You don’t need to explicitly install solid. It will get pulled in as a dependency.
This is terrifying
I prefer flameshot as well but it has some issues on wayland if you use multiple monitors.
Please don’t use discover or any other packagekit-based application(Gnome Software) to install/update packages on Arch-based distros. On the other hand, it is fine for managing flatpaks and kde components.
The only reason I mentioned ‘Discovery’ is I will search for packages from there when I am reading in posts. But then install from command line.
The sad thing is I really like Gnome Screen capture for video when I bug things. My goal is to break free from Gnome … but I will be doing allot of testing.
Ah yes seahorse. I had one of THOSE conversations with the Gnome developers on how the fingerprint authentication was implemented. So one of many reasons I am drifting to KDE.
Well just figured out that going into gnome tweaks that ‘Legacy Applications’ got switched to ‘Breeze’. So this is why the controls looked like KDE Style.
Looks like you’re getting there I’ve never run a system with both Gnome and KDE installed, and others have reported minor conflicts and problems when they do. If you do decide to switch to KDE full time, a clean install might have some benefits.
Very neat suggestion. It would definitely work for me when I put on my suckless hat.
The truth is I support 5 other users in the family on EndeavourOS (long hard fought battle to get them off Windows 10 then onto Gnome). I have 2 more people I would like to move this year to Gnome. So for non technical users I try to have GUI like experiences like the Pop Store where possible.
I 100% agree with having a separate profile. My goal is not longterm co-existence. Its to help me monitor Wayland, Pipewire and Firejail changes as I plan to move fully over to KDE.
I’m actively writing documentation so I can re-build my setup by doing a new install. So at the moment I am writng a Matrix for the applications I intend to use in KDE for when I full switch my workflows to KDE…
So the real challenge for me is I am doing this while also trying to get my day to day work done. So perhaps I won’t do any crazy Linux Scoop theming till I am ready
This kind of switch reminds me of when I compare Windows (Gnome) to OS/2 (KDE). KDE is like the ultimate lego. And to be really honest that last time I used KDE was maybe 2003.
So today I figured out that KDE is not remembering my Mic and Volume preferences every time I sign out and then sign back in again (it resets to 69%). So now I am research what solution I should use for a pipewire\wayland setup.
I hope it is not creating a manual configuration file.
