Here is “Dmesg Part 3”…
[ 0.594344] NET: Registered protocol family 2
[ 0.594497] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.594511] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.594599] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.594741] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.594776] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.594800] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.594865] NET: Registered protocol family 1
[ 0.594871] NET: Registered protocol family 44
[ 0.594877] pci 0000:00:01.0: MSI quirk detected; subordinate MSI disabled
[ 0.613517] pci 0000:00:12.0: quirk_usb_early_handoff+0x0/0x63a took 18185 usecs
[ 0.630179] pci 0000:00:12.1: quirk_usb_early_handoff+0x0/0x63a took 16263 usecs
[ 0.646870] pci 0000:00:13.0: quirk_usb_early_handoff+0x0/0x63a took 16087 usecs
[ 0.664500] pci 0000:00:13.1: quirk_usb_early_handoff+0x0/0x63a took 17207 usecs
[ 0.683507] pci 0000:00:14.5: quirk_usb_early_handoff+0x0/0x63a took 18333 usecs
[ 0.683527] pci 0000:01:05.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.683536] pci 0000:01:05.1: D0 power state depends on 0000:01:05.0
[ 0.683876] PCI: CLS 64 bytes, default 64
[ 0.683917] Trying to unpack rootfs image as initramfs...
[ 0.794923] Freeing initrd memory: 9196K
[ 0.794931] PCI-DMA: Disabling AGP.
[ 0.794985] PCI-DMA: aperture base @ c4000000 size 65536 KB
[ 0.794985] PCI-DMA: using GART IOMMU.
[ 0.794987] PCI-DMA: Reserving 64MB of IOMMU area in the AGP aperture
[ 0.797232] amd_uncore: AMD NB counters detected
[ 0.797339] LVT offset 0 assigned for vector 0x400
[ 0.797374] perf: AMD IBS detected (0x000000ff)
[ 0.797424] check: Scanning for low memory corruption every 60 seconds
[ 0.797816] Initialise system trusted keyrings
[ 0.797824] Key type blacklist registered
[ 0.797877] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[ 0.799246] zbud: loaded
[ 0.803868] Key type asymmetric registered
[ 0.803870] Asymmetric key parser 'x509' registered
[ 0.803880] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.803923] io scheduler mq-deadline registered
[ 0.803924] io scheduler kyber registered
[ 0.803950] io scheduler bfq registered
[ 0.804467] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.804530] vesafb: mode is 1024x768x32, linelength=4096, pages=0
[ 0.804531] vesafb: scrolling: redraw
[ 0.804532] vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0
[ 0.804542] vesafb: framebuffer at 0xd0000000, mapped to 0x(____ptrval____), using 3072k, total 3072k
[ 0.804626] Console: switching to colour frame buffer device 128x48
[ 0.811954] fb0: VESA VGA frame buffer device
[ 0.812000] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.812008] ACPI: Power Button [PWRB]
[ 0.812054] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.813485] ACPI: Power Button [PWRF]
[ 0.813923] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.834597] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.835002] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.835002] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[ 0.835464] usbcore: registered new interface driver usbserial_generic
[ 0.835469] usbserial: USB Serial support registered for generic
[ 0.835490] rtc_cmos 00:02: RTC can wake from S4
[ 0.835624] rtc_cmos 00:02: registered as rtc0
[ 0.835640] rtc_cmos 00:02: alarms up to one month, 242 bytes nvram, hpet irqs
[ 0.835725] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.835764] x86/pm: family 0x15 cpu detected, MSR saving is needed during suspending.
[ 0.835929] NET: Registered protocol family 10
[ 0.841490] Segment Routing with IPv6
[ 0.841509] NET: Registered protocol family 17
[ 0.841744] RAS: Correctable Errors collector initialized.
[ 0.841772] microcode: CPU0: patch_level=0x0600081c
[ 0.841778] microcode: CPU1: patch_level=0x0600081c
[ 0.841785] microcode: CPU2: patch_level=0x0600081c
[ 0.841791] microcode: CPU3: patch_level=0x0600081c
[ 0.841829] microcode: Microcode Update Driver: v2.2.
[ 0.841838] sched_clock: Marking stable (844963152, -3138227)->(879611885, -37786960)
[ 0.841976] registered taskstats version 1
[ 0.841982] Loading compiled-in X.509 certificates
[ 0.845281] Loaded X.509 cert 'Build time autogenerated kernel key: 6c1fc4794a06a007a4da1111f99d44566c225d05'
[ 0.845301] zswap: loaded using pool lzo/zbud
[ 0.850468] Key type big_key registered
[ 0.850745] PM: Magic number: 7:346:263
[ 0.850812] rtc_cmos 00:02: setting system clock to 2019-10-29T04:17:27 UTC (1572322647)
[ 0.852352] Freeing unused decrypted memory: 2040K
[ 0.852748] Freeing unused kernel image memory: 1632K
[ 0.866834] Write protecting the kernel read-only data: 18432k
[ 0.867427] Freeing unused kernel image memory: 2012K
[ 0.867487] Freeing unused kernel image memory: 144K
[ 0.876756] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.876758] Run /init as init process
[ 0.930713] Floppy drive(s): fd0 is unknown type 13 (usb?)
[ 0.938878] SCSI subsystem initialized
[ 0.939355] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.939467] xhci_hcd 0000:02:00.0: xHCI Host Controller
[ 0.939472] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 1
[ 0.939524] xhci_hcd 0000:02:00.0: hcc params 0x040050af hci version 0x100 quirks 0x0000000000080490
[ 0.939671] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.03
[ 0.939673] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.939674] usb usb1: Product: xHCI Host Controller
[ 0.939675] usb usb1: Manufacturer: Linux 5.3.7-arch1-2-ARCH xhci-hcd
[ 0.939676] usb usb1: SerialNumber: 0000:02:00.0
[ 0.939783] hub 1-0:1.0: USB hub found
[ 0.939792] hub 1-0:1.0: 2 ports detected
[ 0.939904] xhci_hcd 0000:02:00.0: xHCI Host Controller
[ 0.939906] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 2
[ 0.939909] xhci_hcd 0000:02:00.0: Host supports USB 3.0 SuperSpeed
[ 0.939932] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.939959] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.03
[ 0.939960] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.939961] usb usb2: Product: xHCI Host Controller
[ 0.939962] usb usb2: Manufacturer: Linux 5.3.7-arch1-2-ARCH xhci-hcd
[ 0.939963] usb usb2: SerialNumber: 0000:02:00.0
[ 0.940042] hub 2-0:1.0: USB hub found
[ 0.940051] hub 2-0:1.0: 2 ports detected
[ 0.940202] xhci_hcd 0000:04:00.0: xHCI Host Controller
[ 0.940206] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 3
[ 0.940251] xhci_hcd 0000:04:00.0: hcc params 0x040050af hci version 0x100 quirks 0x0000000000080490
[ 0.940376] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.03
[ 0.940378] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.940379] usb usb3: Product: xHCI Host Controller
[ 0.940380] usb usb3: Manufacturer: Linux 5.3.7-arch1-2-ARCH xhci-hcd
[ 0.940381] usb usb3: SerialNumber: 0000:04:00.0
[ 0.940481] hub 3-0:1.0: USB hub found
[ 0.940492] hub 3-0:1.0: 2 ports detected
[ 0.940502] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.940597] xhci_hcd 0000:04:00.0: xHCI Host Controller
[ 0.940600] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 4
[ 0.940603] xhci_hcd 0000:04:00.0: Host supports USB 3.0 SuperSpeed
[ 0.940619] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.940645] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.03
[ 0.940646] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.940647] usb usb4: Product: xHCI Host Controller
[ 0.940648] usb usb4: Manufacturer: Linux 5.3.7-arch1-2-ARCH xhci-hcd
[ 0.940649] usb usb4: SerialNumber: 0000:04:00.0
[ 0.940723] hub 4-0:1.0: USB hub found
[ 0.940731] hub 4-0:1.0: 2 ports detected
[ 0.941532] ehci-pci: EHCI PCI platform driver
[ 0.941685] ehci-pci 0000:00:12.2: EHCI Host Controller
[ 0.941690] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 5
[ 0.941694] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 0.941703] ehci-pci 0000:00:12.2: debug port 1
[ 0.941749] ehci-pci 0000:00:12.2: irq 17, io mem 0xfe02c000
[ 0.946313] libata version 3.00 loaded.
[ 0.950493] FDC 0 is a post-1991 82077
[ 0.953416] scsi host0: pata_atiixp
[ 0.953519] ahci 0000:00:11.0: version 3.0
[ 0.953756] ahci 0000:00:11.0: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0xf impl SATA mode
[ 0.953759] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part ccc
[ 0.954329] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
[ 0.954401] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.03
[ 0.954403] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.954405] usb usb5: Product: EHCI Host Controller
[ 0.954406] usb usb5: Manufacturer: Linux 5.3.7-arch1-2-ARCH ehci_hcd
[ 0.954408] usb usb5: SerialNumber: 0000:00:12.2
[ 0.954629] hub 5-0:1.0: USB hub found
[ 0.954650] scsi host2: ahci
[ 0.954740] hub 5-0:1.0: 6 ports detected
[ 0.955475] ehci-pci 0000:00:13.2: EHCI Host Controller
[ 0.955480] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 6
[ 0.955486] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 0.955495] ehci-pci 0000:00:13.2: debug port 1
[ 0.955541] ehci-pci 0000:00:13.2: irq 19, io mem 0xfe029000
[ 0.955552] scsi host3: ahci
[ 0.960092] scsi host4: ahci
[ 0.960990] scsi host1: pata_atiixp
[ 0.961034] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xfa00 irq 14
[ 0.961036] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xfa08 irq 15
[ 0.967663] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 0.967716] usb usb6: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.03
[ 0.967718] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.967719] usb usb6: Product: EHCI Host Controller
[ 0.967720] usb usb6: Manufacturer: Linux 5.3.7-arch1-2-ARCH ehci_hcd
[ 0.967721] usb usb6: SerialNumber: 0000:00:13.2
[ 0.967835] hub 6-0:1.0: USB hub found
[ 0.967842] hub 6-0:1.0: 6 ports detected
[ 0.969119] ohci-pci: OHCI PCI platform driver
[ 0.969289] ohci-pci 0000:00:12.0: OHCI PCI host controller
[ 0.969295] ohci-pci 0000:00:12.0: new USB bus registered, assigned bus number 7
[ 0.969338] ohci-pci 0000:00:12.0: irq 16, io mem 0xfe02e000
[ 0.971009] scsi host5: ahci
