Can you show the output of command
pacman -Q libx11
pacman -Q libx11
Show the following.
Edit: Your card requires the 470.xx nvidia drivers from the AUR
inxi -Ga
Here
It shows no driver loaded. It’s not even running on nouveau opens source.
Can i install them in terminal? Or is it require anything different?
@Akse
Have you tried to install the nvidia drivers.
I have reinstalled endevouros with online installer, installed steam, installed cs. Then rebooted and still getting stuck at Reached target grapgical interface. Now installing nvidia drivers, stucked here
Alright it ended, rebooting and ill see what happens.
What you should do is install EndeavourOS online and don’t install steam or cs or anything. Does it boot to a desktop then before doing anything.
Edit: maybe you aren’t waiting long enough for it to finish?
Installing drivers solving the problem, booted to OS.
There you go. Now it is running on the 470,xx drivers and rendering with the card.
Yes, thank you for help!
Please mark the post that solved the issue as the solution. Thanks.
