275 packages are waiting .... see whats going on on commandline
hi dear community
currently 275 updates in the queue
see what happens here on commandline
==> yay
[sudo] Passwort für martin:
:: Paketdatenbanken werden synchronisiert …
 endeavouros                      28,8 KiB  24,2 KiB/s 00:01 [--------------------------------] 100%
 core                            132,2 KiB   121 KiB/s 00:01 [--------------------------------] 100%
 extra                             8,3 MiB  1303 KiB/s 00:07 [--------------------------------] 100%
 community ist aktuell
 multilib                        141,3 KiB   168 KiB/s 00:01 [--------------------------------] 100%
:: Durchsuche AUR nach Updates...
:: Durchsuche Datenbanken nach Updates...
 -> 1 error occurred:
	* request failed: Get "https://aur.archlinux.org/rpc?arg%5B%5D=arc-x-icons-theme&arg%5B%5D=celt&arg%5B%5D=gn-m87&arg%5B%5D=grub-tools&arg%5B%5D=grub2-theme-endeavouros&arg%5B%5D=ipw2100-fw&arg%5B%5D=ipw2200-fw&arg%5B%5D=js78&arg%5B%5D=libsidplay&arg%5B%5D=metis&arg%5B%5D=paper-icon-theme&arg%5B%5D=pcurses&arg%5B%5D=python2&arg%5B%5D=visual-studio-code-bin&arg%5B%5D=wavemon-git&arg%5B%5D=woeusb&type=info&v=5": net/http: TLS handshake timeout
Drücke ENTER um dieses Fenster zu schließen:
That looks like a network error. What happens if you try it again?
hi dalto - many thanks for the reply - youre right. Now it runs very well! without any trouble…
btw see the comments - what was noted at the end
Gesamt (112/112)                508,5 MiB  1090 KiB/s 07:58 [--------------------------------] 100%
(246/246) Schlüssel im Schlüsselbund werden geprüft          [--------------------------------] 100%
(246/246) Paket-Integrität wird überprüft                    [--------------------------------] 100%
Fehler: endeavouros-mirrorlist: signature from "manuel <manuel@endeavouros.com>" is unknown trust
:: Datei /var/cache/pacman/pkg/endeavouros-mirrorlist-23.5-1-any.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigtes Paket (PGP-Signatur)).
Soll die Datei entfernt werden? [J/n]
see - that the many keys are broken - i need to rework it
Soll die Datei entfernt werden? [J/n] j
Fehler: endeavouros-theming: signature from "manuel <manuel@endeavouros.com>" is unknown trust
:: Datei /var/cache/pacman/pkg/endeavouros-theming-22.12.3.3-2-any.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigtes Paket (PGP-Signatur)).
Fehler: yad: signature from "manuel <manuel@endeavouros.com>" is unknown trust
:: Datei /var/cache/pacman/pkg/yad-13.0-1.1-x86_64.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigtes Paket (PGP-Signatur)).
Fehler: eos-rankmirrors: signature from "manuel <manuel@endeavouros.com>" is unknown trust
:: Datei /var/cache/pacman/pkg/eos-rankmirrors-2.14-1-any.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigtes Paket (PGP-Signatur)).
Fehler: welcome: signature from "manuel <manuel@endeavouros.com>" is unknown trust
:: Datei /var/cache/pacman/pkg/welcome-3.64-1-any.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigtes Paket (PGP-Signatur)).
Fehler: yay: signature from "manuel <manuel@endeavouros.com>" is unknown trust
:: Datei /var/cache/pacman/pkg/yay-12.0.5-1-x86_64.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigtes Paket (PGP-Signatur)).
well no package would be updated - all that things failed…
Fehler: Der Vorgang konnte nicht durchgeführt werden (Ungültiges oder beschädigtes Paket (PGP-Signatur))
Fehler sind aufgetreten, keine Pakete wurden aktualisiert.
 -> error installing repo packages
i need to rework all
i did this and it worked like a charme
yay -Sy archlinux-keyring endeavouros-keyring --noconfirm
yay --noconfirm
You have been told how to fix that multiple times already. Here are 4 separate topics you created where you were given this answer:
