Extreme graphical artifacts after exiting sleep with an Nvidia 3060ti
Immediately after? No. But the last wake-from-sleep had this issue. About three or four hours ago.
Ah ok. It’ll need to be immediately after. The log shared only accounted for the last 3 minutes.
OK. I’ll keep that in mind and do that when it happens again and post back here. Thanks.
I have the same artifact issue after resume from suspend with a standard Nvidia RTX 3060 (not TI). Posting here so I can track progress/solutions.
Like OP I have configured the nvidia suspend/resume settings per the wiki (including PreserveVideoMemoryAllocations set to 1 and TemporaryFilePath set to /var/tmp)and have enabled the nvidia suspend resume systemd services. I am able to reproduce on nvidia-open on the standard linux kernel and nvidia-open-dkms on the linux-lts kernel. journalctl shows nothing out of the ordinary on resume.
I run i3 on x11 (not KDE as other person mentioned).
Like other people have mentioned: the issue is intermittent. Sometimes I resume from suspend and there are no graphical artifacts, but most of the time the artifacts are present on resume. Everything seems to point to some form of suspend/resume memory issue. I believe the issue started around the time that arch switched to nvidia-open but I am not sure as the issue is frustratingly intermittent.
I’ve only been able to reproduce the issue twice on the DKMS drivers. It’s been a bit over a week since it’s happened, and I havent updated in that time.
Downgrading drivers to the 580xx version may have solved it for my hardware and wm (standard RTX 3060 running x11 and i3). Yesterday I tried linux-lts and nvidia-open-dkms but the issue persisted so today I decided to downgrade drivers to the pre-ā€openā€ version. I kept linux-lts and installed the nvidia-580xx-dkms driver and nvidia-580xx-settings packages. I doubt having the LTS kernel makes a difference as the dkms driver should work fine with both. I have done a few suspend/resume tests and it appears to be working without any graphical artifacts… The issue is frustratingly intermittent so if it happens again I will update this thread.
Just happened again…
ā”€āÆ journalctl -b -0 | tail -n 50
Feb 25 10:42:01 endeavourmsi NetworkManager[990]: <info>  [1772037721.1064] dhcp4 (enp4s0): state changed new lease, address=10.0.0.202
Feb 25 10:42:01 endeavourmsi avahi-daemon[888]: Joining mDNS multicast group on interface enp4s0.IPv4 with address 10.0.0.202.
Feb 25 10:42:01 endeavourmsi avahi-daemon[888]: New relevant interface enp4s0.IPv4 for mDNS.
Feb 25 10:42:01 endeavourmsi NetworkManager[990]: <info>  [1772037721.1086] policy: set 'Wired connection 1' (enp4s0) as default for IPv4 routing and DNS
Feb 25 10:42:01 endeavourmsi mullvad-daemon[1012]: [mullvad_daemon::api][INFO] Detecting changes to offline state - Online(Ipv4AndIpv6)
Feb 25 10:42:01 endeavourmsi mullvad-daemon[1012]: [mullvad_api::availability][DEBUG] Resuming API requests due to coming online
Feb 25 10:42:01 endeavourmsi avahi-daemon[888]: Registering new address record for 10.0.0.202 on enp4s0.IPv4.
Feb 25 10:42:01 endeavourmsi NetworkManager[990]: <info>  [1772037721.1277] device (enp4s0): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
Feb 25 10:42:01 endeavourmsi systemd[1]: Starting Network Manager Script Dispatcher Service...
Feb 25 10:42:01 endeavourmsi systemd[1]: Started Network Manager Script Dispatcher Service.
Feb 25 10:42:01 endeavourmsi NetworkManager[990]: <info>  [1772037721.1906] device (enp4s0): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
Feb 25 10:42:01 endeavourmsi NetworkManager[990]: <info>  [1772037721.1910] device (enp4s0): state change: secondaries -> activated (reason 'none', managed-type: 'full')
Feb 25 10:42:01 endeavourmsi NetworkManager[990]: <info>  [1772037721.1919] manager: NetworkManager state is now CONNECTED_SITE
Feb 25 10:42:01 endeavourmsi NetworkManager[990]: <info>  [1772037721.1926] device (enp4s0): Activation: successful, device activated.
Feb 25 10:42:01 endeavourmsi avahi-daemon[888]: Leaving mDNS multicast group on interface enp4s0.IPv6 with address fe80::cd16:629d:5fca:594b.
Feb 25 10:42:01 endeavourmsi avahi-daemon[888]: Joining mDNS multicast group on interface enp4s0.IPv6 with address 2601:243:e080:2110:255b:1bf3:ec7c:6ae8.
Feb 25 10:42:01 endeavourmsi avahi-daemon[888]: Registering new address record for 2601:243:e080:2110:255b:1bf3:ec7c:6ae8 on enp4s0.*.
Feb 25 10:42:01 endeavourmsi avahi-daemon[888]: Withdrawing address record for fe80::cd16:629d:5fca:594b on enp4s0.
Feb 25 10:42:01 endeavourmsi NetworkManager[990]: <info>  [1772037721.4833] manager: NetworkManager state is now CONNECTED_GLOBAL
Feb 25 10:42:01 endeavourmsi plasmashell[16098]: Tray icon changed, title: MEGAsync name: MEGAsync
                                                 SHA1: 7cf18b8902709a198e9a47097c1c4e6f049983ef
                                                 Replacement:
Feb 25 10:42:01 endeavourmsi mullvad-daemon[1012]: [mullvad_daemon::management_interface][DEBUG] get_account_data
Feb 25 10:42:02 endeavourmsi avahi-daemon[888]: Registering new address record for 2601:243:e080:2110::cbc2 on enp4s0.*.
Feb 25 10:42:02 endeavourmsi systemd[1208]: Started LibreWolf - Web Browser.
Feb 25 10:42:02 endeavourmsi systemd[1]: Starting Time & Date Service...
Feb 25 10:42:02 endeavourmsi systemd[1]: Started Time & Date Service.
Feb 25 10:42:03 endeavourmsi rtkit-daemon[1131]: Successfully made thread 63938 of process 63729 owned by '1000' RT at priority 10.
Feb 25 10:42:04 endeavourmsi rtkit-daemon[1131]: Successfully made thread 64073 of process 63913 owned by '1000' RT at priority 10.
Feb 25 10:42:11 endeavourmsi systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Feb 25 10:42:23 endeavourmsi kdeconnectd[16275]: Cannot find Bluez 5 adapter for device search false
Feb 25 10:42:26 endeavourmsi rtkit-daemon[1131]: Successfully made thread 64218 of process 63729 owned by '1000' RT at priority 10.
Feb 25 10:42:30 endeavourmsi systemd[1208]: Started Dolphin - File Manager.
Feb 25 10:42:31 endeavourmsi dolphin[64232]: Could not load default global viewproperties
Feb 25 10:42:31 endeavourmsi plasmashell[16098]: Tray icon changed, title: MEGAsync name: MEGAsync
                                                 SHA1: 71024d39d48b475ba8d020e78eb4a2f8ddecc097
                                                 Replacement:
Feb 25 10:42:32 endeavourmsi systemd[1]: systemd-timedated.service: Deactivated successfully.
Feb 25 10:42:33 endeavourmsi systemd[1208]: app-org.kde.dolphin@1ac18939351242d0ad9a2cebfed719a4.service: Consumed 1.740s CPU time over 2.473s wall clock time, 177.1M memory peak.
Feb 25 10:42:35 endeavourmsi plasmashell[16098]: qrc:/qt/qml/plasma/applet/org/kde/plasma/taskmanager/ToolTipDelegate.qml:63: TypeError: Cannot read property 'containsMouse' of null
Feb 25 10:42:35 endeavourmsi systemd[1208]: Started kitty - Terminal emulator.
Feb 25 10:42:35 endeavourmsi kitty[64302]: [0.045] Could not find included config file: /home/wombat/.config/kitty/current-theme.conf, ignoring
Feb 25 10:42:35 endeavourmsi systemd[1208]: Started kitty child process: 64306 launched by: 64302.
Feb 25 10:42:35 endeavourmsi fastfetch[64321]: Starting libddcutil. library built Not set at Not set. stdout_stderr_redirected=false
Feb 25 10:42:35 endeavourmsi libddcutil[64321]: Initializing libddcutil.  ddcutil version: 2.2.5, shared library: /usr/lib/libddcutil.so.5.4.1
Feb 25 10:42:35 endeavourmsi libddcutil[64321]:                           library built Not set at Not set. stdout_stderr_redirected=false
Feb 25 10:42:36 endeavourmsi libddcutil[64321]: Library initialization complete.
Feb 25 10:42:36 endeavourmsi libddcutil[64321]: libddcutil terminating.
Feb 25 10:42:36 endeavourmsi kitty[64302]: [1.347] [PARSE ERROR] Unknown terminfo property: query-os-name
ā”€āÆ
Unfortunately, it looks like my suggestion to retrieve the last 50 entries might have been too conservative, and I can’t spot anything there that might relate to the display issue. If there was something, it might have been logged earlier.
What you grabbed there does represent about 35 seconds worth of log. Would you say you retrieved it within 35 seconds of the system coming out of sleep?
You can always adjust the amount of log you retrieve by changing -n 50 to a higher number. I was conservative with it, because I’m mindful of not asking people to divulge full session history etc.
@Bink, happened again. This time I used journalctl -b -0 | tail -n 150. I opened Kitty and ran that within 15 seconds at most.
ā”€āÆ journalctl -b -0 | tail -n 150
Feb 27 10:30:31 endeavourmsi plasmashell[1435]: file:///home/wombat/.local/share/plasma/plasmoids/KdeControlStation/contents/ui/components/Volume.qml:48: TypeError: Cannot read property 'volume' of null
Feb 27 10:30:31 endeavourmsi mullvad-vpn[1643]: [2026-02-27 10:30:31.964][warning] Failed to fetch account data. Retrying in 8000 ms
Feb 27 10:30:31 endeavourmsi mullvad-vpn[1643]: [2026-02-27 10:30:31.964][warning] Failed to update device info: 14 UNAVAILABLE: Cannot reach the API
Feb 27 10:30:31 endeavourmsi mullvad-daemon[992]: [mullvad_daemon::management_interface][DEBUG] get_current_api_access_method
Feb 27 10:30:31 endeavourmsi mullvad-daemon[992]: [mullvad_daemon::management_interface][DEBUG] get_relay_locations
Feb 27 10:30:31 endeavourmsi plasmashell[1435]: No object for name "alsa_output.pci-0000_00_1f.3.analog-stereo"
Feb 27 10:30:31 endeavourmsi plasmashell[1435]: No object for name "alsa_output.pci-0000_00_1f.3.analog-stereo.monitor"
Feb 27 10:30:31 endeavourmsi mullvad-daemon[992]: [mullvad_daemon::management_interface][DEBUG] get_current_version
Feb 27 10:30:32 endeavourmsi mullvad-daemon[992]: [mullvad_daemon::management_interface][DEBUG] get_version_info
Feb 27 10:30:32 endeavourmsi mullvad-daemon[992]: [mullvad_daemon::management_interface][DEBUG] get_current_version
Feb 27 10:30:32 endeavourmsi mullvad-daemon[992]: [mullvad_daemon::version::check][ERROR] Failed to fetch version info: Failed to check the latest app version
Feb 27 10:30:32 endeavourmsi plasmashell[1435]: Tray icon changed, title: MEGAsync name: MEGAsync
                                                SHA1: 64b74e2bfde936ea429842b2a0190481186c0a06
                                                Replacement:
Feb 27 10:30:32 endeavourmsi org_kde_powerdevil[1469]: [ 53051] Emitting DDCA_Display_Status_Event[36392.481:  DDCA_EVENT_DISPLAY_CONNECTED, card1-DP-1, dref: DDCA_Display_Ref[8], io_path:/dev/i2c-3, ddc working: true]
Feb 27 10:30:32 endeavourmsi org_kde_powerdevil[1469]: [ 53051] Starting 1 callback threads
Feb 27 10:30:32 endeavourmsi org_kde_powerdevil[1469]: [ 53051] libddcutil callback thread 0x7fc714015b10 started
Feb 27 10:30:32 endeavourmsi org_kde_powerdevil[1469]: [ 53051] Started 1 event callback thread(s)
Feb 27 10:30:32 endeavourmsi org_kde_powerdevil[1469]: [ 74536] Invoking callback function 0x7fc737de77f0 for event DDCA_Display_Status_Event[36392.481:  DDCA_EVENT_DISPLAY_CONNECTED, card1-DP-1, dref: DDCA_Display_Ref[8], io_path:/dev/i2c-3, ddc working: true] in this thread [ 74536]
Feb 27 10:30:32 endeavourmsi org_kde_powerdevil[1469]: [ 74536] Callback function 0x7fc737de77f0 for event DDCA_Display_Status_Event[36392.481:  DDCA_EVENT_DISPLAY_CONNECTED, card1-DP-1, dref: DDCA_Display_Ref[8], io_path:/dev/i2c-3, ddc working: true] complete
Feb 27 10:30:32 endeavourmsi org_kde_powerdevil[1469]: [  1469] Quiescing libddcutil API...
Feb 27 10:30:32 endeavourmsi org_kde_powerdevil[1469]: [  1469] Quiesce libddcutil API complete
Feb 27 10:30:32 endeavourmsi org_kde_powerdevil[1469]: [  1469] Display redetection starting.
Feb 27 10:30:32 endeavourmsi org_kde_powerdevil[1469]: [ 53050] recheck thread terminating because watch thread terminated
Feb 27 10:30:33 endeavourmsi org_kde_powerdevil[1469]: [  1469] Watch thread terminated.
Feb 27 10:30:33 endeavourmsi kernel: alx 0000:04:00.0 enp4s0: NIC Up: 1 Gbps Full
Feb 27 10:30:33 endeavourmsi mullvad-daemon[992]: [netlink_packet_route::link::buffer_tool][WARN] Specified IFLA_INET6_CONF NLA attribute holds more(most likely new kernel) data which is unknown to netlink-packet-route crate, expecting 236, got 240
Feb 27 10:30:33 endeavourmsi NetworkManager[970]: <info>  [1772209833.6676] device (enp4s0): carrier: link connected
Feb 27 10:30:33 endeavourmsi NetworkManager[970]: <info>  [1772209833.6677] device (enp4s0): state change: unavailable -> disconnected (reason 'carrier-changed', managed-type: 'full')
Feb 27 10:30:33 endeavourmsi NetworkManager[970]: <info>  [1772209833.6682] policy: auto-activating connection 'Wired connection 1' (b85d3b56-9e20-3285-80a0-d1d6829dbb4b)
Feb 27 10:30:33 endeavourmsi NetworkManager[970]: <info>  [1772209833.6684] device (enp4s0): Activation: starting connection 'Wired connection 1' (b85d3b56-9e20-3285-80a0-d1d6829dbb4b)
Feb 27 10:30:33 endeavourmsi NetworkManager[970]: <info>  [1772209833.6685] device (enp4s0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
Feb 27 10:30:33 endeavourmsi NetworkManager[970]: <info>  [1772209833.6686] manager: NetworkManager state is now CONNECTING
Feb 27 10:30:33 endeavourmsi NetworkManager[970]: <info>  [1772209833.6687] device (enp4s0): state change: prepare -> config (reason 'none', managed-type: 'full')
Feb 27 10:30:33 endeavourmsi NetworkManager[970]: <info>  [1772209833.6785] device (enp4s0): state change: config -> ip-config (reason 'none', managed-type: 'full')
Feb 27 10:30:33 endeavourmsi NetworkManager[970]: <info>  [1772209833.6788] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds)
Feb 27 10:30:34 endeavourmsi org_kde_powerdevil[1469]: [  1469] Watching for display connection changes, resolved watch mode = Watch_Mode_Udev, poll loop interval = 500 millisec
Feb 27 10:30:34 endeavourmsi org_kde_powerdevil[1469]: [  1469]                                          extra_stabilization_millisec: 0,  stabilization_poll_millisec: 100
Feb 27 10:30:34 endeavourmsi org_kde_powerdevil[1469]: [  1469] libddcutil recheck thread 0x55ab73a62690 started
Feb 27 10:30:34 endeavourmsi org_kde_powerdevil[1469]: [  1469] libddcutil watch thread 0x55ab73b30050 started
Feb 27 10:30:34 endeavourmsi org_kde_powerdevil[1469]: [  1469] Display redetection finished.
Feb 27 10:30:34 endeavourmsi org_kde_powerdevil[1469]: [  1469] Unquiescing libddcutil API...
Feb 27 10:30:34 endeavourmsi org_kde_powerdevil[1469]: [ 74558] (dw_recheck_displays_func) Recheck interval: Sleeping for 200 milliseconds
Feb 27 10:30:34 endeavourmsi kernel: alx 0000:04:00.0 enp4s0: Link Down
Feb 27 10:30:34 endeavourmsi mullvad-daemon[992]: [netlink_packet_route::link::buffer_tool][WARN] Specified IFLA_INET6_CONF NLA attribute holds more(most likely new kernel) data which is unknown to netlink-packet-route crate, expecting 236, got 240
Feb 27 10:30:35 endeavourmsi avahi-daemon[886]: Joining mDNS multicast group on interface enp4s0.IPv6 with address fe80::cd16:629d:5fca:594b.
Feb 27 10:30:35 endeavourmsi avahi-daemon[886]: New relevant interface enp4s0.IPv6 for mDNS.
Feb 27 10:30:35 endeavourmsi avahi-daemon[886]: Registering new address record for fe80::cd16:629d:5fca:594b on enp4s0.*.
Feb 27 10:30:36 endeavourmsi systemd[1]: dbus-:1.2-org.kde.powerdevil.wakeupsourcehelper@3.service: Deactivated successfully.
Feb 27 10:30:37 endeavourmsi kernel: alx 0000:04:00.0 enp4s0: NIC Up: 1 Gbps Full
Feb 27 10:30:37 endeavourmsi mullvad-daemon[992]: [netlink_packet_route::link::buffer_tool][WARN] Specified IFLA_INET6_CONF NLA attribute holds more(most likely new kernel) data which is unknown to netlink-packet-route crate, expecting 236, got 240
Feb 27 10:30:37 endeavourmsi NetworkManager[970]: <info>  [1772209837.0067] device (enp4s0): carrier: link connected
Feb 27 10:30:37 endeavourmsi NetworkManager[970]: <info>  [1772209837.0071] device (enp4s0): ip:dhcp4: restarting
Feb 27 10:30:37 endeavourmsi NetworkManager[970]: <info>  [1772209837.0232] dhcp4 (enp4s0): canceled DHCP transaction
Feb 27 10:30:37 endeavourmsi NetworkManager[970]: <info>  [1772209837.0232] dhcp4 (enp4s0): state changed no lease
Feb 27 10:30:37 endeavourmsi NetworkManager[970]: <info>  [1772209837.0232] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds)
Feb 27 10:30:38 endeavourmsi NetworkManager[970]: <info>  [1772209838.5672] dhcp6 (enp4s0): activation: beginning transaction (timeout in 45 seconds)
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]: [mullvad_daemon::api][INFO] Detecting changes to offline state - Online(Ipv6)
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]: [mullvad_api::availability][DEBUG] Resuming API requests due to coming online
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]: [mullvad_api::rest][ERROR] Error: HTTP request failed
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]: Caused by: Legacy hyper error
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]: Caused by: client error (Connect)
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]: Caused by: Network is unreachable (os error 101)
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]: [mullvad_daemon::version::check][ERROR] Failed to fetch version info: Failed to check the latest app version
Feb 27 10:30:38 endeavourmsi NetworkManager[970]: <info>  [1772209838.5693] policy: set 'Wired connection 1' (enp4s0) as default for IPv6 routing and DNS
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]: [mullvad_encrypted_dns_proxy::state][ERROR] Failed to fetch a new proxy configuration: ResolutionError(ResolveError { kind: Proto(ProtoError { kind: Io(Os { code: 101, kind: NetworkUnreachable, message: "Network is unreachable" }) }) })
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]: [mullvad_daemon::api][WARN] Failed to fetch new Encrypted DNS Proxy configurations
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]: [mullvad_daemon::api][DEBUG] FetchConfigError(
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]:     ResolutionError(
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]:         ResolveError {
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]:             kind: Proto(
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]:                 ProtoError {
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]:                     kind: Io(
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]:                         Os {
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]:                             code: 101,
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]:                             kind: NetworkUnreachable,
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]:                             message: "Network is unreachable",
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]:                         },
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]:                     ),
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]: [mullvad_daemon::api][WARN] Could not select next Encrypted DNS proxy config
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]: [mullvad_api::access_mode][INFO] A new API access method has been selected: Encrypted DNS proxy
Feb 27 10:30:38 endeavourmsi mullvad-daemon[992]: [mullvad_daemon::management_interface][DEBUG] Broadcasting access method event
Feb 27 10:30:38 endeavourmsi NetworkManager[970]: <info>  [1772209838.5838] dhcp6 (enp4s0): state changed new lease, address=2601:243:e080:2110::cbc2
Feb 27 10:30:38 endeavourmsi systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Feb 27 10:30:39 endeavourmsi NetworkManager[970]: <info>  [1772209839.0369] dhcp4 (enp4s0): state changed new lease, address=10.0.0.202, acd pending
Feb 27 10:30:39 endeavourmsi NetworkManager[970]: <info>  [1772209839.1624] dhcp4 (enp4s0): state changed new lease, address=10.0.0.202
Feb 27 10:30:39 endeavourmsi avahi-daemon[886]: Joining mDNS multicast group on interface enp4s0.IPv4 with address 10.0.0.202.
Feb 27 10:30:39 endeavourmsi avahi-daemon[886]: New relevant interface enp4s0.IPv4 for mDNS.
Feb 27 10:30:39 endeavourmsi NetworkManager[970]: <info>  [1772209839.1645] policy: set 'Wired connection 1' (enp4s0) as default for IPv4 routing and DNS
Feb 27 10:30:39 endeavourmsi mullvad-daemon[992]: [mullvad_daemon::api][INFO] Detecting changes to offline state - Online(Ipv4AndIpv6)
Feb 27 10:30:39 endeavourmsi mullvad-daemon[992]: [mullvad_api::availability][DEBUG] Resuming API requests due to coming online
Feb 27 10:30:39 endeavourmsi avahi-daemon[886]: Registering new address record for 10.0.0.202 on enp4s0.IPv4.
Feb 27 10:30:39 endeavourmsi NetworkManager[970]: <info>  [1772209839.1882] device (enp4s0): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
Feb 27 10:30:39 endeavourmsi systemd[1]: Starting Network Manager Script Dispatcher Service...
Feb 27 10:30:39 endeavourmsi systemd[1]: Started Network Manager Script Dispatcher Service.
Feb 27 10:30:39 endeavourmsi NetworkManager[970]: <info>  [1772209839.2120] device (enp4s0): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
Feb 27 10:30:39 endeavourmsi NetworkManager[970]: <info>  [1772209839.2122] device (enp4s0): state change: secondaries -> activated (reason 'none', managed-type: 'full')
Feb 27 10:30:39 endeavourmsi NetworkManager[970]: <info>  [1772209839.2124] manager: NetworkManager state is now CONNECTED_SITE
Feb 27 10:30:39 endeavourmsi NetworkManager[970]: <info>  [1772209839.2125] device (enp4s0): Activation: successful, device activated.
Feb 27 10:30:39 endeavourmsi NetworkManager[970]: <info>  [1772209839.5053] manager: NetworkManager state is now CONNECTED_GLOBAL
Feb 27 10:30:39 endeavourmsi avahi-daemon[886]: Leaving mDNS multicast group on interface enp4s0.IPv6 with address fe80::cd16:629d:5fca:594b.
Feb 27 10:30:39 endeavourmsi avahi-daemon[886]: Joining mDNS multicast group on interface enp4s0.IPv6 with address 2601:243:e080:2110:255b:1bf3:ec7c:6ae8.
Feb 27 10:30:39 endeavourmsi avahi-daemon[886]: Registering new address record for 2601:243:e080:2110:255b:1bf3:ec7c:6ae8 on enp4s0.*.
Feb 27 10:30:39 endeavourmsi avahi-daemon[886]: Withdrawing address record for fe80::cd16:629d:5fca:594b on enp4s0.
Feb 27 10:30:39 endeavourmsi avahi-daemon[886]: Registering new address record for 2601:243:e080:2110::cbc2 on enp4s0.*.
Feb 27 10:30:39 endeavourmsi mullvad-daemon[992]: [mullvad_daemon::management_interface][DEBUG] get_account_data
Feb 27 10:30:44 endeavourmsi systemd[1178]: Started LibreWolf - Web Browser.
Feb 27 10:30:44 endeavourmsi systemd[1]: Starting Time & Date Service...
Feb 27 10:30:44 endeavourmsi systemd[1]: Started Time & Date Service.
Feb 27 10:30:45 endeavourmsi rtkit-daemon[1098]: Successfully made thread 74799 of process 74580 owned by '1000' RT at priority 10.
Feb 27 10:30:46 endeavourmsi rtkit-daemon[1098]: Successfully made thread 74864 of process 74767 owned by '1000' RT at priority 10.
Feb 27 10:30:49 endeavourmsi systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Feb 27 10:31:01 endeavourmsi rtkit-daemon[1098]: Successfully made thread 75063 of process 74580 owned by '1000' RT at priority 10.
Feb 27 10:31:01 endeavourmsi kdeconnectd[1598]: Cannot find Bluez 5 adapter for device search false
Feb 27 10:31:02 endeavourmsi plasmashell[1435]: Tray icon changed, title: MEGAsync name: MEGAsync
                                                Replacement:
Feb 27 10:31:12 endeavourmsi plasmashell[1435]: Tray icon changed, title: MEGAsync name: MEGAsync
                                                Replacement:
Feb 27 10:31:13 endeavourmsi systemd[1178]: Started Dolphin - File Manager.
Feb 27 10:31:14 endeavourmsi dolphin[75098]: Could not load default global viewproperties
Feb 27 10:31:14 endeavourmsi systemd[1178]: Started kitty - Terminal emulator.
Feb 27 10:31:15 endeavourmsi kitty[75154]: [0.045] Could not find included config file: /home/wombat/.config/kitty/current-theme.conf, ignoring
Feb 27 10:31:15 endeavourmsi systemd[1178]: Started kitty child process: 75159 launched by: 75154.
Feb 27 10:31:15 endeavourmsi fastfetch[75172]: Starting libddcutil. library built Not set at Not set. stdout_stderr_redirected=false
Feb 27 10:31:15 endeavourmsi libddcutil[75172]: Initializing libddcutil.  ddcutil version: 2.2.5, shared library: /usr/lib/libddcutil.so.5.4.1
Feb 27 10:31:15 endeavourmsi libddcutil[75172]:                           library built Not set at Not set. stdout_stderr_redirected=false
Feb 27 10:31:15 endeavourmsi systemd[1]: systemd-timedated.service: Deactivated successfully.
Feb 27 10:31:16 endeavourmsi libddcutil[75172]: Library initialization complete.
Feb 27 10:31:16 endeavourmsi libddcutil[75172]: libddcutil terminating.
Feb 27 10:31:16 endeavourmsi kitty[75154]: [1.289] [PARSE ERROR] Unknown terminfo property: query-os-name
ā”€āÆ
@Bink, it happened yet again. Seems to be happening every 3-5 days. Very odd.
ā”€āÆ journalctl -b -0 | tail -n 200
Mar 01 21:29:05 endeavourmsi systemd-logind[906]: Operation 'suspend' finished.
Mar 01 21:29:05 endeavourmsi lact[1034]: 2026-03-02T03:29:05.541166Z  INFO lact_daemon::suspend: suspend/resume event detected, reloading config
Mar 01 21:29:05 endeavourmsi mullvad-vpn[1661]: [2026-03-01 21:29:05.541][info] Resume event received, connecting to daemon
Mar 01 21:29:05 endeavourmsi kdeconnectd[1615]: Failed to open any MDNS client sockets
Mar 01 21:29:05 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::management_interface][DEBUG] app_upgrade_events_listen
Mar 01 21:29:05 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::management_interface][DEBUG] get_account_history
Mar 01 21:29:05 endeavourmsi mullvad-daemon[1008]: [netlink_packet_route::link::buffer_tool][WARN] Specified IFLA_INET6_CONF NLA attribute holds more(most likely new kernel) data which is unknown to netlink-packet-route crate, expecting 236, got 240
Mar 01 21:29:05 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::management_interface][DEBUG] get_tunnel_state
Mar 01 21:29:05 endeavourmsi mullvad-vpn[1661]: [2026-03-01 21:29:05.545][info] Resume event received, connecting to daemon
Mar 01 21:29:05 endeavourmsi mullvad-vpn[1661]: [2026-03-01 21:29:05.546][info] Verified socket ownership
Mar 01 21:29:05 endeavourmsi mullvad-vpn[1661]: [2026-03-01 21:29:05.546][info] Connected to the daemon
Mar 01 21:29:05 endeavourmsi mullvad-vpn[1661]: [2026-03-01 21:29:05.549][info] Verified socket ownership
Mar 01 21:29:05 endeavourmsi mullvad-vpn[1661]: [2026-03-01 21:29:05.549][info] Connected to the daemon
Mar 01 21:29:05 endeavourmsi rtkit-daemon[1115]: Resuming known real-time threads.
Mar 01 21:29:05 endeavourmsi kdeconnectd[1615]: Failed to open any MDNS server sockets
Mar 01 21:29:05 endeavourmsi logger[3358]: <13>Mar  1 21:29:05 suspend: nvidia-resume.service
Mar 01 21:29:05 endeavourmsi rtkit-daemon[1115]: Successfully made thread 1523 of process 1514 owned by '1000' RT at priority 20.
Mar 01 21:29:05 endeavourmsi NetworkManager[986]: <info>  [1772422145.5427] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Mar 01 21:29:05 endeavourmsi rtkit-daemon[1115]: Successfully made thread 1514 of process 1514 owned by '1000' high priority at nice level -11.
Mar 01 21:29:05 endeavourmsi NetworkManager[986]: <info>  [1772422145.5427] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
Mar 01 21:29:05 endeavourmsi rtkit-daemon[1115]: Successfully made thread 1358 of process 1346 owned by '1000' RT at priority 20.
Mar 01 21:29:05 endeavourmsi kdeconnectd[1615]: No local bluetooth adapter found
Mar 01 21:29:05 endeavourmsi rtkit-daemon[1115]: Successfully made thread 1346 of process 1346 owned by '1000' high priority at nice level -11.
Mar 01 21:29:05 endeavourmsi NetworkManager[986]: <info>  [1772422145.5548] manager: NetworkManager state is now DISCONNECTED
Mar 01 21:29:05 endeavourmsi rtkit-daemon[1115]: Successfully made thread 1350 of process 1345 owned by '1000' RT at priority 20.
Mar 01 21:29:05 endeavourmsi kwin_wayland[1288]: Atomic modeset test failed! Permission denied
Mar 01 21:29:05 endeavourmsi rtkit-daemon[1115]: Successfully made thread 1345 of process 1345 owned by '1000' high priority at nice level -11.
Mar 01 21:29:05 endeavourmsi rtkit-daemon[1115]: Resumed scheduling 6 threads.
Mar 01 21:29:05 endeavourmsi systemd[1]: nvidia-resume.service: Deactivated successfully.
Mar 01 21:29:05 endeavourmsi org_kde_powerdevil[1489]: [  1609] Udev event detected
Mar 01 21:29:05 endeavourmsi systemd[1]: Finished NVIDIA system resume actions.
Mar 01 21:29:05 endeavourmsi suspend[3358]: nvidia-resume.service
Mar 01 21:29:05 endeavourmsi lact[1034]: 2026-03-02T03:29:05.664392Z  INFO lact_daemon::server::handler: initialized nvidia controller for GPU 10DE:2489-19DA:6630-0000:01:00.0 at '/sys/class/drm/card1/device'
Mar 01 21:29:05 endeavourmsi lact[1034]: 2026-03-02T03:29:05.664412Z  INFO lact_daemon::server::handler: GPU list reloaded with 1 devices, reapplying configuration
Mar 01 21:29:05 endeavourmsi wireplumber[1346]: spa.bluez5: BlueZ system service is not available
Mar 01 21:29:05 endeavourmsi kded6[1405]: No object for name "auto_null"
Mar 01 21:29:05 endeavourmsi kded6[1405]: No object for name "auto_null.monitor"
Mar 01 21:29:05 endeavourmsi kded6[1405]: No object for name "@DEFAULT_SINK@"
Mar 01 21:29:05 endeavourmsi kded6[1405]: No object for name "@DEFAULT_SOURCE@"
Mar 01 21:29:05 endeavourmsi kded6[1405]: No object for name "alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor"
Mar 01 21:29:05 endeavourmsi kded6[1405]: No object for name "alsa_input.pci-0000_00_1f.3.analog-stereo"
Mar 01 21:29:05 endeavourmsi kded6[1405]: No object for name "alsa_output.pci-0000_00_1f.3.analog-stereo.monitor"
Mar 01 21:29:05 endeavourmsi lact[1034]: 2026-03-02T03:29:05.878070Z  INFO lact_daemon::server::handler: configuration applied
Mar 01 21:29:05 endeavourmsi lact[1034]: 2026-03-02T03:29:05.880010Z  INFO lact_daemon: got kernel drm subsystem event, reloading GPUs
Mar 01 21:29:05 endeavourmsi org_kde_powerdevil[1489]: [  1609] Adding connected display with bus 3
Mar 01 21:29:05 endeavourmsi lact[1034]: 2026-03-02T03:29:05.959481Z  INFO lact_daemon::server::handler: initialized nvidia controller for GPU 10DE:2489-19DA:6630-0000:01:00.0 at '/sys/class/drm/card1/device'
Mar 01 21:29:05 endeavourmsi lact[1034]: 2026-03-02T03:29:05.959495Z  INFO lact_daemon::server::handler: GPU list reloaded with 1 devices, reapplying configuration
Mar 01 21:29:05 endeavourmsi lact[1034]: 2026-03-02T03:29:05.966583Z  INFO lact_daemon::server::handler: configuration applied
Mar 01 21:29:06 endeavourmsi kded6[1405]: No object for name "alsa_output.pci-0000_00_1f.3.analog-stereo.monitor"
Mar 01 21:29:06 endeavourmsi mullvad-vpn[1661]: [1661:0301/212906.205351:ERROR:electron/shell/browser/notifications/linux/libnotify_notification.cc:50] notify_notification_show: domain=776 code=36 message="GDBus.Error:org.freedesktop.Notifications.Error.ExcessNotificationGeneration: Created too many similar notifications in quick succession"
Mar 01 21:29:06 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::management_interface][DEBUG] get_device
Mar 01 21:29:06 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::management_interface][DEBUG] get_settings
Mar 01 21:29:06 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::management_interface][DEBUG] update_device
Mar 01 21:29:06 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::management_interface][DEBUG] get_account_history
Mar 01 21:29:06 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::management_interface][DEBUG] get_account_data
Mar 01 21:29:06 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::management_interface][ERROR] Unable to get account data from API: Error: Legacy hyper error
Mar 01 21:29:06 endeavourmsi mullvad-daemon[1008]: Caused by: client error (Connect)
Mar 01 21:29:06 endeavourmsi mullvad-daemon[1008]: Caused by: Network is unreachable (os error 101)
Mar 01 21:29:06 endeavourmsi mullvad-vpn[1661]: [2026-03-01 21:29:06.216][warning] Failed to fetch account data. Retrying in 8000 ms
Mar 01 21:29:06 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::management_interface][DEBUG] get_current_api_access_method
Mar 01 21:29:06 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::management_interface][DEBUG] get_relay_locations
Mar 01 21:29:06 endeavourmsi plasmashell[1465]: No object for name "auto_null"
Mar 01 21:29:06 endeavourmsi plasmashell[1465]: No object for name "auto_null.monitor"
Mar 01 21:29:06 endeavourmsi plasmashell[1465]: file:///home/wombat/.local/share/plasma/plasmoids/KdeControlStation/contents/ui/components/Volume.qml:44: TypeError: Cannot read property 'volume' of null
Mar 01 21:29:06 endeavourmsi plasmashell[1465]: file:///home/wombat/.local/share/plasma/plasmoids/KdeControlStation/contents/ui/components/Volume.qml:35: TypeError: Cannot read property 'volume' of null
Mar 01 21:29:06 endeavourmsi plasmashell[1465]: file:///home/wombat/.local/share/plasma/plasmoids/KdeControlStation/contents/ui/components/Volume.qml:48: TypeError: Cannot read property 'volume' of null
Mar 01 21:29:06 endeavourmsi plasmashell[1465]: No object for name "alsa_output.pci-0000_00_1f.3.analog-stereo"
Mar 01 21:29:06 endeavourmsi plasmashell[1465]: No object for name "alsa_output.pci-0000_00_1f.3.analog-stereo.monitor"
Mar 01 21:29:06 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::management_interface][DEBUG] get_current_version
Mar 01 21:29:06 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::management_interface][DEBUG] get_version_info
Mar 01 21:29:06 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::version::check][ERROR] Failed to fetch version info: Failed to check the latest app version
Mar 01 21:29:07 endeavourmsi kernel: alx 0000:04:00.0 enp4s0: NIC Up: 1 Gbps Full
Mar 01 21:29:07 endeavourmsi mullvad-daemon[1008]: [netlink_packet_route::link::buffer_tool][WARN] Specified IFLA_INET6_CONF NLA attribute holds more(most likely new kernel) data which is unknown to netlink-packet-route crate, expecting 236, got 240
Mar 01 21:29:07 endeavourmsi NetworkManager[986]: <info>  [1772422147.4553] device (enp4s0): carrier: link connected
Mar 01 21:29:07 endeavourmsi NetworkManager[986]: <info>  [1772422147.4557] device (enp4s0): state change: unavailable -> disconnected (reason 'carrier-changed', managed-type: 'full')
Mar 01 21:29:07 endeavourmsi NetworkManager[986]: <info>  [1772422147.4572] policy: auto-activating connection 'Wired connection 1' (b85d3b56-9e20-3285-80a0-d1d6829dbb4b)
Mar 01 21:29:07 endeavourmsi NetworkManager[986]: <info>  [1772422147.4580] device (enp4s0): Activation: starting connection 'Wired connection 1' (b85d3b56-9e20-3285-80a0-d1d6829dbb4b)
Mar 01 21:29:07 endeavourmsi NetworkManager[986]: <info>  [1772422147.4582] device (enp4s0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
Mar 01 21:29:07 endeavourmsi NetworkManager[986]: <info>  [1772422147.4588] manager: NetworkManager state is now CONNECTING
Mar 01 21:29:07 endeavourmsi NetworkManager[986]: <info>  [1772422147.4593] device (enp4s0): state change: prepare -> config (reason 'none', managed-type: 'full')
Mar 01 21:29:07 endeavourmsi NetworkManager[986]: <info>  [1772422147.5001] device (enp4s0): state change: config -> ip-config (reason 'none', managed-type: 'full')
Mar 01 21:29:07 endeavourmsi NetworkManager[986]: <info>  [1772422147.5008] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds)
Mar 01 21:29:08 endeavourmsi org_kde_powerdevil[1489]: [  1609] Emitting DDCA_Display_Status_Event[2541.323:  DDCA_EVENT_DISPLAY_CONNECTED, card1-DP-1, dref: DDCA_Display_Ref[2], io_path:/dev/i2c-3, ddc working: true]
Mar 01 21:29:08 endeavourmsi org_kde_powerdevil[1489]: [  1609] Starting 1 callback threads
Mar 01 21:29:08 endeavourmsi org_kde_powerdevil[1489]: [  1609] libddcutil callback thread 0x7f1344003690 started
Mar 01 21:29:08 endeavourmsi org_kde_powerdevil[1489]: [  1609] Started 1 event callback thread(s)
Mar 01 21:29:08 endeavourmsi org_kde_powerdevil[1489]: [  3415] Invoking callback function 0x7f136a3217f0 for event DDCA_Display_Status_Event[2541.323:  DDCA_EVENT_DISPLAY_CONNECTED, card1-DP-1, dref: DDCA_Display_Ref[2], io_path:/dev/i2c-3, ddc working: true] in this thread [  3415]
Mar 01 21:29:08 endeavourmsi org_kde_powerdevil[1489]: [  3415] Callback function 0x7f136a3217f0 for event DDCA_Display_Status_Event[2541.323:  DDCA_EVENT_DISPLAY_CONNECTED, card1-DP-1, dref: DDCA_Display_Ref[2], io_path:/dev/i2c-3, ddc working: true] complete
Mar 01 21:29:08 endeavourmsi org_kde_powerdevil[1489]: [  1489] Quiescing libddcutil API...
Mar 01 21:29:08 endeavourmsi org_kde_powerdevil[1489]: [  1489] Quiesce libddcutil API complete
Mar 01 21:29:08 endeavourmsi org_kde_powerdevil[1489]: [  1489] Display redetection starting.
Mar 01 21:29:08 endeavourmsi org_kde_powerdevil[1489]: [  1608] recheck thread terminating because watch thread terminated
Mar 01 21:29:08 endeavourmsi org_kde_powerdevil[1489]: [  1489] Watch thread terminated.
Mar 01 21:29:08 endeavourmsi avahi-daemon[902]: Joining mDNS multicast group on interface enp4s0.IPv6 with address fe80::cd16:629d:5fca:594b.
Mar 01 21:29:08 endeavourmsi avahi-daemon[902]: New relevant interface enp4s0.IPv6 for mDNS.
Mar 01 21:29:08 endeavourmsi avahi-daemon[902]: Registering new address record for fe80::cd16:629d:5fca:594b on enp4s0.*.
Mar 01 21:29:09 endeavourmsi NetworkManager[986]: <info>  [1772422149.1668] dhcp6 (enp4s0): activation: beginning transaction (timeout in 45 seconds)
Mar 01 21:29:09 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::api][INFO] Detecting changes to offline state - Online(Ipv6)
Mar 01 21:29:09 endeavourmsi mullvad-daemon[1008]: [mullvad_api::availability][DEBUG] Resuming API requests due to coming online
Mar 01 21:29:09 endeavourmsi NetworkManager[986]: <info>  [1772422149.1685] policy: set 'Wired connection 1' (enp4s0) as default for IPv6 routing and DNS
Mar 01 21:29:09 endeavourmsi NetworkManager[986]: <info>  [1772422149.1836] dhcp6 (enp4s0): state changed new lease, address=2601:243:e080:2110::cbc2
Mar 01 21:29:09 endeavourmsi NetworkManager[986]: <info>  [1772422149.5118] dhcp4 (enp4s0): state changed new lease, address=10.0.0.202, acd pending
Mar 01 21:29:09 endeavourmsi org_kde_powerdevil[1489]: [  1489] Watching for display connection changes, resolved watch mode = Watch_Mode_Udev, poll loop interval = 500 millisec
Mar 01 21:29:09 endeavourmsi org_kde_powerdevil[1489]: [  1489]                                          extra_stabilization_millisec: 0,  stabilization_poll_millisec: 100
Mar 01 21:29:09 endeavourmsi org_kde_powerdevil[1489]: [  1489] libddcutil recheck thread 0x5644b3fc3290 started
Mar 01 21:29:09 endeavourmsi org_kde_powerdevil[1489]: [  1489] libddcutil watch thread 0x7f1358018b50 started
Mar 01 21:29:09 endeavourmsi org_kde_powerdevil[1489]: [  1489] Display redetection finished.
Mar 01 21:29:09 endeavourmsi org_kde_powerdevil[1489]: [  1489] Unquiescing libddcutil API...
Mar 01 21:29:09 endeavourmsi org_kde_powerdevil[1489]: [  3416] (dw_recheck_displays_func) Recheck interval: Sleeping for 200 milliseconds
Mar 01 21:29:09 endeavourmsi systemd[1]: dbus-:1.2-org.kde.powerdevil.wakeupsourcehelper@0.service: Deactivated successfully.
Mar 01 21:29:09 endeavourmsi NetworkManager[986]: <info>  [1772422149.6988] dhcp4 (enp4s0): state changed new lease, address=10.0.0.202
Mar 01 21:29:09 endeavourmsi avahi-daemon[902]: Joining mDNS multicast group on interface enp4s0.IPv4 with address 10.0.0.202.
Mar 01 21:29:09 endeavourmsi avahi-daemon[902]: New relevant interface enp4s0.IPv4 for mDNS.
Mar 01 21:29:09 endeavourmsi avahi-daemon[902]: Registering new address record for 10.0.0.202 on enp4s0.IPv4.
Mar 01 21:29:09 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::api][INFO] Detecting changes to offline state - Online(Ipv4AndIpv6)
Mar 01 21:29:09 endeavourmsi NetworkManager[986]: <info>  [1772422149.7009] policy: set 'Wired connection 1' (enp4s0) as default for IPv4 routing and DNS
Mar 01 21:29:09 endeavourmsi NetworkManager[986]: <info>  [1772422149.7237] device (enp4s0): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
Mar 01 21:29:09 endeavourmsi NetworkManager[986]: <info>  [1772422149.7277] device (enp4s0): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
Mar 01 21:29:09 endeavourmsi NetworkManager[986]: <info>  [1772422149.7281] device (enp4s0): state change: secondaries -> activated (reason 'none', managed-type: 'full')
Mar 01 21:29:09 endeavourmsi NetworkManager[986]: <info>  [1772422149.7291] manager: NetworkManager state is now CONNECTED_SITE
Mar 01 21:29:09 endeavourmsi NetworkManager[986]: <info>  [1772422149.7300] device (enp4s0): Activation: successful, device activated.
Mar 01 21:29:09 endeavourmsi systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 01 21:29:10 endeavourmsi NetworkManager[986]: <info>  [1772422150.0272] manager: NetworkManager state is now CONNECTED_GLOBAL
Mar 01 21:29:10 endeavourmsi systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 01 21:29:10 endeavourmsi systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 01 21:29:10 endeavourmsi avahi-daemon[902]: Leaving mDNS multicast group on interface enp4s0.IPv6 with address fe80::cd16:629d:5fca:594b.
Mar 01 21:29:10 endeavourmsi avahi-daemon[902]: Joining mDNS multicast group on interface enp4s0.IPv6 with address 2601:243:e080:2110:255b:1bf3:ec7c:6ae8.
Mar 01 21:29:10 endeavourmsi avahi-daemon[902]: Registering new address record for 2601:243:e080:2110:255b:1bf3:ec7c:6ae8 on enp4s0.*.
Mar 01 21:29:10 endeavourmsi avahi-daemon[902]: Withdrawing address record for fe80::cd16:629d:5fca:594b on enp4s0.
Mar 01 21:29:10 endeavourmsi avahi-daemon[902]: Registering new address record for 2601:243:e080:2110::cbc2 on enp4s0.*.
Mar 01 21:29:11 endeavourmsi mullvad-daemon[1008]: [mullvad_api::rest][ERROR] Error: HTTP request failed
Mar 01 21:29:11 endeavourmsi mullvad-daemon[1008]: Caused by: Legacy hyper error
Mar 01 21:29:11 endeavourmsi mullvad-daemon[1008]: Caused by: client error (SendRequest)
Mar 01 21:29:11 endeavourmsi mullvad-daemon[1008]: Caused by: connection error
Mar 01 21:29:11 endeavourmsi mullvad-daemon[1008]: Caused by: Connection reset by peer (os error 104)
Mar 01 21:29:11 endeavourmsi mullvad-daemon[1008]: [mullvad_relay_selector::relay_selector::detailer][INFO] Selected Shadowsocks bridge us-nyc-br-601 at 38.132.121.146:443/TCP
Mar 01 21:29:11 endeavourmsi mullvad-daemon[1008]: [mullvad_api::access_mode][INFO] A new API access method has been selected: Mullvad Bridges
Mar 01 21:29:11 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::management_interface][DEBUG] Broadcasting access method event
Mar 01 21:29:12 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::device][DEBUG] The current device is still valid
Mar 01 21:29:14 endeavourmsi mullvad-daemon[1008]: [mullvad_daemon::management_interface][DEBUG] get_account_data
Mar 01 21:29:17 endeavourmsi plasmashell[1465]: Tray icon changed, title: MEGAsync name: MEGAsync
                                                Replacement:
Mar 01 21:29:20 endeavourmsi systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 01 21:29:20 endeavourmsi systemd[1194]: Started Mousepad - Text Editor.
Mar 01 21:29:20 endeavourmsi mousepad[3440]: broker.vala:156: Error loading plugin: libhspell.so.0: cannot open shared object file: No such file or directory
Mar 01 21:29:20 endeavourmsi mousepad[3440]: broker.vala:156: Error loading plugin: libnuspell.so.5: cannot open shared object file: No such file or directory
Mar 01 21:29:20 endeavourmsi mousepad[3440]: broker.vala:156: Error loading plugin: libvoikko.so.1: cannot open shared object file: No such file or directory
Mar 01 21:29:20 endeavourmsi mousepad[3440]: gspell_language_get_code: assertion 'language != NULL' failed
Mar 01 21:29:20 endeavourmsi mousepad[3440]: Failed to load plugin "mousepad-plugin-shortcuts": libxfce4kbd-private-3.so.0: cannot open shared object file: No such file or directory
Mar 01 21:29:21 endeavourmsi systemd[1194]: Starting Virtual filesystem metadata service...
Mar 01 21:29:21 endeavourmsi systemd[1194]: Started Virtual filesystem metadata service.
Mar 01 21:29:23 endeavourmsi systemd[1194]: Started LibreWolf - Web Browser.
Mar 01 21:29:24 endeavourmsi systemd[1]: Starting Time & Date Service...
Mar 01 21:29:24 endeavourmsi systemd[1]: Started Time & Date Service.
Mar 01 21:29:25 endeavourmsi rtkit-daemon[1115]: Successfully made thread 3985 of process 3760 owned by '1000' RT at priority 10.
Mar 01 21:29:25 endeavourmsi rtkit-daemon[1115]: Successfully made thread 4056 of process 3950 owned by '1000' RT at priority 10.
Mar 01 21:29:35 endeavourmsi kdeconnectd[1615]: Cannot find Bluez 5 adapter for device search false
Mar 01 21:29:37 endeavourmsi plasmashell[1465]: Tray icon changed, title: MEGAsync name: MEGAsync
                                                Replacement:
Mar 01 21:29:40 endeavourmsi rtkit-daemon[1115]: Successfully made thread 4252 of process 3760 owned by '1000' RT at priority 10.
Mar 01 21:29:42 endeavourmsi systemd[1194]: Started kitty - Terminal emulator.
Mar 01 21:29:42 endeavourmsi kitty[4266]: [0.066] Could not find included config file: /home/wombat/.config/kitty/current-theme.conf, ignoring
Mar 01 21:29:43 endeavourmsi plasmashell[1465]: error creating screencast "Could not find window id {5428be6d-7f67-4c86-bb59-48ebc28bc21f}"
Mar 01 21:29:43 endeavourmsi systemd[1194]: Started kitty child process: 4275 launched by: 4266.
Mar 01 21:29:43 endeavourmsi fastfetch[4284]: Starting libddcutil. library built Not set at Not set. stdout_stderr_redirected=false
Mar 01 21:29:43 endeavourmsi libddcutil[4284]: Initializing libddcutil.  ddcutil version: 2.2.5, shared library: /usr/lib/libddcutil.so.5.4.1
Mar 01 21:29:43 endeavourmsi libddcutil[4284]:                           library built Not set at Not set. stdout_stderr_redirected=false
Mar 01 21:29:44 endeavourmsi libddcutil[4284]: Library initialization complete.
Mar 01 21:29:44 endeavourmsi libddcutil[4284]: libddcutil terminating.
Mar 01 21:29:44 endeavourmsi kitty[4266]: [1.440] [PARSE ERROR] Unknown terminfo property: query-os-name
ā”€āÆ
EDIT:
Even more strange. I right-clicked the desktop, chose Display And Wallpaper. Picked a wallpaper and POOF… all was normal.
:thinking:
Are the white rectangles on top of everything, or only appearing on the wallpaper?
From what I can see of the screenshots shared in the thread, it’s wallpaper only? (that hadn’t really occurred to me earlier)
I suggest this with some caution.
You might try setting your Rendering Backend in Plasma Renderer to Software.
I’ve used this in the past to quite effectively resolve numerous Nvidia + Wayland issues. However, one update did cause Plasma to be temporarily inaccessible as a result, hence my caution. If that happens, here’s how to revert it:
the wallpaper fixing things kind of makes sense to me. It seems like a VRAM corruption issue during sleep, and from what i can tell it only affects things that were rendered before sleeping. Refreshing whatever cached memory was corrupted should remove the artifacts.
I’m not sure that I want to risk that. At least for the time being. Admittedly, this graphical artifact issue seems to be a minor issue. At least as far as I’m concerned. Especially since I can seemingly ā€œfixā€ it with a couple of clicks when it occurs. I’ll continue to monitor this and post back if/when anything changes.
I wouldn’t worry too much, it seems to be a minor bug in the Nvidia driver. It seems to be caused when coming out of sleep mode, because the memory controller or display scanout path is left in a partially inconsistent state, causing occasional read errors from the VRAM. I think it’s best to ignore it.
This problem does not only occur on the wallpaper, but also on the task bar and in games. These artifacts sometimes are a tiny version of the screen itself. If you change the background, the color of the remaining artifacts change as well. Maybe EtheraelEspeon uses an alternative task bar? The last thing i will do is ignore this bug. It looks terrible and make people laugh about my os. On my system it occurs every other standby cycle. The latest nvidia driver update didn’t change anything.
I know this probably isn’t the ideal solution, but perhaps disable sleep, and when not using the device for extended periods of time, simply shut down?
I suggest this, as I encountered sleep issues years ago and have simply chosen not to rely on it since.
Did that. Now only one screen(i have two) is affected which is an improvement. Thank you! I also searched in other distros forums and it seems other arch distros are affected as well which gives a little more hope for a fix.
It happened again!
This is the first time in 22 days, and it only showed up on my third monitor
(weather info scribbled out for privacy)
This is the output of journalctl -b -0 | tail -n 1000 > nvidia_bug_log.txt
https://pastebin.com/03FTxaB0
Happened to me again earlier today. I just decided to live with it. Logging out and back in clears it up. Pretty annoying, though.
