I don’t know that I tried pressing F11 before hooking up the external monitors. I will double check.
Also did you get my note that there is a UEFI Bios update.
Yes, thank you for the note about the BIOS. I’m running E17N1IWS.311 right now which was released on July 7th.
I really think you were right about how there should be a BIOS setting to use the discrete card only. From what I can tell, there may be such an option, but it’s hidden from the normal BIOS menu and accessible only through MSI’s Windows only program. I currently digging into this. I’ll let you know what I find.
Thanks,
Dale
If you want to try you can install WINE and see if you could get the MSI Control Center to install under that. It maybe worth a try before installing Windows on the side…
Hi there !
After googling several days it seems that I had a similar behavior here :
here’s what I tried : Installing Endeavour on an old mini PC:
System : Lenovo Thinkcentre M72E MAHOBAY
CPU : Intel core i3-3220T
GPU: Intel HD Graphics 2500 internal
Display : Noname TCL MT35
Please excuse poor quality screenshots : this is the nomodset option boot.
after trying a lot of ideas listed above nothing worked.
So I’ve got the idea of switching display : I tried SAMSUNG SyncMaster P2270HD and all went good !!
In my opinion it’s not UEFI or NVIDIA issue because the system is installed in BIOS mode and no NVIDIA here ( no choices about UEFI because Windows was there installed in MBR and we use it with crippled dongle software
So now it’s working but I’m curious about what went wrong before, with the first monitor (plus I need the SAMSUNG SyncMaster for another machine…)
It seems that some displays are not “standard” regarding X11.
I had a same issue years ago for a laptop with a Mandrake distro : it was only working with 1024x768, 255 color depth.
Any ideas ? or what should I try ??
Thanks in advance
