Ok this just started recently not sure what’s going on. Please help!!
I get the following when trying with WoeUSB or with Gnome DISKS
I’ve tried two different Thumb drives, and 2 different USB ports
It seems it is related to the latest kernel update:
Seemingly it will be fixed with the next one.
Thank you for the quick response!! Ok guess I just have to be patient
Perhaps switching to LTS could be an option for the moment when it comes to this libparted issue.
here’s a terminal command for at least restoring your flash drive to factory default Then if you have Disk(gnome-disk) installed you can format it with that, or someone can post the appropriate terminal command for you.
sudo shred -s $((2048*512)) -vzn0 /dev/sdf
Replace sdf with the appropriate device
Perhaps you’re able to format it in a terminal?
Some time ago I created a utility script to format USB sticks using exfat. The script basically uses gdisk and can easily be amended to Linux and ext4
exfat
USB=/dev/sdy
printf 'o\ny\nn\n\n\n\n0700\nw\ny\n' | sudo gdisk "$USB" && sudo mkexfatfs "$USB"1
ext4
USB=/dev/sdy
printf 'o\ny\nn\n\n\n\n8200\nw\ny\n' | sudo gdisk "$USB" && sudo mkfs.ext4 "$USB"1
#!/usr/bin/env bash
# format USB device to exfat
# ensure a device is given
if [[ -z "$1" ]]; then
echo "No device specified ..."
echo "Usage: format-usb.sh /dev/sdy"
exit
fi
# get the last part of device path
device="$(echo $1 | cut -d'/' -f3)"
echo "Checking device on => $device"
# create list of available devices
devices="$(lsblk -o NAME | egrep '^sd')"
# check if device is valid - abort if not
if ! [[ $devices =~ (^|[[:space:]])$device($|[[:space:]]) ]]; then
echo "$1 not found"
echo "Aborting"
exit 1
fi
# check if device is removable - abort if not
[[ $(echo $(lsblk -no RM "$1" | head -n 1)) = '0' ]] && \
echo "Non removable device detected!" && \
echo "Aborting" && \
exit 1
# Ask for confirmation
read -r -p "Confirm reformat of '$1' [y/N] " resp
if [[ "$resp" =~ ^([yY][eE][sS]|[yY])$ ]]; then
# Repeat confirmation question
read -r -p "Irrevocably format '$1' [y/N] " resp2
if [[ "$resp2" =~ ^([yY][eE][sS]|[yY])$ ]]; then
# will do
echo "Formatting $1 ..."
# use gdisk to create new partition table
# and a single Microsoft basic data partition type
printf 'o\ny\nn\n\n\n\n0700\nw\ny\n' | \
sudo gdisk "$1" && \
sudo mkexfatfs "$1"1
# done
echo "Done"
exit
fi
echo "Formatting aborted"
else
fi
