Hi everyone!
A question on what I should be looking at…
background:
I have a framework laptop running EOS (been running EOS for about 3 months-ish).
This morning, I started up the laptop. It’s HDMI plugged into an external 24" 1920x1080 Dell monitor.
It worked normally. the next step is where I fudged up
I ran an update, not paying attention to what was being updated because there was a lot (the laptop had been shut down for about 4 days and not been updated for several days before that).
I rebooted.
issue:
the external monitor started flickering (not on/off, more of a “trying to find the right resolution” type of flickering) but it was still at the correct 1920x1080 resolution.
I rebooted. (there were several reboots, monitor swaps, and cables swaps in this step because the flickering was giving me a headache)
After 10 or so reboots, the flickering stopped but the resolution change (less desktop space, bigger everything else)
The resolution changed to something smaller but the system still lists it as 1920x1080.
The current problem is the resolution is not displaying what is listed by the system.
I ran inxi and this is what pops up.
$ inxi -Ga
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Realtek Laptop Camera type: USB driver: uvcvideo bus-ID: 3-7:4
chip-ID: 0bda:5634 class-ID: 0e02 serial: 200901010001
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: intel unloaded: fbdev,modesetting,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 202 s-size: 242x136mm (9.5x5.4")
s-diag: 278mm (10.9")
Monitor-1: DP1 res: 1920x1080 dpi: 92 size: 530x300mm (20.9x11.8")
diag: 609mm (24")
I ran xrandr and this is what shows up:
$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
eDP1 connected (normal left inverted right x axis y axis)
2256x1504 60.00 + 48.00
DP1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 530mm x 300mm
1920x1080 60.00 + 50.00* 59.94
1920x1080i 60.00 50.00 59.94
1600x900 60.00
1280x1024 75.02 60.02
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 60.00 59.94
720x400 70.08
DP2 disconnected (normal left inverted right x axis y axis)
DP3 disconnected (normal left inverted right x axis y axis)
DP4 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
What am I missing? The configuration looks correct for my untrained eyes but the screen resolution is REALLY not correct.
I looked at the kernel thinking maybe there was a kernel update that fubar’d the resolution but it is the same version that was running last week with no issues. Currently running 5.14.16-arch1-1
Anyone have a sweet nugget of “you’re an idiot, try this” commands?
