Lemon
May 2, 2021, 9:00am
1
Hi all,
Did any one of you convert a laptop from bios to uefy successfully?
I want to do that without the whole hassle of reinstalling everything.
Mostly because of the ability to update my firmware.
I’ve read a few tuts on the web and it seems doable but there are probably a couple of difficulties.
I know I have to change mbr to gpt and add a /boot/efi.
Lemon
May 2, 2021, 10:22am
3
There is no other os and the partitions are simple.
Model: ATA Crucial_CT128MX1 (scsi)
Schijf /dev/sda: 128GB
Sectorgrootte (logisch/fysiek): 512B/4096B
Partitietabel: msdos
Schijfvlaggen:
Nummer Begin Einde Grootte Type Bestandssysteem Vlaggen
1 1049kB 119GB 119GB primary ext4
2 119GB 128GB 8882MB primary linux-swap(v1)
Kernel: 5.4.115-1-lts54 x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-lts54
root=UUID=6dcee954-bc8a-4034-86f5-189bf448289a rw intel_idle.max_cstate=1
intel_iommu=off resume=UUID=31fc204a-f877-4128-b63f-ac70b0d5312e
loglevel=3 pci=nocrs
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
dm: LightDM 1.30.0 Distro: EndeavourOS base: Arch Linux
Type: Portable System: Dell product: Inspiron 15-3552 v: 4.4.0
serial: <filter> Chassis: type: 8 serial: <filter>
Mobo: Dell model: ������ v: ��� serial: <filter> UEFI-[Legacy]: Dell
v: 4.4.0 date: 03/06/2018
Battery:
ID-1: BAT0 charge: 28.3 Wh (100.0%) condition: 28.3/41.4 Wh (68.2%)
volts: 17.1 min: 14.8 model: PANASONIC DELL 78V9D63 type: Unknown
serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: Dual Core model: Intel Celeron N3050 bits: 64 type: MCP
arch: Airmont family: 6 model-id: 4C (76) stepping: 3 microcode: 368
cache: L2: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 6400
Speed: 1829 MHz min/max: 480/2160 MHz Core speeds (MHz): 1: 647 2: 604
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: mds mitigation: Clear CPU buffers; SMT disabled
Type: spec_store_bypass status: Not affected
Type: spectre_v1
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional,
IBRS_FW, STIBP: disabled, RSB filling
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:22b1
class-ID: 0300
Device-2: Suyin Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 064e:9209 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: fbdev,modesetting,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 99 size: 350x190mm (13.8x7.5")
diag: 398mm (15.7")
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio
vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:2284 class-ID: 0403
Sound Server-1: ALSA v: k5.4.115-1-lts54 running: yes
Sound Server-2: JACK v: 0.125.0 running: no
Sound Server-3: PulseAudio v: 14.2 running: yes
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell Vostro 3470 driver: ath9k v: kernel port: f040
bus-ID: 01:00.0 chip-ID: 168c:0036 class-ID: 0280
Bluetooth:
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-2.1:11
chip-ID: 0cf3:e005 class-ID: e001
Report: bt-service: disabled note: bt-adapter can't run.
Local Storage: total: 119.24 GiB used: 66.64 GiB (55.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT128MX100SSD1
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: MU03 scheme: MBR
ID-1: / raw-size: 110.97 GiB size: 108.73 GiB (97.98%)
used: 66.62 GiB (61.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.27 GiB used: 20.5 MiB (0.2%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 26.0 C mobo: 45.0 C
Fan Speeds (RPM): cpu: 0
Processes: 159 Uptime: 2d 55m wakeups: 50 Memory: 3.76 GiB
used: 2.18 GiB (58.0%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 10.2.0 Packages: pacman: 1175 lib: 279 Shell: Bash v: 5.1.4
running-in: xfce4-terminal inxi: 3.3.03
Lemon:
UEFI-[Legacy]
check all option in your UEFI
SecureBoot off
Fast Boot off
No CSM
No Legacy
all disks on AHCI
you can check in terminal
inxi -Fxza
test -d /sys/firmware/efi && echo efi || echo bios
sudo efibootmgr -v
So first , 2 ways ,
you will need to create dir /boot/efi , have UUID /boot/efi in /etc/fstab updated , then restore GRUb EFI
Lemon
May 2, 2021, 11:37am
5
Okay, I think I know what to do.
Two things, do I need to backup and restore to get gpt?
It looks like I can do this without restoring a backup with gdisk…
And two, how would I generate a new fstab? Or should I copy the example given?
That would be: /dev/disk/by-partlabel/EFI-system /boot/efi vfat defaults 0 2
$ test -d /sys/firmware/efi && echo efi || echo bios
bios
$ sudo efibootmgr -v
EFI variables are not supported on this system.
for your UUID see ( before chroot )
sudo lsblk -fs
like
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=XXXX-YYYY /boot/efi vfat defaults,noatime 0 2
Echoa
May 2, 2021, 12:39pm
7
If you only have linux installed you can in place convert an mbr EXT4 system to GPT.
You then need to create and setup a /boot/efi and redo your grub setup. This will usually be easiest if you boot from a USB drive in uefi mode then chroot into your install to reinstall grub in uefi mode.
Its more than doable, i did it on my older Dell laptop myself a while ago but exact instructions i dont have atm
Lemon
May 2, 2021, 2:05pm
8
Okay, but I wonder how the correct uuid will be created for /boot/efi?
So, what comes in places for xxxx-yyyy?
UUID (universally unique identifier) of your block device.
The easiest way to find out the UUIDs, in my opinion, is to run
lsblk -f
Lemon
May 2, 2021, 2:27pm
10
Yes, but what I mean is, will the uuid for the efi partition automatically be created?
Since I now only have these.
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
sda
├─sda1 ext4 1.0 6dcee954-bc8a-4034-86f5-189bf448289a 36,1G 62% /
└─sda2 swap 1 31fc204a-f877-4128-b63f-ac70b0d5312e [SWAP]
dalto
May 2, 2021, 3:25pm
12
The UUID will be created when the partition is created. The partition won’t be created for you.
A few things:
How are you planning to convert your disk from MBR/msdos to GPT? I know there are some tools that can do this but be aware it is a fairly risky operation.
There is no reason to create an EFI partition until your disk is converted to GPT.
What you are planning to do is both something of a pain and is risky enough that you shouldn’t do it without a backup.
If you have a backup, wouldn’t it be easier to erase the disk, re-install and then restore your backup?
Based on the questions you are asking above, I am a little fearful this conversion is going to more than you are ready for at this point in your Linux journey.
Lemon
May 2, 2021, 3:45pm
13
Thank you for your confidence Dalto.
If I’m not ready now then I will never be ready for this journey.
I started in 2008.
(Or maybe I’m too dumb…)
dalto
May 2, 2021, 4:05pm
14
Sorry if I offended. It wasn’t my intention. If you feel you are ready for it then things like this make an excellent learning experience.
However, please go into it knowing what you are contemplating doing is not easy. Fundamentally, what you need to do is:
Update your system.
Make a backup.
Use a tool to convert your disk to GPT. After doing this it will no longer boot.
Boot off a Linux ISO.
Resize and relocate your partitions to make room for an EFI partition.
Create an EFI partition manually with the appropriate flags.
Format the EFI partition.
Mount your root partition.
create a boot/efi partition in that mounted partition.
Mount your EFI partition at boot/efi.
Chroot into that mounted system.
Re-install grub for efi.
Modify /etc/fstab with the correct UUIDs for your root and swap partitions.
Add an entry for your EFI partition.
Exit the chroot.
Unmount all the partitions.
Boot into your BIOS and select the efi as your default boot device. (This is only needed because it is probably currently set to legacy boot from a specific partition)
Hope everything works, if not, troubleshoot from there.
Please note, I haven’t tried the above, that is just how I would think through it. It is possible I missed steps.
I don’t think you will find a perfect tutorial where you can copy/paste commands. It will probably take some exploration and interpretation.
Lemon
May 2, 2021, 5:06pm
15
Well, I followed all steps but there is one thing missing out.
$ lsblk -f
sda
├─sda1
│ ext4 1.0 6dcee954-bc8a-4034-86f5-189bf448289a 37,6G 60% /
├─sda2
│ swap 1 31fc204a-f877-4128-b63f-ac70b0d5312e [SWAP]
└─sda3
vfat FAT32 EFI-SYSTEM
2A52-C405 470,1M 0% /boot/efi
fstab:
UUID=6dcee954-bc8a-4034-86f5-189bf448289a / ext4 rw,noatime,data=ordered 0 1
UUID=31fc204a-f877-4128-b63f-ac70b0d5312e swap swap defaults 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
UUID=2A52-C405 /boot/efi vfat defaults,noatime 0
I regenerated grub with the usual command; sudo grub-mkconfig -o /boot/grub/grub.cfg
But it won’t boot.
dalto
May 2, 2021, 5:09pm
16
You need to re-install grub, not just regenerate the config for it.
https://wiki.archlinux.org/title/GRUB#Installation_2
Be sure to boot the ISO in efi mode so you can do an efi install of grub.
Perhaps also put boot and esp flag on the EFI System Partition.
Lemon
May 2, 2021, 5:20pm
18
And it’s done!
It boots just fine.
I had to install grub.
dalto
May 2, 2021, 5:22pm
19
The flags shouldn’t matter as long the type is correct.
Lemon:
And it’s done!
Congrats!
