Ok, it did still not change the zoom screen share window transparency for full desktop share.
Do you think it’s possible that installing i3wm over the xfce install could have messed up with my compositor or something running in the background? I am just wondering at this point if I should reinstall EOS on this laptop using your new iso for i3wm, or switch to my xfce session for now and see how that goes.
I have a workshop next week Tue/Wed and would love to use i3 as it is very easy to switch and focus windows using my keyboard. Stupid me, I only discovered i3 last weekend…
Edit: can actually confirm that log into my xfce session, sharing screen via zoom works flawlessly. Probably better not to mess around under stress situation.
Did you disable window effects in effects on Cinnamon in the menu? That causes Transparency on the Welcome screen so could be that if you haven’t disabled it.
On the laptop with cinnammon… it was disabled already. Tried playing with other settings without luck. Have to troubleshoot the hybrid grafics card issue and post another thread, last system update borked my system due to python upgrade and optimus. will see if troubleshooting that will fix the flickering screen share on zoom too.
The easiest would be if someone else with cinnamon can test and confirm the zoom screen sharing works flawlessly. Perhaps which install method they used.
Looks like xfce and kde are good to go. Which means zoom should work on both qt and gtk based DE.
I used cinnamon on this laptop because the other DE did not enable me to deal with high dpi screen issues, moved over recently from kde, see my thread.
Ha, I tried fedora about a month ago, starting zoom refused because I was on wayland and had to switch to xorg. Guess they fixed that. Are you using i3 and wayland, is that possible? Hopefully thats not a dumb question, I am not versed at wm stuff…
I fixed my cinnamon install on my lenovo P1 gen2 with hybrid graphics. Took my a while to read all the infos out there. Now my zoom screen share is back to normal, no more flickering on zoom! Win #2!
Hopefully that will last, will have to test connecting/disconnecting external monitor. Also what I learned is that in hybrid mode the laptop basically uses the intel card with lower power consumption, while connecting an external screen directly connects to the nvidia GPU Quadro P2000. One can also decide to switch the bios to only discrete GPU but it would drain more heavily the battery.
