Hi Everyone,
I had created this thread a few weeks ago: Cannot boot into live environment
The gist is that the live USB provides 3 boot options: default, nvidia, or fallback (NOMODESET). In fallback mode, X11 would throw an error and would not start. In either of the other 2 modes (default or nvidia), I would just get a black screen. This was using the Apollo release, but I had the same issue with Artemis. I could not even switch to a terminal to get logs. However, I tried my external monitors and they are recognized and working. Specifically, the external monitors start working when the internal display stops working; early in the boot process. Since I can now install and provide proper log output, Iâm starting a new thread that reflects the current issue.
My laptop is an MSI CreatorPro Z17
I installed Endeavour using the default (no NVidia driver) option and chose Cinnamon as my DE. (Choosing to install the Nvidia driver at installation time still results in my laptop display not being detected, but if someone wants to see logs with that option chosen, I can do that). I appreciate anyone who may be able to help figure out whatâs going on with my laptop display.
Here are some logs that will hopefully shed light on this situation:
inxi -Fxxc0z --no-host | eos-sendlog
https://clbin.com/S27Tv
journalctl -b -0 | eos-sendlog
https://clbin.com/ilCx5
The main thing that stands out for me is this one:
xrandr -q --verbose
Summary
xrandr: Output eDP1 is not disconnected but has no modes
Screen 0: minimum 8 x 8, current 3840 x 1200, maximum 32767 x 32767
eDP1 connected (normal left inverted right x axis y axis)
Identifier: 0x43
Timestamp: 17398959
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff0006af9b3c00000000
141f0104a52517780308b5ae5242b226
0c505400000001010101010101010101
010101010101e8fd00a0a0404c693020
aa006ee4100000180000000f00000000
00000000000000000020000000fd0c3c
a520204e010a202020202020000000fe
004231373051414e30312e30200a01ad
70137900000301141a300184ff099f00
2f001f003f0685000900040000000000
00000000000000000000000000000000
0000000000000000000000000000c190
BACKLIGHT: 4800
range: (0, 96000)
Backlight: 4800
range: (0, 96000)
vrr_capable: 1
range: (0, 1)
scaling mode: Full aspect
supported: Full, Center, Full aspect
Colorspace: Default
supported: Default, RGB_Wide_Gamut_Fixed_Point, RGB_Wide_Gamut_Floating_Point, opRGB, DCI-P3_RGB_D65, BT2020_RGB, BT601_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, BT2020_CYCC, BT2020_YCC
max bpc: 12
range: (6, 12)
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
panel orientation: Normal
supported: Normal, Upside Down, Left Side Up, Right Side Up
link-status: Good
supported: Good, Bad
non-desktop: 0
range: (0, 1)
DP1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x44
Timestamp: 17398959
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
HDCP Content Type: HDCP Type0
supported: HDCP Type0, HDCP Type1
Content Protection: Undesired
supported: Undesired, Desired, Enabled
vrr_capable: 0
range: (0, 1)
Colorspace: Default
max bpc: 12
range: (6, 12)
audio: auto
supported: force-dvi, off, auto, on
subconnector: Unknown
supported: Unknown, VGA, DVI-D, HDMI, DP, Wireless, Native
link-status: Good
non-desktop: 0
range: (0, 1)
DP2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x45
Timestamp: 17398959
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
vrr_capable: 0
range: (0, 1)
Colorspace: Default
max bpc: 12
range: (6, 12)
audio: auto
link-status: Good
non-desktop: 0
range: (0, 1)
DP2-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x53e
Timestamp: 17398959
Subpixel: unknown
Clones: DP2-1-1 DP2-1-8 DP2-8
CRTCs: 0 1 2 3
filter:
max bpc: 12
range: (6, 12)
audio: auto
link-status: Good
non-desktop: 0
range: (0, 1)
DP2-1-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x540
Timestamp: 17398959
Subpixel: unknown
Clones: DP2-1 DP2-1-8 DP2-8
CRTCs: 0 1 2 3
filter:
max bpc: 12
range: (6, 12)
audio: auto
link-status: Good
non-desktop: 0
range: (0, 1)
DP2-1-8 connected primary 1920x1200+1920+0 (0x541) normal (normal left inverted right x axis y axis) 520mm x 320mm
Identifier: 0x53f
Timestamp: 17398959
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones: DP2-1 DP2-1-1 DP2-8
CRTC: 0
CRTCs: 0 1 2 3
filter:
_MUTTER_PRESENTATION_OUTPUT: 0
EDID:
00ffffffffffff0010acb8a04c364b31
2d180104a53420783a0495a9554d9d26
105054a54b00714f8180a940d1c0d100
010101010101283c80a070b023403020
360006442100001e000000ff0050564a
5657344234314b364c0a000000fc0044
454c4c2055323431350a2020000000fd
00313d1e5311000a20202020202001de
02031cf14f9005040302071601141f12
132021222309070783010000023a8018
71382d40582c450006442100001e011d
8018711c1620582c250006442100009e
011d007251d01e206e28550006442100
001e8c0ad08a20e02d10103e96000644
21000018000000000000000000000000
0000000000000000000000000000000c
max bpc: 12
range: (6, 12)
audio: auto
link-status: Good
non-desktop: 0
range: (0, 1)
1920x1200 (0x541) 154.000MHz +HSync +VSync *current +preferred
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 74.04KHz
v: height 1200 start 1203 end 1209 total 1235 clock 59.95Hz
1920x1080 (0x542) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x543) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0x544) 148.352MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080 (0x545) 74.250MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.75KHz
v: height 1080 start 1084 end 1089 total 1125 clock 30.00Hz
1920x1080 (0x546) 74.250MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 28.12KHz
v: height 1080 start 1084 end 1089 total 1125 clock 25.00Hz
1920x1080 (0x547) 74.250MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 27.00KHz
v: height 1080 start 1084 end 1089 total 1125 clock 24.00Hz
1920x1080 (0x548) 74.176MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.72KHz
v: height 1080 start 1084 end 1089 total 1125 clock 29.97Hz
1920x1080 (0x549) 74.176MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 26.97KHz
v: height 1080 start 1084 end 1089 total 1125 clock 23.98Hz
1600x1200 (0x54a) 162.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.00KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.00Hz
1280x1024 (0x54b) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x54c) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1152x864 (0x54d) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1280x720 (0x54e) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x54f) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1280x720 (0x550) 74.176MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1024x768 (0x551) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x552) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x553) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x554) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0x555) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x556) 27.027MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.50KHz
v: height 480 start 489 end 495 total 525 clock 60.00Hz
720x480 (0x557) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x558) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x559) 25.200MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.50KHz
v: height 480 start 490 end 492 total 525 clock 60.00Hz
640x480 (0x55a) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
720x400 (0x55b) 28.320MHz -HSync +VSync
h: width 720 start 738 end 846 total 900 skew 0 clock 31.47KHz
v: height 400 start 412 end 414 total 449 clock 70.08Hz
DP2-8 connected 1920x1200+0+0 (0x541) normal (normal left inverted right x axis y axis) 520mm x 320mm
Identifier: 0x53d
Timestamp: 17398959
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones: DP2-1 DP2-1-1 DP2-1-8
CRTC: 1
CRTCs: 0 1 2 3
filter:
EDID:
00ffffffffffff0010acb8a04c504431
2e180104a53420783a0495a9554d9d26
56573442413144504c0a000000fc0044
00313d1e5311000a20202020202001aa
max bpc: 12
range: (6, 12)
audio: auto
link-status: Good
non-desktop: 0
range: (0, 1)
DP3 disconnected (normal left inverted right x axis y axis)
Identifier: 0x46
Timestamp: 17398959
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
vrr_capable: 0
range: (0, 1)
Colorspace: Default
max bpc: 12
range: (6, 12)
audio: auto
link-status: Good
non-desktop: 0
range: (0, 1)
DP4 disconnected (normal left inverted right x axis y axis)
Identifier: 0x47
Timestamp: 17398959
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
vrr_capable: 0
range: (0, 1)
Colorspace: Default
max bpc: 12
range: (6, 12)
audio: auto
link-status: Good
non-desktop: 0
range: (0, 1)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x48
Timestamp: 17398959
Subpixel: no subpixels
Clones:
CRTCs: 4
filter:
non-desktop: 0
supported: 0, 1
It says eDP1 is connected but has no modes. Iâve seen an Arch document on manually adding modes, but Iâm wondering why the supported modes arenât being probed directly from the display.
Please let me know what other logs or info may be relevant. Thank you in advance to anyone who is willing to take a look at this.
Thanks,
Dale
