If not EndeavourOS, what distro would you be using?
I just read this unless you said that somewhere else?
Edit: Okay i see it above in another post! My bad!
So 122 update I have on eos sway :crazy_face: give you + @RodneyCK little worry ? :joy:
I usually wait till i have at least 500. :rofl:
Done that :crazy_face::wink:
How can you keep yourself from not opening your terminal… or Pamac, I’m not judgy… I would implode, if I were you. :rofl:
If I on computer I in terminal :crazy_face: just no need for “ pacman -Syu or yay “ every time it open :+1:
Takes years of practice and meditation :pensive:
That’s how it feels on EndeavourOS! Zen!
I would literally be …
let you know 122 finish + zero problem. i use now for message now … :blush:
In other words, it’s like working in a candy shop, you’re immune to the temptation. :crazy_face:
I will never reach that level of coolness, I’m afraid :exploding_head:
Okay, my apologies for getting off-topic, I’ll stop now. (This happens when you have time off… :stuck_out_tongue:)
no temptation …update
before eye see “manjaro” it kernel for pinebook pro for Arch at moment ( i no change for test eos sway on stock PBP kernel "
I’m so sad now…
You could always downgrade! :grin:
no feel sad … my same now :rofl:
@Lemon I too am so very sad now! :stuck_out_tongue:
Screenshot from 2021-08-10 11-52-50
Old saying, “you seldom find a diabetic working in a candy shop.” :candy:
In other words, do what’s best for you.
Pudge
Too bad this doesn’t work! :laughing:
sudo downgrade -all
Use the Arch archives to back up to a specific date - then you can re-upgrade for your ‘fix’! Check our Wiki for easy ways to do that :grin:
Unless I have zfs-kernel updates, most of them struggle to take as long as a minute - something to do with the hi-speed fibre connection I guess (not to mention the parallel downloads).
Oh - the kernel updates? Their repo is capable of only a few Kps - so minutes every time…
You downgraded to Gnome? :scream_cat:
