mirrorlist first?
I can see a bunch of funami in here, which one do i remove? all?
### EndeavourOS Repository Mirrorlist ###
#### Entry in file /etc/pacman.conf:
### [endeavouros]
### SigLevel = PackageRequired
### Include = /etc/pacman.d/endeavouros-mirrorlist
### Tip: Use the 'eos-rankimirrors' program to rank
### these mirrors or re-order them manually.
## Germany
#Server = https://mirror.alpix.eu/endeavouros/repo/$repo/$arch
#Server = https://de.freedif.org/EndeavourOS/repo/$repo/$arch
#Server = https://mirror.moson.org/endeavouros/repo/$repo/$arch
## Sweden
#Server = https://ftp.acc.umu.se/mirror/endeavouros/repo/$repo/$arch
#Server = https://mirror.linux.pizza/endeavouros/repo/$repo/$arch
## Canada
#Server = https://ca.gate.endeavouros.com/endeavouros/repo/$repo/$arch
## China
#Server = https://mirrors.tuna.tsinghua.edu.cn/endeavouros/repo/$repo/$arch
## Singapore
#Server = https://mirror.jingk.ai/endeavouros/repo/$repo/$arch
#Server = http://mirror.jingk.ai/endeavouros/repo/$repo/$arch
## France
#Server = https://endeavour.remi.lu/repo/$repo/$arch
## South Korea
#Server = https://mirror.funami.tech/endeavouros/repo/$repo/$arch
# Results of mirror ranking at (UTC) 06/01/22 04:44:03:
# The following fields are shown for each mirror:
# mirror: The mirror address
# update-level: Ordinal number of the latest update (larger is newer)
# fetch-time: Measures the speed of the mirror (smaller is faster)
# mirror update-level fetch-time
# https://mirror.funami.tech/endeavouros/repo/$repo/$arch 1176 0.420747
# https://mirrors.tuna.tsinghua.edu.cn/endeavouros/repo/$repo/$arch 1176 0.602221
# https://de.freedif.org/EndeavourOS/repo/$repo/$arch 1176 0.905102
# https://ftp.acc.umu.se/mirror/endeavouros/repo/$repo/$arch 1176 0.948932
# http://mirror.jingk.ai/endeavouros/repo/$repo/$arch 1176 1.314130
# https://endeavour.remi.lu/repo/$repo/$arch 1176 1.321978
# https://ca.gate.endeavouros.com/endeavouros/repo/$repo/$arch 1176 1.376193
# https://mirror.linux.pizza/endeavouros/repo/$repo/$arch 1176 2.089185
# https://mirror.jingk.ai/endeavouros/repo/$repo/$arch 1176 5.171062
# https://mirror.moson.org/endeavouros/repo/$repo/$arch 1176 5.662822
# https://mirror.alpix.eu/endeavouros/repo/$repo/$arch 1176 5.809706
# EndeavourOS mirrorlist:
i got this, what should i do?
[caviezel@Nicolas ~]$ rm -r /var/lib/pacman/sync/
rm: descend into write-protected directory '/var/lib/pacman/sync/'?
EOS
January 30, 2022, 8:48pm
20
Add # at the beginning of this line:
It should look like this:
# Server = https://mirror.funami.tech/endeavouros/repo/$repo/$arch
Lines with a # sign at the beginning are skipped.
Edit it with sudo nano /etc/pacman.d/endeavouros-mirrorlist
Remember to save changes to a file.
