I will place you for those who would like to use after effect with wine the procedure to follow. The code below must be pasted into a text file following this procedure:
nano after_effect.sh
Paste code
#!/bin/bash
WINEARCH=win32 WINEPREFIX=~/.after_effect_cs4 wineboot
mkdir $HOME/.cache/winetricks/msxml3/
wget -P $HOME/.cache/winetricks/msxml3/ http://repository.playonlinux.com/divers/msxml3.msi
WINEPREFIX=$HOME/.after_effect_cs4/ wine msiexec /i $HOME/.cache/winetricks/msxml3/msxml3.msi
regsvr32 msxml3.dll
WINEPREFIX=$HOME/.after_effect_cs4/ winetricks atmlib riched20 riched30 msxml6 gdiplus quicktime76 vcrun2005 vcrun2008 vcrun2010 xvid wmp9 vcrun6sp6
WINEPREFIX=$HOME/.after_effect_cs4/ wineserver -w
echo "-- Run setup #WINEPREFIX=$HOME/.after_effect_cs4/ winecfg and set Windows XP default system --"
echo "-- Run setup #WINEPREFIX=$HOME/.after_effect_cs4/ wine setupadobe.exe --"
echo "-- Befere install After Effects /home/USERNAME/.after_effect_cs4/drive_c/Program Files/Adobe/Adobe After Effects CS4/Support Files/Plug-ins/Format --"
echo "-- Rename CNImported.AEX file to -> CNImported.AEX.old --"
echo "-- Rename WMImport.AEX file to -> WMImport.AEX.old --"
echo "-- Install Adobe CS4 and enjoy --"
echo "-- Windows media player 10 not install and error import Windows Media Player --"
echo "-- Plugin working complete --"
Change permission after_effect.sh
chmod 777 after_effect.sh
Run the terminal script as a normal user and not as root.
