Hi, this is a trully newbie question, but I couldn’t figure it out myself.
So the problem is the last update (172 packages). After installing them one of my app stops open (the app is “bauh”).
I has been reading articles about EndeavourOS for quite a while, trying to increase my knowledge in Linux and related subjects, so I expeted such a problem, and I did a system backup using Timeshift before upgrade.
And I was able to restore the last point and everything works again.
But the question is:
What should I do next?
Now I have 172 updates and I should do something about it. But I don’t know how to localize the problem. How and where to report about it. Or how to test all environment after each update.
I would appreciate your help, maybe you can give me some sort of a checklist on how to update EndeavourOS properly, how to check system and apps after that and what to do in a case of some problems.
Please, share your experience on how you are dealing with updates in a case them broke something.
