How do I fix Chromium-based browser lags
I have made a post before about how any Linux distro underperformes compared to Windows 10 in the past.
It turns out I was mistaken in some areas.
I did two phoronix benchmark tests on both operating systems, one was unigine-heaven which the results were this which was very similar (Windows was slightly better)
The other phoronix test which was openarena, EndeavourOS did better than Windows.
Windows 10
EndeavourOS (linux-vanilla kernel)
So everywhere else EndeavourOS seems to perform better but when it comes to chromium-based browsers it lags when scrolling and doing anything else. Some websites the browser does not lag at all but on other websites that have got more content on it (such as images) it does lag, but those exact same websites on Windows runs completely fine. This particular website website is very laggy on any Linux distro. On firefox that website does fine (other than having screen-tearing issues but is not present on chromium-based browsers) but why does this lag so much on chromium-based browsers? Is there a way to fix this? I am using KDE. (This issue is not specific to EndeavourOS and it happens to other Linux distros as well).
I am also using KDE and that particular website does not lag at all for me. I use Firefox and i will try Chromium but i can almost guarantee you i have no issue.
Edit: No lag on Chromium. My suggestion to alleviate all your issues is get new hardware without Intel Graphics.
Hello @unix_lover
Have you tried this to see whether your chromium browser is using hardware acceleration or software?
https://bbs.archlinux.org/viewtopic.php?id=244031
https://wiki.archlinux.org/index.php/Hardware_video_acceleration
I did the test on my hardware just for fun. …
Screenshot_20200224_112600
Screenshot_20200224_112626
Edit: do you have ffmpeg installed?
I believe with Nvidia it will run fine.
I have got another friend who also has Intel hardware and he claims that there is no lag when using chromium-based. Particular with that website.
Ok so I installed chromium-vaapi-bin
To see whether you are currently using Hardware or Software acceleration, play a video and in a new tab open chrome://media-internals/ , click on the video and check the video_decoder field:
  • Hardware acceleration: MojoVideoDecoder, GpuVideoDecoder
  • Software acceleration: VpxVideoDecoder, FFmpegVideoDecoder (some say it’s Hardware acceleration?)
I did that but I couldn’t even find the video_decoder field (I did a ctrl+f to search for it) nor hardware.
Also check chrome://gpu and ensure that you see:
  • Video Decode: Hardware accelerated
I did that and the Video Decode says it is unavailable, even though I just installed chromium-vaapi-bin package.
All though the videos on YouTube don’t really seem to lag that much compared to scrolling.
Sorry mate I really wouldn’t happen to understand what all the information means in the images.
Yes its already installed.
So I went inside chrome://gpu/ and I just wanted to paste my log (this one is specific to brave)
Graphics Feature Status
Canvas: Hardware accelerated
Flash: Hardware accelerated
Flash Stage3D: Hardware accelerated
Flash Stage3D Baseline profile: Hardware accelerated
Compositing: Hardware accelerated
Multiple Raster Threads: Enabled
Out-of-process Rasterization: Disabled
OpenGL: Enabled
Hardware Protected Video Decode: Unavailable
Rasterization: Software only. Hardware acceleration disabled
Skia Renderer: Enabled
Viz Display Compositor: Enabled
Vulkan: Disabled
WebGL: Hardware accelerated
WebGL2: Hardware accelerated
Driver Bug Workarounds
adjust_src_dst_region_for_blitframebuffer
clear_uniforms_before_first_program_use
count_all_in_varyings_packing
disable_post_sub_buffers_for_onscreen_surfaces
exit_on_context_lost
msaa_is_slow
rely_on_implicit_sync_for_swap_buffers
scalarize_vec_and_mat_constructor_args
disabled_extension_GL_KHR_blend_equation_advanced
disabled_extension_GL_KHR_blend_equation_advanced_coherent
disabled_extension_GL_MESA_framebuffer_flip_y
Problems Detected
Accelerated video decode is unavailable on Linux: 137247
Disabled Features: accelerated_video_decode
Protected video decoding with swap chain is for Windows and Intel only
Disabled Features: protected_video_decode
Clear uniforms before first program use on all platforms: 124764, 349137
Applied Workarounds: clear_uniforms_before_first_program_use
Mesa drivers in Linux handle varyings without static use incorrectly: 333885
Applied Workarounds: count_all_in_varyings_packing
Disable partial swaps on Mesa drivers (detected with GL_RENDERER): 339493
Applied Workarounds: disable_post_sub_buffers_for_onscreen_surfaces
Always rewrite vec/mat constructors to be consistent: 398694
Applied Workarounds: scalarize_vec_and_mat_constructor_args
On Intel GPUs MSAA performance is not acceptable for GPU rasterization: 527565
Applied Workarounds: msaa_is_slow
Disable partial swaps on Mesa drivers (detected with GL_VERSION): 339493
adjust src/dst region if blitting pixels outside framebuffer on Linux Intel: 664740
Applied Workarounds: adjust_src_dst_region_for_blitframebuffer
Disable KHR_blend_equation_advanced until cc shaders are updated: 661715
Applied Workarounds: disable(GL_KHR_blend_equation_advanced), disable(GL_KHR_blend_equation_advanced_coherent)
Some drivers can't recover after OUT_OF_MEM and context lost: 893177
Applied Workarounds: exit_on_context_lost
Avoid waiting on a egl fence before swapping buffers and rely on implicit sync on Intel GPUs: 938286
Applied Workarounds: rely_on_implicit_sync_for_swap_buffers
Disable GL_MESA_framebuffer_flip_y for desktop GL: 964010
Applied Workarounds: disable(GL_MESA_framebuffer_flip_y)
Version Information
Data exported	2020-02-25T02:11:54.010Z
Chrome version	Chrome/80.0.3987.116
Operating system	Linux 5.5.5-arch1-1
Software rendering list URL	https://chromium.googlesource.com/chromium/src/+/dc00a510e4c2ae25c4d084cc3d946fc782249224/gpu/config/software_rendering_list.json
Driver bug list URL	https://chromium.googlesource.com/chromium/src/+/dc00a510e4c2ae25c4d084cc3d946fc782249224/gpu/config/gpu_driver_bug_list.json
ANGLE commit id	362168eb695d
2D graphics backend	Skia/80 97c9a95908bc8c7a6794259b35f366a3291e2d0f
Command Line	/usr/lib/brave-bin/brave --enable-dom-distiller --disable-domain-reliability --no-pings --extension-content-verification=enforce_strict --extensions-install-verification=enforce --sync-url=https://no-thanks.invalid --enable-features=PasswordImport,WebUIDarkMode,SimplifyHttpsIndicator --disable-features=AutofillServerCommunication,VideoPlaybackQuality,AllowPopupsDuringPageUnload,SmsReceiver,AudioServiceOutOfProcess,NotificationTriggers,LookalikeUrlNavigationSuggestionsUI,WebXR,WebXrGamepadModule --flag-switches-begin --flag-switches-end --disable-webrtc-apm-in-audio-service --disable-sync
Driver Information
Initialization time	364
In-process GPU	false
Passthrough Command Decoder	false
Sandboxed	false
GPU0	VENDOR= 0x8086 [Intel Open Source Technology Center], DEVICE=0x5916 [Mesa DRI Intel(R) HD Graphics 620 (Kaby Lake GT2) ] *ACTIVE*
Optimus	false
AMD switchable	false
Driver vendor	Mesa
Driver version	19.3.4
GPU CUDA compute capability major version	0
Pixel shader version	4.60
Vertex shader version	4.60
Max. MSAA samples	16
Machine model name
Machine model version
GL_VENDOR	Intel Open Source Technology Center
GL_RENDERER	Mesa DRI Intel(R) HD Graphics 620 (Kaby Lake GT2)
GL_VERSION	4.6 (Core Profile) Mesa 19.3.4
GL_EXTENSIONS	GL_3DFX_texture_compression_FXT1 GL_AMD_conservative_depth GL_AMD_depth_clamp_separate GL_AMD_draw_buffers_blend GL_AMD_gpu_shader_int64 GL_AMD_multi_draw_indirect GL_AMD_query_buffer_object GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_AMD_shader_trinary_minmax GL_AMD_texture_texture4 GL_AMD_vertex_shader_layer GL_AMD_vertex_shader_viewport_index GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_APPLE_object_purgeable GL_ARB_ES2_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_compressed_texture_pixel_storage GL_ARB_compute_shader GL_ARB_conditional_render_inverted GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_shader GL_ARB_fragment_shader_interlock GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_post_depth_coverage GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_ballot GL_ARB_shader_bit_encoding GL_ARB_shader_clock GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_stencil_export GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shader_viewport_layer_array GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_spirv_extensions GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map_array GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ATI_blend_equation_separate GL_ATI_texture_float GL_EXT_EGL_sync GL_EXT_abgr GL_EXT_blend_equation_separate GL_EXT_demote_to_helper_invocation GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_shader_framebuffer_fetch GL_EXT_shader_framebuffer_fetch_non_coherent GL_EXT_shader_integer_mix GL_EXT_shader_samples_identical GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_sRGB GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_decode GL_EXT_texture_shadow_lod GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_IBM_multimode_draw_arrays GL_INTEL_conservative_rasterization GL_INTEL_performance_query GL_INTEL_shader_atomic_float_minmax GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_parallel_shader_compile GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_MESA_framebuffer_flip_y GL_MESA_pack_invert GL_MESA_shader_integer_functions GL_MESA_texture_signed_rgba GL_NV_compute_shader_derivatives GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fragment_shader_interlock GL_NV_packed_depth_stencil GL_NV_texture_barrier GL_OES_EGL_image GL_S3_s3tc
Disabled Extensions	GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_MESA_framebuffer_flip_y
Disabled WebGL Extensions
Window system binding vendor	SGI
Window system binding version	1.4
Window system binding extensions	GLX_ARB_create_context GLX_ARB_create_context_no_error GLX_ARB_create_context_profile GLX_ARB_create_context_robustness GLX_ARB_fbconfig_float GLX_ARB_framebuffer_sRGB GLX_ARB_multisample GLX_EXT_create_context_es_profile GLX_EXT_create_context_es2_profile GLX_EXT_fbconfig_packed_float GLX_EXT_framebuffer_sRGB GLX_EXT_import_context GLX_EXT_libglvnd GLX_EXT_no_config_context GLX_EXT_texture_from_pixmap GLX_EXT_visual_info GLX_EXT_visual_rating GLX_MESA_copy_sub_buffer GLX_OML_swap_method GLX_SGI_make_current_read GLX_SGI_swap_control GLX_SGIS_multisample GLX_SGIX_fbconfig GLX_SGIX_pbuffer GLX_SGIX_visual_select_group GLX_INTEL_swap_event
Window manager	KWin
XDG_CURRENT_DESKTOP	KDE
Compositing manager	Yes
Direct rendering version	DRI3
Reset notification strategy	0x8252
GPU process crash count	0
System visual ID	32
RGBA visual ID	408
gfx::BufferFormats supported for allocation and texturing	R_8: not supported, R_16: not supported, RG_88: not supported, BGR_565: not supported, RGBA_4444: not supported, RGBX_8888: not supported, RGBA_8888: not supported, BGRX_8888: not supported, BGRX_1010102: not supported, RGBX_1010102: not supported, BGRA_8888: not supported, RGBA_F16: not supported, YVU_420: not supported, YUV_420_BIPLANAR: not supported, P010: not supported
Compositor Information
Tile Update Mode	One-copy
Partial Raster	Enabled
GpuMemoryBuffers Status
R_8	Software only
R_16	Software only
RG_88	Software only
BGR_565	Software only
RGBA_4444	Software only
RGBX_8888	Software only
RGBA_8888	Software only
BGRX_8888	Software only
BGRX_1010102	Software only
RGBX_1010102	Software only
BGRA_8888	Software only
RGBA_F16	Software only
YVU_420	Software only
YUV_420_BIPLANAR	Software only
P010	Software only
Display(s) Information
Info	Display[1657942003464773] bounds=[0,0 1920x1080], workarea=[0,0 1920x1044], scale=1, rotation=0, panel_rotation=0 external.
Color space information	{primaries:INVALID, transfer:INVALID, matrix:INVALID, range:INVALID}
SDR white level in nits	80
Bits per color component	8
Bits per pixel	24
Refresh Rate in Hz	60
Video Acceleration Information
Vulkan Information
Log Messages
[6355:6355:0225/125129.675509:ERROR:vaapi_wrapper.cc(417)] : vaInitialize failed: unknown libva error
[6355:6355:0225/125129.978082:ERROR:sandbox_linux.cc(374)] : InitializeSandbox() called with multiple threads in process gpu-process.
[6355:6355:0225/125422.399723:ERROR:shared_image_manager.cc(191)] : SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
[6355:6355:0225/125422.401218:ERROR:shared_image_manager.cc(191)] : SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
I was hoping if somebody understands this log and knows what is causing the lag.
In case the log that I have submitted is hard to read, I have also pasted the contents in a document https://drive.google.com/open?id=1pT7XBCty5Ej1D3LAZnsFF9CdIq3ytEkg so that it is easier to read.
Let me try and see if it works now, hopefully.
Ok so when I tested out brave, I typed this out in the terminal brave --enable-gpu-rasterization --ignore-gpu-blacklist --disable-gpu-driver-workarounds and I tested out this website https://linuxconfig.org/benchmark-your-graphics-card-on-linux.
It does seem to be smoother now with little lag. And for some reason I am getting errrors in the console.
[4374:4374:0225/150641.768461:ERROR:vaapi_wrapper.cc(417)] vaInitialize failed: unknown libva error
[4374:4374:0225/150641.828119:ERROR:sandbox_linux.cc(374)] InitializeSandbox() called with multiple threads in process gpu-process.
[4350:4366:0225/150641.936944:ERROR:rewards_service_impl.cc(206)] Failed to read file: /home/user1/.config/BraveSoftware/Brave-Browser/Default/ledger_state
[4382:4382:0225/150642.015997:ERROR:ledger_impl.cc(102)] Failed to initialize wallet
[4432:1:0225/150642.477159:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4432:1:0225/150642.482840:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4432:1:0225/150642.555189:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4432:1:0225/150642.556842:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4432:1:0225/150642.562601:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4432:1:0225/150642.569936:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4432:1:0225/150642.573624:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4432:1:0225/150642.581982:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4432:1:0225/150642.583865:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4432:1:0225/150642.586019:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4499:1:0225/150644.002756:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4499:1:0225/150644.007219:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4350:4350:0225/150655.061023:ERROR:CONSOLE(0)] "Unchecked runtime.lastError: Cannot access contents of url "chrome://gpu/". Extension manifest must request permission to access this host.", source: chrome-extension://mnojpmjdmbbfmejpflffifhffcmidifd/_generated_background_page.html (0)
[4350:4350:0225/150655.061087:ERROR:CONSOLE(0)] "Unchecked runtime.lastError: Cannot access contents of url "chrome://newtab/". Extension manifest must request permission to access this host.", source: chrome-extension://mnojpmjdmbbfmejpflffifhffcmidifd/_generated_background_page.html (0)
[4350:4350:0225/150656.624712:ERROR:CONSOLE(0)] "Unchecked runtime.lastError: Cannot access contents of url "chrome://media-internals/". Extension manifest must request permission to access this host.", source: chrome-extension://mnojpmjdmbbfmejpflffifhffcmidifd/_generated_background_page.html (0)
[4644:1:0225/150658.675364:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4644:1:0225/150658.675885:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4644:1:0225/150658.676499:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4644:1:0225/150658.677151:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4644:1:0225/150658.678485:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4644:1:0225/150658.679185:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4644:1:0225/150658.680367:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4644:1:0225/150658.684527:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4644:1:0225/150658.685787:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4644:1:0225/150658.686406:ERROR:child_process_sandbox_support_impl_linux.cc(79)] FontService unique font name matching request did not receive a response.
[4350:4350:0225/150702.394885:ERROR:CONSOLE(0)] "Unchecked runtime.lastError: Cannot access contents of url "chrome://gpu/". Extension manifest must request permission to access this host.", source: chrome-extension://mnojpmjdmbbfmejpflffifhffcmidifd/_generated_background_page.html (0)
[4350:4350:0225/150702.416069:ERROR:CONSOLE(0)] "Unchecked runtime.lastError: Cannot access contents of url "chrome://settings/". Extension manifest must request permission to access this host.", source: chrome-extension://mnojpmjdmbbfmejpflffifhffcmidifd/_generated_background_page.html (0)
[4350:4350:0225/150702.651868:ERROR:CONSOLE(4)] "Polymer is already defined.", source: chrome://settings/crisper.js (4)
Is there something else that needs to be enabled/disabled in order to fully fix the lag issues?
I looked at this log and it’s similar to mine although i have a high end nvidia card.
The one thing i did see is this (vaInitialize failed: unknown libva error)
I see this is common error on Brave. Are you using the open source driver not intel?
Did you run vaininfo
Are you getting the same error on your side?
I am currently using modesetting right now. I tried to disable modesetting by following this person’s method How do I disable modesetting? - #2 by anotherusername but that completely ruined the display after a reboot so I was forced to reinstall Endeavour.
This package doesn’t seem to exist and when I tried to install it yay -S vaininfo it doesn’t exist.
Edit: So I have the Windows version of chrome://gpu/ https://drive.google.com/open?id=1pT7XBCty5Ej1D3LAZnsFF9CdIq3ytEkg
Is there something I need to use for Linux instead? Do I need to replace the gl_render or gl_version or something on Endeavour to match it with Windows?
I think you have to have libva-utils installed to run vainfo. vainfo tells you whether vavapi is setup properly. I’m just reading it from the Arch wiki. The problem with the Arch wiki is everything just leads you down another rabbit hole and i find it really doesn’t explain how to do something form start to finish. There is so much information and you have to decipher what is relevant for your hardware and issue. Good luck. with that. :grin:
Read 100 times …check more! :laughing:
You didn’t have to reinstall the whole operating system. It’d have taken ~5 minutes to revert the changes.
Also, another person on the same thread adviced to temporarily change the params and make sure everything works.
Is it through chroot?
Yes true but I changed to nomodesetting before I saw that post that day. But I guess I could try it again through the temporary Grub settings
Edit: So I actually don’t know where to ad this nomodesetting (so I asked in the other post on how to do this) but regardless if it failed without changing it in the grub settings, I am sure it will fail if I did this through grub, so in other words I need to have modesettings.
No. You could just remove the option from grub when booting. After the system is up, just revert the changes, recreate grub config.
Ah I see, I will give that a try.
Yes true, I don’t get why some YOuTubers say this is a good website and suggest to bookmark it.
I get lost a lot with their website.
Lol
I highly disagree. The statement “might” be true for the Gentoo wiki, or Slackware howtos, but AW is as easy and straight forward as there can be.
Yes they explain what you need to do to achieve something but like sometimes they don’t explain things in details for example I remember in the past it didn’t explain what these flags meant for something (I can’t quite remember what I was searching up)… Plus it can get too technical for noobs like me.
Short answer, it can’t. The wiki tells you just enough to get by while still not be totally in the dark. Each topic it takes on, will have something related ought to be explained. If they start explaining everything. . . . I don’t know, actually they just can’t. For you it was some flags, for another person, it’ll be something different, like say “bootloader” or “configs” or “format”. If you want to know about something, you’ll have to search on that yourself. If you want to know about some flags of a program named “X”, you’ll have to look into its documentation. It’s “Arch Wiki”, not a “documentation of everything”.
Fair enough and you are right about that. I can also understand it can become too bloated the documentation website if they explained everything.
Ok so after installing libva-utils, when i ran vainfo I get this error message vaInitialize failed with error code -1 (unknown libva error),exit
Install libva-intel-driver. It’ll fix the issue.
@anotherusername @ricklinux Ok so after installing libva-intel-driver and after runnign vainfo I am getting this output.
vainfo: VA-API version: 1.6 (libva 2.6.0)
vainfo: Driver version: Intel i965 driver for Intel(R) Kaby Lake - 2.4.0
vainfo: Supported profile and entrypoints
      VAProfileMPEG2Simple            :	VAEntrypointVLD
      VAProfileMPEG2Simple            :	VAEntrypointEncSlice
      VAProfileMPEG2Main              :	VAEntrypointVLD
      VAProfileMPEG2Main              :	VAEntrypointEncSlice
      VAProfileH264ConstrainedBaseline:	VAEntrypointVLD
      VAProfileH264ConstrainedBaseline:	VAEntrypointEncSlice
      VAProfileH264ConstrainedBaseline:	VAEntrypointEncSliceLP
      VAProfileH264Main               :	VAEntrypointVLD
      VAProfileH264Main               :	VAEntrypointEncSlice
      VAProfileH264Main               :	VAEntrypointEncSliceLP
      VAProfileH264High               :	VAEntrypointVLD
      VAProfileH264High               :	VAEntrypointEncSlice
      VAProfileH264High               :	VAEntrypointEncSliceLP
      VAProfileH264MultiviewHigh      :	VAEntrypointVLD
      VAProfileH264MultiviewHigh      :	VAEntrypointEncSlice
      VAProfileH264StereoHigh         :	VAEntrypointVLD
      VAProfileH264StereoHigh         :	VAEntrypointEncSlice
      VAProfileVC1Simple              :	VAEntrypointVLD
      VAProfileVC1Main                :	VAEntrypointVLD
      VAProfileVC1Advanced            :	VAEntrypointVLD
      VAProfileNone                   :	VAEntrypointVideoProc
      VAProfileJPEGBaseline           :	VAEntrypointVLD
      VAProfileJPEGBaseline           :	VAEntrypointEncPicture
      VAProfileVP8Version0_3          :	VAEntrypointVLD
      VAProfileVP8Version0_3          :	VAEntrypointEncSlice
      VAProfileHEVCMain               :	VAEntrypointVLD
      VAProfileHEVCMain               :	VAEntrypointEncSlice
      VAProfileHEVCMain10             :	VAEntrypointVLD
      VAProfileHEVCMain10             :	VAEntrypointEncSlice
      VAProfileVP9Profile0            :	VAEntrypointVLD
      VAProfileVP9Profile0            :	VAEntrypointEncSlice
      VAProfileVP9Profile2            :	VAEntrypointVLD
Is everything working fine?
Now try to run the browser from a terminal, see the output, look for the lag you’re facing previously.
