Hello , just did a fresh install . Almost everything worked perfect . The problem I encountered is I have no internet wired connection .
WiFi is working great , but wired connection can’t connect .
I tried to connect while live , but still same . WIFI works great but no wired connection .
I was going to re-install , but don’t think it would make a difference as it happens while being live also .
I’m running KDE latest , how can I resolve this problem ?
Start by posting
inxi -Fxxxz
But i’ll assume it’s classics:
Looking into it now , thanks . I’ll report back shortly .
After reading the link , I tried these 2 commands .
Two things to try:
install r8168 (sudo pacman -S r8168) and reboot, does ethernet work?
uninstall r8168 (sudo pacman -R r8168) and reboot, does ethernet work?
Still not connecting . Here is the ( ```
inxi -Fxxxz
And the Network section results :
Network: Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel port: 1000
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: CLEVO/KAPOK
driver: r8169 v: kernel port: 5000 bus-ID: 28:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp40s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
After the wired connection deactivates , it give me this info :
IP configuration was unavailable
Not sure if it’s important or not .
I installed driver ```
r8168
here is the info after reboot :
driver: r8168 v: 8.048.03-NAPI port: 5000 bus-ID: 28:00.0 chip-ID: 10ec:8168
class-ID: 0200
Just to check off some boxes… have you tried that same internet cable with another device to ensure it’s working? Have you tried another socket on the router?
Will double check now .
Personally I use the aur/r8168-dkms
package. In /etc/modules-load.d/r8168.conf
r8168
Works. Just as a data point.
Well , I just went through the basics . Although nothing changed but a fresh install , Garbage Modem was at fault . It is now working ! Changing modem fixed it . Reset faulty modem a couple times and that one now working .
I think I was confused because WIFI was working and didn’t suspect modem itself . I should have known better as Endeavour has always been perfect … SORRY , My bad !
Yes I’m embarrassed , and feel a little dumb at the moment .
Besides it working again , it was good to refresh my memory on the basics .
Thank You ! for the help …
Happens to the best of us
so many pieces of hardware and software have to all be just perfect, sometimes it can boggle the mind (well, mine, at least)
Endeavour has always been perfect for me . Just hardware problem . I used to be a distro hopper looking for the Holy Grail . I found it in EndeavourOS . Now I’m cured !
