HDMI Sound Has no Output
@bescott9944 I just think it’s a hardware thing and it may be able to be resolved with a change somewhere in one of the configurations but is it worth the headache. It’s just easier to get a card that works and done. But if I had the hardware in front of me? I might try more. :thinking: Maybe?
@bescott9944 I found some more info on hdmi. Read the section on HDMI it talks about resetting the tv and having sound playing while connecting the HDMI cable.
https://wiki.archlinux.org/index.php/Advanced_Linux_Sound_Architecture/Troubleshooting#No_output
@ricklinux Lol So now we’re not giving up yet… :slightly_smiling_face:
I will give it a look and see. I followed the instructions @joekamprad provided and not a change there either…
I will give it a look and let ya know…
LLAP
Have you looked at the following commands?
pacmd list-cards
Then look at this one which is very important because i think the problem is with one of the sinks maybe configured improperly. I’m guessing here?
pacmd list-sinks
There is also another version of this sinks command
pactl list sinks
list playback devices
aplay -l
The answer lies somewhere in the depths of the configuration. :face_with_raised_eyebrow::thinking:
Reading the Arch wiki makes my head spin. There is so much information on this.
@ricklinux
I looked that this and tried what it said, did not see anything… Lol
Here is the output of the commands…
####<---- I ran this wthout SUDO ---> -bruce
[bruce@endevor ~]$ alsactl restore
alsactl: state_lock:125: file /var/lib/alsa/asound.state lock error: File exists
alsactl: load_state:1683: Cannot open /var/lib/alsa/asound.state for reading: File exists
alsactl: sysfs_init:48: sysfs path '/sys' is invalid
Found hardware: "HDA-Intel" "Realtek ALC887-VD" "HDA:10ec0887,1458a002,00100302" "0x1458" "0xa002"
Hardware is initialized using a generic method
Found hardware: "HDA-Intel" "ATI RS690/780 HDMI" "HDA:1002791a,00791a00,00100000" "0x1002" "0x960f"
####<---- I ran this out SUDO ---> -bruce
[bruce@endevor ~]$ sudo alsactl restore
[sudo] password for bruce:
alsactl: load_state:1683: Cannot open /var/lib/alsa/asound.state for reading: No such file or directory
First there was files but no access, so I used SUDO and then went to checked the folders and there are no such files as the SUDO command shows…
What is interesting to me is that it seems to see the hardware but something is preventing it from functioning even though you can get sound out of it.
@ricklinux
Yes I know what ya mean, my head is spinning too… Lol
Yes I agree, but the question is obvious, WHERE? … :smile:
I tried all of the commands and here is all of there output… In the order that you have them…
Nothing jumped out at me but some of it is above my paygrade… Lol
pacmd list-cards
2 card(s) available.
    index: 0
	driver: <module-alsa-card.c>
	owner module: 7
	properties:
		alsa.card = "1"
		alsa.card_name = "HDA ATI HDMI"
		alsa.long_card_name = "HDA ATI HDMI at 0xfdafc000 irq 19"
		alsa.driver_name = "snd_hda_intel"
		device.bus_path = "pci-0000:01:05.1"
		sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:05.1/sound/card1"
		device.bus = "pci"
		device.vendor.id = "1002"
		device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
		device.product.id = "960f"
		device.product.name = "RS780 HDMI Audio [Radeon 3000/3100 / HD 3200/3300]"
		device.string = "1"
		device.description = "RS780 HDMI Audio [Radeon 3000/3100 / HD 3200/3300]"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	profiles:
		output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
		output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
		output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
		off: Off (priority 0, available: unknown)
	active profile: <off>
	ports:
		hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
			properties:
				device.icon_name = "video-display"
    index: 1
	owner module: 8
	properties:
		alsa.card = "0"
		alsa.card_name = "HDA ATI SB"
		alsa.long_card_name = "HDA ATI SB at 0xfe024000 irq 16"
		device.bus_path = "pci-0000:00:14.2"
		sysfs.path = "/devices/pci0000:00/0000:00:14.2/sound/card0"
		device.bus = "pci"
		device.product.id = "4383"
		device.product.name = "SBx00 Azalia (Intel HDA)"
		device.form_factor = "internal"
		device.string = "0"
		device.description = "Built-in Audio"
	profiles:
		input:analog-stereo: Analog Stereo Input (priority 65, available: no)
		output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
		output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: no)
		output:iec958-stereo: Digital Stereo (IEC958) Output (priority 5500, available: unknown)
		output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (priority 5565, available: no)
	active profile: <output:analog-stereo>
	sinks:
		alsa_output.pci-0000_00_14.2.analog-stereo/#0: Built-in Audio Analog Stereo
	sources:
		alsa_output.pci-0000_00_14.2.analog-stereo.monitor/#0: Monitor of Built-in Audio Analog Stereo
	ports:
		analog-input-front-mic: Front Microphone (priority 8500, latency offset 0 usec, available: no)
			properties:
				device.icon_name = "audio-input-microphone"
		analog-input-rear-mic: Rear Microphone (priority 8200, latency offset 0 usec, available: no)
			properties:
		analog-input-linein: Line In (priority 8100, latency offset 0 usec, available: no)
			properties:
		analog-output-lineout: Line Out (priority 9000, latency offset 0 usec, available: no)
			properties:
		analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: unknown)
			properties:
				device.icon_name = "audio-headphones"
		iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
			properties:
pacmd list-sinks
1 sink(s) available.
  * index: 0
	flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 9039
	volume: front-left: 53739 /  82% / -5.17 dB,   front-right: 53739 /  82% / -5.17 dB
	        balance 0.00
	base volume: 65536 / 100% / 0.00 dB
	volume steps: 65537
	muted: no
	current latency: 0.00 ms
	max request: 0 KiB
	max rewind: 0 KiB
	monitor source: 0
	sample spec: s16le 2ch 44100Hz
	channel map: front-left,front-right
	             Stereo
	used by: 0
	linked by: 0
	configured latency: 0.00 ms; range is 0.50 .. 1999.82 ms
	card: 1 <alsa_card.pci-0000_00_14.2>
	module: 8
	properties:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = "ALC887-VD Analog"
		alsa.id = "ALC887-VD Analog"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "0"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "front:0"
		device.buffering.buffer_size = "352768"
		device.buffering.fragment_size = "176384"
		device.access_mode = "mmap+timer"
		device.profile.name = "analog-stereo"
		device.profile.description = "Analog Stereo"
		device.description = "Built-in Audio Analog Stereo"
		alsa.mixer_name = "Realtek ALC887-VD"
		alsa.components = "HDA:10ec0887,1458a002,00100302"
	ports:
			properties:
			properties:
	active port: <analog-output-headphones>
pactl list sinks
Sink #0
	State: SUSPENDED
	Description: Built-in Audio Analog Stereo
	Driver: module-alsa-card.c
	Sample Specification: s16le 2ch 44100Hz
	Channel Map: front-left,front-right
	Owner Module: 8
	Mute: no
	Volume: front-left: 53739 /  82% / -5.17 dB,   front-right: 53739 /  82% / -5.17 dB
	        balance 0.00
	Base Volume: 65536 / 100% / 0.00 dB
	Monitor Source: alsa_output.pci-0000_00_14.2.analog-stereo.monitor
	Latency: 0 usec, configured 0 usec
	Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		device.api = "alsa"
		alsa.device = "0"
		alsa.card = "0"
		device.bus = "pci"
	Ports:
		analog-output-lineout: Line Out (priority: 9000, not available)
		analog-output-headphones: Headphones (priority: 9900)
	Active Port: analog-output-headphones
	Formats:
		pcm
aplay -l
null
    Discard all samples (playback) or generate zero samples (capture)
jack
    JACK Audio Connection Kit
pulse
    PulseAudio Sound Server
default
    Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=SB
    HDA ATI SB, ALC887-VD Analog
    Default Audio Device
front:CARD=SB,DEV=0
    Front speakers
surround21:CARD=SB,DEV=0
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=SB,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=SB,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=SB,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=SB,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=SB,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=SB,DEV=0
    HDA ATI SB, ALC887-VD Digital
    IEC958 (S/PDIF) Digital Audio Output
usbstream:CARD=SB
    HDA ATI SB
    USB Stream Output
hdmi:CARD=HDMI,DEV=0
    HDA ATI HDMI, HDMI 0
    HDMI Audio Output
usbstream:CARD=HDMI
    HDA ATI HDMI
    USB Stream Output
Well there is that… Lol
I am still doing the head dance on the desk… :smile:
I want to thank you again… I know I keep saying that, but I do thank you!
@ricklinux
I know it is baffling to me too… I have 3 of these boards, I have hooked this HDD to them, I do have Manjaro OS on a HDD on one of the same boards and there is the same issue…
But boot from a Mint 18.3, Peppermint 10, or a MX-18 live USB and the HDMI sound works after booting from the USB. I had a issue with Mint 19.2 and MX-19, but the MX forum said to go back to the 4.14 kernel and the sound started to work on the installed MX-19 OS on a HDD on the same boards.
That is why I thought it could be a kernel issue … Lol
LLAP
The active profile is OFF. The one you want is the hdmi-stereo. Somewhere in some configuration there needs to be a change. I just don’t know where as i am not an Arch hardware sound expert. The hardware is there and it is recognized and the video works it’s just the sound and you know it works in other distributions.
Have you tried the lts kernel?
@bescott9944 Give me a little time as i am going to compare these commands to mine. One thing i already notice and i said before is the pacctl list sinks shows headphones as the active port right at the bottom. Mine shows analog line out with headphones not available because i don’t have any plugged in. I’m wondering if you go back to sudo alsamixer and turn off headphones as i noticed that was active.
@bescott9944 Here is the output of my pactl list sinks
[rick@endeavour-os ~]$ pactl list sinks
Sink #0
	State: SUSPENDED
	Description: Caicos HDMI Audio [Radeon HD 6450 / 7450/8450/8490 OEM / R5 230/235/235X OEM] Digital Stereo (HDMI)
	Owner Module: 6
	Mute: no
	Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor
	Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
	Properties:
		device.api = "alsa"
		alsa.name = "HDMI 0"
		alsa.id = "HDMI 0"
		alsa.device = "3"
		alsa.card = "1"
		alsa.long_card_name = "HDA ATI HDMI at 0xf0020000 irq 35"
		device.bus_path = "pci-0000:01:00.1"
		sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
		device.bus = "pci"
		device.product.id = "aa98"
		device.product.name = "Caicos HDMI Audio [Radeon HD 6450 / 7450/8450/8490 OEM / R5 230/235/235X OEM]"
		device.string = "hdmi:1"
		device.profile.name = "hdmi-stereo"
		device.profile.description = "Digital Stereo (HDMI)"
		device.description = "Caicos HDMI Audio [Radeon HD 6450 / 7450/8450/8490 OEM / R5 230/235/235X OEM] Digital Stereo (HDMI)"
		alsa.mixer_name = "ATI R6xx HDMI"
		alsa.components = "HDA:1002aa01,00aa0100,00100200"
	Ports:
		hdmi-output-0: HDMI / DisplayPort (priority: 5900, available)
	Active Port: hdmi-output-0
	Formats:
		pcm
Sink #1
	State: SUSPENDED
	Owner Module: 7
	Mute: no
	Volume: front-left: 17311 /  26% / -34.69 dB,   front-right: 17311 /  26% / -34.69 dB
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_00_1b.0.analog-stereo.monitor
	Properties:
		device.api = "alsa"
		alsa.name = "ALC662 rev1 Analog"
		alsa.id = "ALC662 rev1 Analog"
		alsa.device = "0"
		alsa.card = "0"
		alsa.card_name = "HDA Intel"
		alsa.long_card_name = "HDA Intel at 0xf0120000 irq 34"
		device.bus_path = "pci-0000:00:1b.0"
		sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.vendor.name = "Intel Corporation"
		device.product.id = "3a6e"
		device.product.name = "82801JD/DO (ICH10 Family) HD Audio Controller"
		device.buffering.buffer_size = "352800"
		device.buffering.fragment_size = "176400"
		alsa.mixer_name = "Realtek ALC662 rev1"
		alsa.components = "HDA:10ec0662,103c3048,00100101"
	Ports:
		analog-output-lineout: Line Out (priority: 9000, available)
		analog-output-speaker: Speakers (priority: 10000, not available)
		analog-output-headphones: Headphones (priority: 9900, not available)
	Active Port: analog-output-lineout
	Formats:
		pcm
@ricklinux
On the First install I used the LTS kernel and you said that I should use the 5.3 kernel so I reinstalled the OS with the default kernel…
@ricklinux
I went to the Alsamixer and turned down the Headphone with the up & down arrow keys…
I found out that If I hit my [Tab Key] another screen pops up. Here is the output of that Alsamixer screen on EndeavourOS and the 2nd one is from my Mint 18.3 Install (this computer). The Mint has [Digital] and EndeavourOS does not…
EndeavourS
alsa-mixer-end
Mint 18.3
Mint18-alsmixer
Interesting…
LLAP
@ricklinux
That is interesting and proves that it is a settings issue somewhere in a script that is not writing the config file or osprobe is not working… Hmmmm…
Yours starts out with the HDMI and mine does not… Hmmm…
I am not a sound person either other than playing music. So you are getting this more than I am…
Thanks…
LLAP
@ricklinux
Don’t have anything plugged in… Hmmmm…
Well, you can have the latest kernels and still keep the lts kernel. You just install it and it adds another entry in grub. It will update as well as the current kernels do when there is an update. But if you already had it before and it didn’t work there isn’t any point in trying it.
im jurius does it shows error on suspended sinks in journalctl -b ?
@bescott9944 Could you run journalctl -b and post it as @ringo asks to see if there are errors with suspended sinks. I also wonder about dmesg if there is something.
Ok @ricklinux and @ringo here are the two logs… BTW if you want me to re-install the OS that is not a problem either… I will have to do this in 2 posts over posting limits…
Here is “Dmesg Part 1”…
    0.000000] Linux version 5.3.7-arch1-2-ARCH (linux@archlinux) (gcc version 9.2.0 (GCC)) #1 SMP PREEMPT @1572002934
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-linux root=UUID=e8c30685-b9f5-4765-bc05-27351ec07f99 rw quiet resume=UUID=94197eaa-2731-487d-8a56-954716d0e42d loglevel=3
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Hygon HygonGenuine
[    0.000000]   Centaur CentaurHauls
[    0.000000]   zhaoxin   Shanghai
[    0.000000] random: get_random_u32 called from bsp_init_amd+0x278/0x330 with crng_init=0
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009f7ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f800-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000cfdeffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000cfdf0000-0x00000000cfdf2fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000cfdf3000-0x00000000cfdfffff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000cfe00000-0x00000000cfefffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000020fffffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.4 present.
[    0.000000] DMI: Gigabyte Technology Co., Ltd. GA-78LMT-USB3/GA-78LMT-USB3, BIOS F4 10/19/2012
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 3816.669 MHz processor
[    0.004594] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.004596] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.013007] AGP: No AGP bridge found
[    0.013083] last_pfn = 0x210000 max_arch_pfn = 0x400000000
[    0.013087] MTRR default type: uncachable
[    0.013087] MTRR fixed ranges enabled:
[    0.013089]   00000-9FFFF write-back
[    0.013090]   A0000-BFFFF uncachable
[    0.013090]   C0000-C7FFF write-protect
[    0.013091]   C8000-FFFFF uncachable
[    0.013092] MTRR variable ranges enabled:
[    0.013093]   0 base 000000000000 mask FFFF80000000 write-back
[    0.013094]   1 base 000080000000 mask FFFFC0000000 write-back
[    0.013095]   2 base 0000C0000000 mask FFFFF0000000 write-back
[    0.013096]   3 base 0000CFE00000 mask FFFFFFE00000 uncachable
[    0.013097]   4 disabled
[    0.013097]   5 disabled
[    0.013098]   6 disabled
[    0.013098]   7 disabled
[    0.013099] TOM2: 0000000230000000 aka 8960M
[    0.013690] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.013786] total RAM covered: 3326M
[    0.014224] Found optimal setting for mtrr clean up
[    0.014225]  gran_size: 64K 	chunk_size: 4M 	num_reg: 4  	lose cover RAM: 0G
[    0.014579] e820: update [mem 0xcfe00000-0xffffffff] usable ==> reserved
[    0.014583] last_pfn = 0xcfdf0 max_arch_pfn = 0x400000000
[    0.017118] found SMP MP-table at [mem 0x000f5e40-0x000f5e4f]
[    0.028794] check: Scanning 1 areas for low memory corruption
[    0.028798] Using GB pages for direct mapping
[    0.028800] BRK [0x1f4c01000, 0x1f4c01fff] PGTABLE
[    0.028802] BRK [0x1f4c02000, 0x1f4c02fff] PGTABLE
[    0.028803] BRK [0x1f4c03000, 0x1f4c03fff] PGTABLE
[    0.028829] BRK [0x1f4c04000, 0x1f4c04fff] PGTABLE
[    0.028830] BRK [0x1f4c05000, 0x1f4c05fff] PGTABLE
[    0.028959] BRK [0x1f4c06000, 0x1f4c06fff] PGTABLE
[    0.028995] BRK [0x1f4c07000, 0x1f4c07fff] PGTABLE
[    0.029042] RAMDISK: [mem 0x36df9000-0x376f3fff]
[    0.029046] ACPI: Early table checksum verification disabled
[    0.029050] ACPI: RSDP 0x00000000000F7870 000014 (v00 GBT   )
[    0.029053] ACPI: RSDT 0x00000000CFDF3000 000040 (v01 GBT    GBTUACPI 42302E31 GBTU 01010101)
[    0.029059] ACPI: FACP 0x00000000CFDF3080 000074 (v01 GBT    GBTUACPI 42302E31 GBTU 01010101)
[    0.029063] ACPI: DSDT 0x00000000CFDF3100 00683B (v01 GBT    GBTUACPI 00001000 MSFT 03000000)
[    0.029066] ACPI: FACS 0x00000000CFDF0000 000040
[    0.029068] ACPI: MSDM 0x00000000CFDF9A00 000055 (v03 GBT    GBTUACPI 42302E31 GBTU 01010101)
[    0.029071] ACPI: HPET 0x00000000CFDF9A80 000038 (v01 GBT    GBTUACPI 42302E31 GBTU 00000098)
[    0.029073] ACPI: MCFG 0x00000000CFDF9AC0 00003C (v01 GBT    GBTUACPI 42302E31 GBTU 01010101)
[    0.029076] ACPI: TAMG 0x00000000CFDF9B00 000022 (v01 GBT    GBT   B0 5455312E BG?? 00000101)
[    0.029078] ACPI: APIC 0x00000000CFDF9940 0000BC (v01 GBT    GBTUACPI 42302E31 GBTU 01010101)
[    0.029080] ACPI: SSDT 0x00000000CFDF9BA0 000B9C (v01 AMD    POWERNOW 00000001 AMD  00000001)
[    0.029088] ACPI: Local APIC address 0xfee00000
[    0.029198] No NUMA configuration found
[    0.029199] Faking a node at [mem 0x0000000000000000-0x000000020fffffff]
[    0.029201] NODE_DATA(0) allocated [mem 0x20fffc000-0x20fffffff]
[    0.029223] Zone ranges:
[    0.029223]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.029224]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.029225]   Normal   [mem 0x0000000100000000-0x000000020fffffff]
[    0.029226]   Device   empty
[    0.029227] Movable zone start for each node
[    0.029228] Early memory node ranges
[    0.029228]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.029229]   node   0: [mem 0x0000000000100000-0x00000000cfdeffff]
[    0.029230]   node   0: [mem 0x0000000100000000-0x000000020fffffff]
[    0.029239] Zeroed struct page in unavailable ranges: 626 pages
[    0.029239] Initmem setup node 0 [mem 0x0000000000001000-0x000000020fffffff]
[    0.029241] On node 0 totalpages: 1965454
[    0.029242]   DMA zone: 64 pages used for memmap
[    0.029242]   DMA zone: 21 pages reserved
[    0.029243]   DMA zone: 3998 pages, LIFO batch:0
[    0.029289]   DMA32 zone: 13240 pages used for memmap
[    0.029290]   DMA32 zone: 847344 pages, LIFO batch:63
[    0.040010]   Normal zone: 17408 pages used for memmap
[    0.040012]   Normal zone: 1114112 pages, LIFO batch:63
[    0.053303] ACPI: PM-Timer IO Port: 0x4008
[    0.053306] ACPI: Local APIC address 0xfee00000
[    0.053312] ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1])
[    0.053313] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
[    0.053314] ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1])
[    0.053314] ACPI: LAPIC_NMI (acpi_id[0x03] dfl dfl lint[0x1])
[    0.053315] ACPI: LAPIC_NMI (acpi_id[0x04] dfl dfl lint[0x1])
[    0.053315] ACPI: LAPIC_NMI (acpi_id[0x05] dfl dfl lint[0x1])
[    0.053316] ACPI: LAPIC_NMI (acpi_id[0x06] dfl dfl lint[0x1])
[    0.053317] ACPI: LAPIC_NMI (acpi_id[0x07] dfl dfl lint[0x1])
[    0.053329] IOAPIC[0]: apic_id 2, version 33, address 0xfec00000, GSI 0-23
[    0.053330] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.053332] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.053333] ACPI: IRQ0 used by override.
[    0.053334] ACPI: IRQ9 used by override.
[    0.053335] Using ACPI (MADT) for SMP configuration information
[    0.053337] ACPI: HPET id: 0x10b9a201 base: 0xfed00000
[    0.053341] smpboot: Allowing 8 CPUs, 4 hotplug CPUs
[    0.053352] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.053354] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.053354] PM: Registered nosave memory: [mem 0x000a0000-0x000effff]
[    0.053355] PM: Registered nosave memory: [mem 0x000f0000-0x000fffff]
[    0.053356] PM: Registered nosave memory: [mem 0xcfdf0000-0xcfdf2fff]
[    0.053357] PM: Registered nosave memory: [mem 0xcfdf3000-0xcfdfffff]
[    0.053357] PM: Registered nosave memory: [mem 0xcfe00000-0xcfefffff]
[    0.053358] PM: Registered nosave memory: [mem 0xcff00000-0xdfffffff]
[    0.053358] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.053359] PM: Registered nosave memory: [mem 0xf0000000-0xfebfffff]
[    0.053359] PM: Registered nosave memory: [mem 0xfec00000-0xffffffff]
[    0.053361] [mem 0xcff00000-0xdfffffff] available for PCI devices
[    0.053362] Booting paravirtualized kernel on bare hardware
[    0.053365] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.154475] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
[    0.154887] percpu: Embedded 54 pages/cpu s184320 r8192 d28672 u262144
[    0.154893] pcpu-alloc: s184320 r8192 d28672 u262144 alloc=1*2097152
[    0.154894] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[    0.154912] Built 1 zonelists, mobility grouping on.  Total pages: 1934721
[    0.154913] Policy zone: Normal
[    0.154914] Kernel command line: BOOT_IMAGE=/vmlinuz-linux root=UUID=e8c30685-b9f5-4765-bc05-27351ec07f99 rw quiet resume=UUID=94197eaa-2731-487d-8a56-954716d0e42d loglevel=3
[    0.156343] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.157011] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.157037] mem auto-init: stack:byref_all, heap alloc:off, heap free:off
[    0.167729] AGP: Checking aperture...
[    0.176138] AGP: No AGP bridge found
[    0.176141] AGP: Node 0: aperture [bus addr 0xce0e000000-0xce0fffffff] (32MB)
[    0.176141] Aperture beyond 4GB. Ignoring.
[    0.176142] AGP: Your BIOS doesn't leave an aperture memory hole
[    0.176142] AGP: Please enable the IOMMU option in the BIOS setup
[    0.176143] AGP: This costs you 64MB of RAM
[    0.176145] AGP: Mapping aperture over RAM [mem 0xc4000000-0xc7ffffff] (65536KB)
[    0.176147] PM: Registered nosave memory: [mem 0xc4000000-0xc7ffffff]
[    0.202187] Memory: 7555352K/7861816K available (12291K kernel code, 1321K rwdata, 3952K rodata, 1632K init, 3548K bss, 306464K reserved, 0K cma-reserved)
[    0.202321] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.202333] ftrace: allocating 37808 entries in 148 pages
[    0.217451] rcu: Preemptible hierarchical RCU implementation.
[    0.217452] rcu: 	CONFIG_RCU_FANOUT set to non-default value of 32.
[    0.217452] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.217453] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[    0.217454] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.217454] 	Tasks RCU enabled.
[    0.217455] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.217456] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.219173] NR_IRQS: 20736, nr_irqs: 488, preallocated irqs: 16
[    0.219442] rcu: 	Offload RCU callbacks from CPUs: (none).
[    0.219505] spurious 8259A interrupt: IRQ7.
[    0.219518] Console: colour dummy device 80x25
[    0.219522] printk: console [tty0] enabled
[    0.219539] ACPI: Core revision 20190703
[    0.219634] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[    0.219662] APIC: Switch to symmetric I/O mode setup
[    0.220270] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.236320] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6e07b6d8f50, max_idle_ns: 881590867116 ns
[    0.236324] Calibrating delay loop (skipped), value calculated using timer frequency.. 7636.39 BogoMIPS (lpj=12722230)
[    0.236325] pid_max: default: 32768 minimum: 301
[    0.236354] LSM: Security Framework initializing
[    0.236358] Yama: becoming mindful.
[    0.236397] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.236418] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.236553] *** VALIDATE proc ***
[    0.236601] *** VALIDATE cgroup1 ***
[    0.236602] *** VALIDATE cgroup2 ***
[    0.236639] LVT offset 1 assigned for vector 0xf9
[    0.236643] Last level iTLB entries: 4KB 512, 2MB 1024, 4MB 512
[    0.236644] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 512, 1GB 0
[    0.236646] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.236647] Spectre V2 : Mitigation: Full AMD retpoline
[    0.236648] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.236649] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.236807] Freeing SMP alternatives memory: 32K
[    0.348785] smpboot: CPU0: AMD FX(tm)-4300 Quad-Core Processor (family: 0x15, model: 0x2, stepping: 0x0)
[    0.366333] Performance Events: Fam15h core perfctr, AMD PMU driver.
[    0.366337] ... version:                0
[    0.366338] ... bit width:              48
[    0.366338] ... generic registers:      6
[    0.366339] ... value mask:             0000ffffffffffff
[    0.366340] ... max period:             00007fffffffffff
[    0.366340] ... fixed-purpose events:   0
[    0.366341] ... event mask:             000000000000003f
[    0.372994] rcu: Hierarchical SRCU implementation.
[    0.396337] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.402997] smp: Bringing up secondary CPUs ...
[    0.443007] x86: Booting SMP configuration:
[    0.443008] .... node  #0, CPUs:      #1
[    0.000195] do_IRQ: 1.55 No irq handler for vector
[    0.483011]  #2
[    0.000195] do_IRQ: 2.55 No irq handler for vector
[    0.523004]  #3
[    0.000195] do_IRQ: 3.55 No irq handler for vector
[    0.525357] smp: Brought up 1 node, 4 CPUs
[    0.525357] smpboot: Max logical packages: 2
[    0.525357] smpboot: Total of 4 processors activated (30545.57 BogoMIPS)
[    0.526621] devtmpfs: initialized
[    0.526621] x86/mm: Memory block size: 128MB
[    0.527153] PM: Registering ACPI NVS region [mem 0xcfdf0000-0xcfdf2fff] (12288 bytes)
[    0.527153] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.527153] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.529662] pinctrl core: initialized pinctrl subsystem
[    0.529662] PM: RTC time: 04:17:26, date: 2019-10-29
[    0.529662] NET: Registered protocol family 16
[    0.529662] audit: initializing netlink subsys (disabled)
[    0.529679] audit: type=2000 audit(1572322646.313:1): state=initialized audit_enabled=0 res=1
[    0.532998] cpuidle: using governor ladder
[    0.533005] cpuidle: using governor menu
[    0.533027] ACPI: bus type PCI registered
[    0.533029] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.533093] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.533095] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.533107] PCI: Using configuration type 1 for base access
[    0.536538] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.536538] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.541282] fbcon: Taking over console
[    0.541282] ACPI: Added _OSI(Module Device)
[    0.541282] ACPI: Added _OSI(Processor Device)
[    0.541282] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.541282] ACPI: Added _OSI(Processor Aggregator Device)
[    0.541282] ACPI: Added _OSI(Linux-Dell-Video)
[    0.541282] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.541282] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.546364] ACPI: 2 ACPI AML tables successfully acquired and loaded
[    0.546364] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - LNKC (20190703/dspkginit-438)
[    0.546364] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - LNKD (20190703/dspkginit-438)
[    0.546364] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - LNKA (20190703/dspkginit-438)
[    0.546364] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - LNKB (20190703/dspkginit-438)
[    0.546367] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - LNKD (20190703/dspkginit-438)
[    0.549875] ACPI: Interpreter enabled
[    0.549894] ACPI: (supports S0 S3 S4 S5)
[    0.549895] ACPI: Using IOAPIC for interrupt routing
[    0.549967] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.550131] ACPI: Enabled 5 GPEs in block 00 to 1F
[    0.555588] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.555593] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[    0.555899] PCI host bridge to bus 0000:00
[    0.555901] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.555902] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.555903] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.555904] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[    0.555905] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xfebfffff window]
[    0.555907] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.555917] pci 0000:00:00.0: [1022:9600] type 00 class 0x060000
[    0.555929] pci 0000:00:00.0: [Firmware Bug]: reg 0x1c: invalid BAR (can't size)
[    0.556031] pci 0000:00:01.0: [1022:9602] type 01 class 0x060400
[    0.556139] pci 0000:00:04.0: [1022:9604] type 01 class 0x060400
[    0.556159] pci 0000:00:04.0: enabling Extended Tags
[    0.556183] pci 0000:00:04.0: PME# supported from D0 D3hot D3cold
[    0.556271] pci 0000:00:06.0: [1022:9606] type 01 class 0x060400
[    0.556290] pci 0000:00:06.0: enabling Extended Tags
[    0.556314] pci 0000:00:06.0: PME# supported from D0 D3hot D3cold
[    0.556410] pci 0000:00:07.0: [1022:9607] type 01 class 0x060400
[    0.556429] pci 0000:00:07.0: enabling Extended Tags
[    0.556453] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[    0.556552] pci 0000:00:11.0: [1002:4390] type 00 class 0x01018f
[    0.556573] pci 0000:00:11.0: reg 0x10: [io  0xff00-0xff07]
[    0.556582] pci 0000:00:11.0: reg 0x14: [io  0xfe00-0xfe03]
[    0.556590] pci 0000:00:11.0: reg 0x18: [io  0xfd00-0xfd07]
[    0.556599] pci 0000:00:11.0: reg 0x1c: [io  0xfc00-0xfc03]
[    0.556607] pci 0000:00:11.0: reg 0x20: [io  0xfb00-0xfb0f]
[    0.556616] pci 0000:00:11.0: reg 0x24: [mem 0xfe02f000-0xfe02f3ff]
[    0.556636] pci 0000:00:11.0: set SATA to AHCI mode
[    0.556744] pci 0000:00:12.0: [1002:4397] type 00 class 0x0c0310
[    0.556761] pci 0000:00:12.0: reg 0x10: [mem 0xfe02e000-0xfe02efff]
[    0.556894] pci 0000:00:12.1: [1002:4398] type 00 class 0x0c0310
Here is “Dmesg Part 2”…
[    0.556911] pci 0000:00:12.1: reg 0x10: [mem 0xfe02d000-0xfe02dfff]
[    0.557045] pci 0000:00:12.2: [1002:4396] type 00 class 0x0c0320
[    0.557065] pci 0000:00:12.2: reg 0x10: [mem 0xfe02c000-0xfe02c0ff]
[    0.557142] pci 0000:00:12.2: supports D1 D2
[    0.557143] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
[    0.557236] pci 0000:00:13.0: [1002:4397] type 00 class 0x0c0310
[    0.557253] pci 0000:00:13.0: reg 0x10: [mem 0xfe02b000-0xfe02bfff]
[    0.557385] pci 0000:00:13.1: [1002:4398] type 00 class 0x0c0310
[    0.557402] pci 0000:00:13.1: reg 0x10: [mem 0xfe02a000-0xfe02afff]
[    0.557537] pci 0000:00:13.2: [1002:4396] type 00 class 0x0c0320
[    0.557557] pci 0000:00:13.2: reg 0x10: [mem 0xfe029000-0xfe0290ff]
[    0.557634] pci 0000:00:13.2: supports D1 D2
[    0.557635] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[    0.557728] pci 0000:00:14.0: [1002:4385] type 00 class 0x0c0500
[    0.557891] pci 0000:00:14.1: [1002:439c] type 00 class 0x01018a
[    0.557909] pci 0000:00:14.1: reg 0x10: [io  0x0000-0x0007]
[    0.557918] pci 0000:00:14.1: reg 0x14: [io  0x0000-0x0003]
[    0.557926] pci 0000:00:14.1: reg 0x18: [io  0x0000-0x0007]
[    0.557934] pci 0000:00:14.1: reg 0x1c: [io  0x0000-0x0003]
[    0.557943] pci 0000:00:14.1: reg 0x20: [io  0xfa00-0xfa0f]
[    0.557961] pci 0000:00:14.1: legacy IDE quirk: reg 0x10: [io  0x01f0-0x01f7]
[    0.557962] pci 0000:00:14.1: legacy IDE quirk: reg 0x14: [io  0x03f6]
[    0.557963] pci 0000:00:14.1: legacy IDE quirk: reg 0x18: [io  0x0170-0x0177]
[    0.557964] pci 0000:00:14.1: legacy IDE quirk: reg 0x1c: [io  0x0376]
[    0.558066] pci 0000:00:14.2: [1002:4383] type 00 class 0x040300
[    0.558089] pci 0000:00:14.2: reg 0x10: [mem 0xfe024000-0xfe027fff 64bit]
[    0.558153] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[    0.558238] pci 0000:00:14.3: [1002:439d] type 00 class 0x060100
[    0.558382] pci 0000:00:14.4: [1002:4384] type 01 class 0x060401
[    0.558503] pci 0000:00:14.5: [1002:4399] type 00 class 0x0c0310
[    0.558519] pci 0000:00:14.5: reg 0x10: [mem 0xfe028000-0xfe028fff]
[    0.558654] pci 0000:00:18.0: [1022:1600] type 00 class 0x060000
[    0.558735] pci 0000:00:18.1: [1022:1601] type 00 class 0x060000
[    0.558810] pci 0000:00:18.2: [1022:1602] type 00 class 0x060000
[    0.558886] pci 0000:00:18.3: [1022:1603] type 00 class 0x060000
[    0.558965] pci 0000:00:18.4: [1022:1604] type 00 class 0x060000
[    0.559041] pci 0000:00:18.5: [1022:1605] type 00 class 0x060000
[    0.559133] pci_bus 0000:01: extended config space not accessible
[    0.559154] pci 0000:01:05.0: [1002:9616] type 00 class 0x030000
[    0.559161] pci 0000:01:05.0: reg 0x10: [mem 0xd0000000-0xdfffffff pref]
[    0.559165] pci 0000:01:05.0: reg 0x14: [io  0xce00-0xceff]
[    0.559169] pci 0000:01:05.0: reg 0x18: [mem 0xfdae0000-0xfdaeffff]
[    0.559177] pci 0000:01:05.0: reg 0x24: [mem 0xfd900000-0xfd9fffff]
[    0.559198] pci 0000:01:05.0: supports D1 D2
[    0.559226] pci 0000:01:05.1: [1002:960f] type 00 class 0x040300
[    0.559233] pci 0000:01:05.1: reg 0x10: [mem 0xfdafc000-0xfdafffff]
[    0.559264] pci 0000:01:05.1: supports D1 D2
[    0.559318] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.559321] pci 0000:00:01.0:   bridge window [io  0xc000-0xcfff]
[    0.559323] pci 0000:00:01.0:   bridge window [mem 0xfd900000-0xfdafffff]
[    0.559325] pci 0000:00:01.0:   bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.559359] pci 0000:02:00.0: [1b6f:7023] type 00 class 0x0c0330
[    0.559380] pci 0000:02:00.0: reg 0x10: [mem 0xfd6f8000-0xfd6fffff 64bit]
[    0.559416] pci 0000:02:00.0: enabling Extended Tags
[    0.559459] pci 0000:02:00.0: supports D1 D2
[    0.559460] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.559524] pci 0000:00:04.0: PCI bridge to [bus 02]
[    0.559527] pci 0000:00:04.0:   bridge window [io  0xb000-0xbfff]
[    0.559528] pci 0000:00:04.0:   bridge window [mem 0xfd600000-0xfd6fffff]
[    0.559531] pci 0000:00:04.0:   bridge window [mem 0xfdf00000-0xfdffffff 64bit pref]
[    0.559567] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[    0.559587] pci 0000:03:00.0: reg 0x10: [io  0xee00-0xeeff]
[    0.559606] pci 0000:03:00.0: reg 0x18: [mem 0xfddff000-0xfddfffff 64bit pref]
[    0.559618] pci 0000:03:00.0: reg 0x20: [mem 0xfddf8000-0xfddfbfff 64bit pref]
[    0.559693] pci 0000:03:00.0: supports D1 D2
[    0.559694] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.559778] pci 0000:00:06.0: PCI bridge to [bus 03]
[    0.559780] pci 0000:00:06.0:   bridge window [io  0xe000-0xefff]
[    0.559782] pci 0000:00:06.0:   bridge window [mem 0xfde00000-0xfdefffff]
[    0.559785] pci 0000:00:06.0:   bridge window [mem 0xfdd00000-0xfddfffff 64bit pref]
[    0.559818] pci 0000:04:00.0: [1b6f:7023] type 00 class 0x0c0330
[    0.559839] pci 0000:04:00.0: reg 0x10: [mem 0xfdcf8000-0xfdcfffff 64bit]
[    0.559876] pci 0000:04:00.0: enabling Extended Tags
[    0.559918] pci 0000:04:00.0: supports D1 D2
[    0.559919] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.559982] pci 0000:00:07.0: PCI bridge to [bus 04]
[    0.559984] pci 0000:00:07.0:   bridge window [io  0xd000-0xdfff]
[    0.559986] pci 0000:00:07.0:   bridge window [mem 0xfdc00000-0xfdcfffff]
[    0.559988] pci 0000:00:07.0:   bridge window [mem 0xfdb00000-0xfdbfffff 64bit pref]
[    0.559998] pci_bus 0000:05: extended config space not accessible
[    0.560057] pci 0000:00:14.4: PCI bridge to [bus 05] (subtractive decode)
[    0.560060] pci 0000:00:14.4:   bridge window [io  0xa000-0xafff]
[    0.560063] pci 0000:00:14.4:   bridge window [mem 0xfd800000-0xfd8fffff]
[    0.560066] pci 0000:00:14.4:   bridge window [mem 0xfd700000-0xfd7fffff pref]
[    0.560068] pci 0000:00:14.4:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
[    0.560069] pci 0000:00:14.4:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.560070] pci 0000:00:14.4:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.560071] pci 0000:00:14.4:   bridge window [mem 0x000c0000-0x000dffff window] (subtractive decode)
[    0.560072] pci 0000:00:14.4:   bridge window [mem 0xd0000000-0xfebfffff window] (subtractive decode)
[    0.560361] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 11) *0, disabled.
[    0.560419] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 11) *0, disabled.
[    0.560476] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 11) *0, disabled.
[    0.560531] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11) *0, disabled.
[    0.560587] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11) *0, disabled.
[    0.560642] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11) *0, disabled.
[    0.560698] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 6 7 10 11) *0, disabled.
[    0.560753] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 6 7 10 11) *0, disabled.
[    0.563068] pci 0000:01:05.0: vgaarb: setting as boot VGA device
[    0.563068] pci 0000:01:05.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.563068] pci 0000:01:05.0: vgaarb: bridge control possible
[    0.563068] vgaarb: loaded
[    0.563156] ACPI: bus type USB registered
[    0.563169] usbcore: registered new interface driver usbfs
[    0.563175] usbcore: registered new interface driver hub
[    0.563192] usbcore: registered new device driver usb
[    0.563211] pps_core: LinuxPPS API ver. 1 registered
[    0.563212] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.563214] PTP clock support registered
[    0.563221] EDAC MC: Ver: 3.0.0
[    0.563301] PCI: Using ACPI for IRQ routing
[    0.572659] PCI: pci_cache_line_size set to 64 bytes
[    0.572713] e820: reserve RAM buffer [mem 0x0009f800-0x0009ffff]
[    0.572714] e820: reserve RAM buffer [mem 0xcfdf0000-0xcfffffff]
[    0.572821] NetLabel: Initializing
[    0.572821] NetLabel:  domain hash size = 128
[    0.572822] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.572833] NetLabel:  unlabeled traffic allowed by default
[    0.572838] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[    0.572838] hpet0: 4 comparators, 32-bit 14.318180 MHz counter
[    0.574077] clocksource: Switched to clocksource tsc-early
[    0.586099] VFS: Disk quotas dquot_6.6.0
[    0.586115] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.586143] *** VALIDATE hugetlbfs ***
[    0.586181] pnp: PnP ACPI init
[    0.586303] system 00:00: [io  0x04d0-0x04d1] has been reserved
[    0.586305] system 00:00: [io  0x0220-0x0225] has been reserved
[    0.586306] system 00:00: [io  0x0290-0x0294] has been reserved
[    0.586311] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.586658] system 00:01: [io  0x4100-0x411f] has been reserved
[    0.586659] system 00:01: [io  0x0228-0x022f] has been reserved
[    0.586660] system 00:01: [io  0x040b] has been reserved
[    0.586662] system 00:01: [io  0x04d6] has been reserved
[    0.586663] system 00:01: [io  0x0c00-0x0c01] has been reserved
[    0.586664] system 00:01: [io  0x0c14] has been reserved
[    0.586665] system 00:01: [io  0x0c50-0x0c52] has been reserved
[    0.586666] system 00:01: [io  0x0c6c-0x0c6d] has been reserved
[    0.586668] system 00:01: [io  0x0c6f] has been reserved
[    0.586669] system 00:01: [io  0x0cd0-0x0cd1] has been reserved
[    0.586670] system 00:01: [io  0x0cd2-0x0cd3] has been reserved
[    0.586671] system 00:01: [io  0x0cd4-0x0cdf] has been reserved
[    0.586672] system 00:01: [io  0x4000-0x40fe] has been reserved
[    0.586674] system 00:01: [io  0x4210-0x4217] has been reserved
[    0.586675] system 00:01: [io  0x0b00-0x0b0f] has been reserved
[    0.586676] system 00:01: [io  0x0b10-0x0b1f] has been reserved
[    0.586677] system 00:01: [io  0x0b20-0x0b3f] has been reserved
[    0.586679] system 00:01: [mem 0x00000000-0x00000fff window] could not be reserved
[    0.586680] system 00:01: [mem 0xfee00400-0xfee00fff window] has been reserved
[    0.586684] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.586869] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.587044] pnp 00:03: [dma 2]
[    0.587069] pnp 00:03: Plug and Play ACPI device, IDs PNP0700 (active)
[    0.587312] pnp 00:04: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.587569] pnp 00:05: Plug and Play ACPI device, IDs PNP0400 (active)
[    0.587743] system 00:06: [mem 0xe0000000-0xefffffff] has been reserved
[    0.587747] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.587975] system 00:07: [mem 0x000cec00-0x000cffff] has been reserved
[    0.587977] system 00:07: [mem 0x000f0000-0x000f7fff] could not be reserved
[    0.587978] system 00:07: [mem 0x000f8000-0x000fbfff] could not be reserved
[    0.587980] system 00:07: [mem 0x000fc000-0x000fffff] could not be reserved
[    0.587981] system 00:07: [mem 0xcfdf0000-0xcfdfffff] could not be reserved
[    0.587982] system 00:07: [mem 0xffff0000-0xffffffff] has been reserved
[    0.587983] system 00:07: [mem 0x00000000-0x0009ffff] could not be reserved
[    0.587985] system 00:07: [mem 0x00100000-0xcfdeffff] could not be reserved
[    0.587986] system 00:07: [mem 0xcfe00000-0xcfefffff] has been reserved
[    0.587987] system 00:07: [mem 0xcff00000-0xcfffffff] could not be reserved
[    0.587988] system 00:07: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.587990] system 00:07: [mem 0xfee00000-0xfee00fff] could not be reserved
[    0.587991] system 00:07: [mem 0xfff80000-0xfffeffff] has been reserved
[    0.587994] system 00:07: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.588014] pnp: PnP ACPI: found 8 devices
[    0.589609] thermal_sys: Registered thermal governor 'fair_share'
[    0.589610] thermal_sys: Registered thermal governor 'bang_bang'
[    0.589610] thermal_sys: Registered thermal governor 'step_wise'
[    0.589611] thermal_sys: Registered thermal governor 'user_space'
[    0.589612] thermal_sys: Registered thermal governor 'power_allocator'
[    0.594151] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.594187] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.594190] pci 0000:00:01.0:   bridge window [io  0xc000-0xcfff]
[    0.594192] pci 0000:00:01.0:   bridge window [mem 0xfd900000-0xfdafffff]
[    0.594194] pci 0000:00:01.0:   bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.594197] pci 0000:00:04.0: PCI bridge to [bus 02]
[    0.594199] pci 0000:00:04.0:   bridge window [io  0xb000-0xbfff]
[    0.594201] pci 0000:00:04.0:   bridge window [mem 0xfd600000-0xfd6fffff]
[    0.594202] pci 0000:00:04.0:   bridge window [mem 0xfdf00000-0xfdffffff 64bit pref]
[    0.594205] pci 0000:00:06.0: PCI bridge to [bus 03]
[    0.594207] pci 0000:00:06.0:   bridge window [io  0xe000-0xefff]
[    0.594209] pci 0000:00:06.0:   bridge window [mem 0xfde00000-0xfdefffff]
[    0.594210] pci 0000:00:06.0:   bridge window [mem 0xfdd00000-0xfddfffff 64bit pref]
[    0.594213] pci 0000:00:07.0: PCI bridge to [bus 04]
[    0.594214] pci 0000:00:07.0:   bridge window [io  0xd000-0xdfff]
[    0.594216] pci 0000:00:07.0:   bridge window [mem 0xfdc00000-0xfdcfffff]
[    0.594218] pci 0000:00:07.0:   bridge window [mem 0xfdb00000-0xfdbfffff 64bit pref]
[    0.594221] pci 0000:00:14.4: PCI bridge to [bus 05]
[    0.594223] pci 0000:00:14.4:   bridge window [io  0xa000-0xafff]
[    0.594227] pci 0000:00:14.4:   bridge window [mem 0xfd800000-0xfd8fffff]
[    0.594231] pci 0000:00:14.4:   bridge window [mem 0xfd700000-0xfd7fffff pref]
[    0.594237] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.594238] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.594239] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.594240] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000dffff window]
[    0.594241] pci_bus 0000:00: resource 8 [mem 0xd0000000-0xfebfffff window]
[    0.594243] pci_bus 0000:01: resource 0 [io  0xc000-0xcfff]
[    0.594244] pci_bus 0000:01: resource 1 [mem 0xfd900000-0xfdafffff]
[    0.594245] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.594246] pci_bus 0000:02: resource 0 [io  0xb000-0xbfff]
[    0.594247] pci_bus 0000:02: resource 1 [mem 0xfd600000-0xfd6fffff]
[    0.594248] pci_bus 0000:02: resource 2 [mem 0xfdf00000-0xfdffffff 64bit pref]
[    0.594249] pci_bus 0000:03: resource 0 [io  0xe000-0xefff]
[    0.594250] pci_bus 0000:03: resource 1 [mem 0xfde00000-0xfdefffff]
[    0.594251] pci_bus 0000:03: resource 2 [mem 0xfdd00000-0xfddfffff 64bit pref]
[    0.594252] pci_bus 0000:04: resource 0 [io  0xd000-0xdfff]
[    0.594253] pci_bus 0000:04: resource 1 [mem 0xfdc00000-0xfdcfffff]
[    0.594254] pci_bus 0000:04: resource 2 [mem 0xfdb00000-0xfdbfffff 64bit pref]
[    0.594255] pci_bus 0000:05: resource 0 [io  0xa000-0xafff]
[    0.594256] pci_bus 0000:05: resource 1 [mem 0xfd800000-0xfd8fffff]
[    0.594257] pci_bus 0000:05: resource 2 [mem 0xfd700000-0xfd7fffff pref]
[    0.594258] pci_bus 0000:05: resource 4 [io  0x0000-0x0cf7 window]
[    0.594259] pci_bus 0000:05: resource 5 [io  0x0d00-0xffff window]
[    0.594260] pci_bus 0000:05: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.594261] pci_bus 0000:05: resource 7 [mem 0x000c0000-0x000dffff window]
[    0.594262] pci_bus 0000:05: resource 8 [mem 0xd0000000-0xfebfffff window]
