So the system is EndevourOS, Xfce environment. I can boot to terminal through SHIFT+F2. My videocard is Nvidia GT 640.
Yesterday it worked flawlessly, even worked after updating system.
Look at this thread:
I have 1.8-1 libx11 version, it doesnt help to solve the problem.
Can you post boot logs and hardware logs as per
Welcome to forums!!
Did that update process include a reboot?
See also:
OK, so what else changed between the update and reboot and you trying the machine today?
Installing Telegram Desktop, Chromium, Steam, nothing special.
Please be specific. Troubleshooting is impossible with generic information.
I thought you said you updated?
Sorry for misunderstanding. I didnt update my system.
Yes, installed these programs, nothing more.
Update your system.
It’s pointless being on a rolling-release distro if you don’t update for months at a time.
How to do that out of terminal? I installed the latest iso of endevouros yesterday
yay
or
UpdateInTerminal
Yes, ive used offline one. And seems like i didnt update my system after booting.
After offline install (and reboot) the first thing to do is update the installed system.
In terminal you can use e.g. the commands I wrote above.
I think there is a lock on the pacman database file. Use the following command to remove it:
sudo rm /var/lib/pacman/db.lck
This happens whenever there is another instance of pacman (package manager) running and/or interrupted.
Updated with yay, problem didnt solve. Linux 5.18.2-arch1-1 now
