Clean install of EndeavourOS and having an issue.
I can connect to wifi with no problem.
But it isn’t connecting to my LAN connection even though it sees it. By that, I mean that if I plug in the LAN cable it shows in the Network Manager but as disconnected. I found this post in the forums…
https://forum.endeavouros.com/t/fresh-install-no-wired-connection/15191
and the command ```
sudo pacman -S r8168
and subsequent reboot does "fix" the issue. But 1) It will disconnect randomly requiring the same process, cmd and reboot, to get it working again. Additionally, if I do a complete shutdown and restart the setting doesn't seem to be preserved.
What am I missing?
Thanks
