please excuse my question again. I want to use a game with Wine and i don’t get it. I used the wiki of archlinux.de and i tried to follow the instructions.
sudo pacman -S wine
sudo nano /etc/pacman.conf
For using x86_64 i had to enable
[multilib]
Include = /etc/pacman.d/mirrorlist
I couldn’t help myself, but i couldn’t start/open the Epic Game Store Launcher.
[sandro@sandro-pc ~]$ winecfg
0009:err:module:load_so_dll failed to load .so lib "/usr/bin/../lib32/wine/l3codeca.acm.so": libmpg123.so.0: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
^C002c:fixme:console:CONSOLE_DefaultHandler Terminating process 8 on event 0
002d:fixme:console:CONSOLE_DefaultHandler Terminating process 2a on event 0
What else should i try, to make this thingy running?
That’s it. Thank you.
But now i have the problem to continue.
[sandro@sandro-pc ~]$ wine EpicGamesLauncher.exe
0009:err:module:__wine_process_init L"C:\\windows\\system32\\EpicGamesLauncher.exe" not found
[sandro@sandro-pc ~]$ wine EpicGamesLauncher.msi
0009:err:module:__wine_process_init L"C:\\windows\\system32\\EpicGamesLauncher.msi" not found
I guess i can’t find this folders in my system, because it belongs to wine and isn’t a real folder?
pacman -Qs:
Microsoft Publisher file format parser library (latest snapshot)
local/libmtp 1.1.17-1
Library implementation of the Media Transfer Protocol
local/libmwaw 0.3.15-1
Import library for some old mac text documents.
local/libmypaint 1.4.0-1
Library for making brushstrokes which is used by MyPaint and other projects
local/libndp 1.7-1
Library for Neighbor Discovery Protocol
local/libnetfilter_conntrack 1.0.7-1
Library providing an API to the in-kernel connection tracking state table
local/libnewt 0.52.21-3
Not Erik's Windowing Toolkit - text mode windowing with slang
local/libnfnetlink 1.0.1-3
Low-level library for netfilter related kernel/userspace communication
local/libnfs 4.0.0-3
client library for accessing NFS shares
local/libnftnl 1.1.5-1
Netfilter library providing interface to the nf_tables subsystem
local/libnghttp2 1.39.2-2
Framing layer of HTTP/2 is implemented as a reusable C library
local/libnice 0.1.16-1
An implementation of the IETF's draft ICE (for p2p UDP data streams)
local/libnl 3.5.0-2
Library for applications dealing with netlink sockets
local/libnm 1.22.6-1
NetworkManager client library
local/libnma 1.8.24-1
NetworkManager GUI client library
local/libnotify 0.7.8-1
Library for sending desktop notifications
local/libnsl 1.2.0-2
Public client interface library for NIS(YP) and NIS+
local/libnumbertext 1.0.5-1
Number to number name and money text conversion library
local/libodfgen 0.1.7-1
Library for generating documents in Open Document Format
local/libofa 0.9.3-8
An open-source audio fingerprint by MusicIP
local/libogg 1.3.4-1
Ogg bitstream and framing library
local/libomxil-bellagio 0.9.3-2
An opensource implementation of the OpenMAX Integration Layer API
local/libopenraw 0.1.3-1
Library for decoding RAW files
local/liborcus 0.15.3-1
File import filter library for spreadsheet documents.
local/libpagemaker 0.0.4-2
a library that parses the file format of Aldus/Adobe PageMaker documents
local/libpcap 1.9.1-2
A system-independent interface for user-level packet capture
local/libpciaccess 0.16-1
X11 PCI access library
local/libpgm 5.2.122-5
OpenPGM: implementation of the Pragmatic General Multicast (PGM, RFC3208)
local/libpipeline 1.5.2-1
a C library for manipulating pipelines of subprocesses in a flexible and
convenient way
local/libplist 2.1.0-2
A library to handle Apple Property List format whereas it's binary or XML
local/libpng 1.6.37-1
A collection of routines used to create PNG format graphics files
local/libproxy 0.4.15-13
A library that provides automatic proxy configuration management
local/libpsl 0.21.0-2
Public Suffix List library
local/libpulse 13.0-3
A featureful, general-purpose sound server (client library)
local/libpwquality 1.4.2-2
Library for password quality checking and generating random passwords
local/libqmi 1.24.4-1
QMI modem protocol helper library
local/libqxp 0.0.2-3
a library that parses the file format of QuarkXPress documents
local/libraqm 0.7.0-1
A library that encapsulates the logic for complex text layout
local/libraw 0.19.5-2
A library for reading RAW files obtained from digital photo cameras
(CRW/CR2, NEF, RAF, DNG, and others)
local/libraw1394 2.1.2-2
Provides an API to the Linux IEEE1394 (FireWire) driver
local/libreoffice-fresh 6.4.0-2
LibreOffice branch which contains new features and program enhancements
local/librevenge 0.0.4-2
library for REVerses ENGineered formats filters
local/librsvg 2:2.46.4-1
SVG rendering library
local/libsamplerate 0.1.9-3
Secret Rabbit Code - aka Sample Rate Converter for audio
local/libsasl 2.1.27-2
Cyrus Simple Authentication Service Layer (SASL) Library
local/libseccomp 2.4.1-3
Enhanced seccomp library
local/libsecret 0.20.1-1
Library for storing and retrieving passwords and other secrets
local/libshout 1:2.4.3-2
Library for accessing a shoutcast/icecast server
local/libsidplay 1.36.59-9
A library for playing SID music files.
local/libsigc++ 2.10.2-1
Libsigc++ implements a full callback system for use in widget libraries - V2
local/libsm 1.2.3-1
X11 Session Management library
local/libsndfile 1.0.28-3
A C library for reading and writing files containing sampled sound
local/libsodium 1.0.18-1
P(ortable|ackageable) NaCl-based crypto library
local/libsoup 2.68.3-1
HTTP client/server library for GNOME
local/libsoxr 0.1.3-1
The SoX Resampler library that aims to give fast and high quality results
for any constant resampling ratio
local/libspiro 1:20190731-1
Simplifies the drawing of beautiful curves
local/libsrtp 1:2.3.0-1
Library for SRTP (Secure Realtime Transport Protocol)
local/libssh 0.9.3-1
Library for accessing ssh client services through C libraries
local/libssh2 1.9.0-2
A library implementing the SSH2 protocol as defined by Internet Drafts
local/libstaroffice 0.0.6-1
filter for old StarOffice documents(.sdc, .sdw, ...) based on librevenge
local/libtasn1 4.15.0-1
The ASN.1 library used in GNUTLS
local/libteam 1.30-1
Library for controlling team network device
local/libthai 0.1.28-1
Thai language support routines
local/libtheora 1.1.1-4
An open video codec developed by the Xiph.org
local/libtiff 4.1.0-1
Library for manipulation of TIFF images
local/libtiger 0.3.4-5
A rendering library for Kate streams using Pango and Cairo
local/libtirpc 1.2.5-1
Transport Independent RPC library (SunRPC replacement)
local/libtommath 1.2.0-1
Highly optimized and portable routines for integer based number theoretic
applications
local/libtool 2.4.6+42+gb88cebd5-8 (base-devel)
A generic library support script
local/libunistring 0.9.10-2
Library for manipulating Unicode strings and C strings
local/libunwind 1.3.1-1
Portable and efficient C programming interface (API) to determine the
call-chain of a program
local/libusb 1.0.23-2
Library that provides generic access to USB devices
local/libusbmuxd 2.0.0-2
USB Multiplex Daemon
local/libutil-linux 2.35.1-1
util-linux runtime libraries
local/libuv 1.34.2-1
Multi-platform support library with a focus on asynchronous I/O
local/libva 2.6.1-1
Video Acceleration (VA) API for Linux
local/libvdpau 1.3-1
Nvidia VDPAU library
local/libvisio 0.1.7-2
Library providing ability to interpret and import visio diagrams
local/libvisual 0.4.0-7
Abstraction library that comes between applications and audio visualisation
plugins
local/libvoikko 4.3-1
A spelling and grammar checker, hyphenator and collection of related
linguistic data for Finnish language
local/libvorbis 1.3.6-1
Vorbis codec library
local/libvpx 1.8.2-1
VP8 and VP9 codec
local/libwacom 1.2-1
Library to identify Wacom tablets and their features
local/libwbclient 4.10.10-2
Samba winbind client library
local/libwebp 1.1.0-1
WebP library and conversion tools
local/libwmf 0.2.12-1
A library for reading vector images in Microsoft's native Windows Metafile
Format (WMF)
local/libwnck3 3.32.0-2
Library to manage X windows and workspaces (via pagers, tasklists, etc.)
local/libwpd 0.10.3-1
Library for importing WordPerfect (tm) documents
local/libwpe 1.4.0.1-1
General-purpose library for WPE WebKit
local/libwpg 0.3.3-1
Library for importing and converting Corel WordPerfect(tm) Graphics images.
local/libwps 0.4.10-1
a Microsoft Works file word processor format import filter library
local/libx11 1.6.9-6
X11 client-side library
local/libx86emu 2.4-1
x86 emulation library
local/libxau 1.0.9-2
X11 authorisation library
local/libxcb 1.13.1-1
local/libxcomposite 0.4.5-2
X11 Composite extension library
local/libxcursor 1.2.0-1
X cursor management library
local/libxdamage 1.1.5-2
X11 damaged region extension library
local/libxdmcp 1.1.3-2
X11 Display Manager Control Protocol library
local/libxext 1.3.4-2
X11 miscellaneous extensions library
local/libxfce4ui 4.14.1-2
Commonly used Xfce widgets among Xfce applications
local/libxfce4util 4.14.0-1
Basic utility non-GUI functions for Xfce
local/libxfixes 5.0.3-3
X11 miscellaneous 'fixes' extension library
local/libxfont2 2.0.4-2
X11 font rasterisation library
local/libxft 2.3.3-1
FreeType-based font drawing library for X
local/libxi 1.7.10-2
X11 Input extension library
local/libxinerama 1.1.4-2
X11 Xinerama extension library
local/libxkbcommon 0.10.0-1
Keymap handling library for toolkits and window systems
local/libxkbcommon-x11 0.10.0-1
Keyboard handling library using XKB data for X11 XCB clients
local/libxkbfile 1.1.0-1
X11 keyboard file manipulation library
local/libxklavier 5.4-2
High-level API for X Keyboard Extension
local/libxml2 2.9.10-1
XML parsing library, version 2
local/libxmu 1.1.3-1
X11 miscellaneous micro-utility library
local/libxpm 3.5.13-1
X11 pixmap library
local/libxpresent 1.0.0-2
X Present Extension library
local/libxrandr 1.5.2-2
X11 RandR extension library
local/libxrender 0.9.10-3
X Rendering Extension client library
local/libxres 1.2.0-1
X11 Resource extension library
local/libxshmfence 1.3-1
a library that exposes a event API on top of Linux futexes
local/libxslt 1.1.34-2
XML stylesheet transformation library
local/libxss 1.2.3-2
X11 Screen Saver extension library
local/libxt 1.2.0-1
X11 toolkit intrinsics library
local/libxtst 1.2.3-3
X11 Testing -- Resource extension library
local/libxv 1.0.11-3
X11 Video extension library
local/libxvmc 1.0.12-2
X11 Video Motion Compensation extension library
local/libxxf86vm 1.1.4-3
X11 XFree86 video mode extension library
local/libyaml 0.2.2-1
YAML 1.1 library
local/libzmf 0.0.2-7
a library for import of Zoner drawing and bitmap files
local/licenses 20191011-2
Standard licenses distribution package
local/lightdm 1:1.30.0-2
A lightweight display manager
local/lightdm-gtk-greeter 1:2.0.7-1
GTK+ greeter for LightDM
local/lightdm-gtk-greeter-settings 1.2.2-4
Settings editor for the LightDM GTK+ Greeter
local/lilv 0.24.6-2
A C library interface to the LV2 plug-in standard
local/linux 5.5.1.arch1-1
The Linux kernel and modules
local/linux-api-headers 5.3.1-2
Kernel headers sanitized for use in userspace
local/linux-atm 2.5.2-6
Drivers and tools to support ATM networking under Linux.
local/linux-firmware 20200122.1eb2408-1
Firmware files for Linux
local/linux-headers 5.5.1.arch1-1
Headers and scripts for building modules for the Linux kernel
local/linux-lts 4.19.101-1
The LTS Linux kernel and modules
local/linux-lts-headers 4.19.101-1
Headers and scripts for building modules for the LTS Linux kernel
local/llvm-libs 9.0.1-1
LLVM runtime libraries
local/lm_sensors 3.6.0-1
Collection of user space tools for general SMBus access and hardware
monitoring
local/lmdb 0.9.24-1
Symas Lightning Memory-Mapped Database
local/logrotate 3.15.1-2
Rotates system logs automatically
local/lpsolve 5.5.2.5-3
a Mixed Integer Linear Programming (MILP) solver
local/lsb-release 1.4-15
LSB version query program
local/lsscsi 0.30-1
A tool that lists devices connected via SCSI and its transports
local/luajit 2.0.5-2
Just-in-time compiler and drop-in replacement for Lua 5.1
local/lv2 1.16.0-3
Plugin standard for audio systems
local/lvm2 2.02.186-5
Logical Volume Manager 2 utilities
local/lz4 1:1.9.2-2
Extremely fast compression algorithm
local/lzo 2.10-3
Portable lossless data compression library
local/m4 1.4.18-3 (base-devel)
The GNU macro processor
local/mailcap 2.1.48+14+g5811758-1
Helper application and MIME type associations for file types
local/make 4.2.1-4 (base-devel)
GNU make utility to maintain groups of programs
local/man-db 2.9.0-1
A utility for reading man pages
local/man-pages 5.04-2
Linux man pages
local/mc 4.8.24-1
A file manager that emulates Norton Commander
local/md4c 0.4.2-1
C Markdown parser
local/mdadm 4.1-2
A tool for managing/monitoring Linux md device arrays, also known as
Software RAID
local/memtest86+ 5.01-3
An advanced memory diagnostic tool
local/mesa 19.3.3-1
An open-source implementation of the OpenGL specification
local/metis 5.1.0.p7-1
A set of serial programs for partitioning graphs, partitioning finite
element meshes, and producing fill reducing orderings for sparse matrices
local/mjpegtools 2.1.0-4
Set of tools that can do recording of videos and playback, simple
cut-and-paste editing and the MPEG compression of audio and video
local/mkinitcpio 27-2
Modular initramfs image creation utility
local/mkinitcpio-busybox 1.31.1-1
Base initramfs tools
local/mkinitcpio-nfs-utils 0.3-7
ipconfig and nfsmount tools for NFS root support in mkinitcpio
local/mlocate 0.26.git.20170220-2
Merging locate/updatedb implementation
local/mobile-broadband-provider-info 20190618-1
Network Management daemon
local/modemmanager 1.12.4-1
Mobile broadband modem management service
local/mousepad 0.4.2-2 (xfce4-goodies)
Simple text editor for Xfce
local/mozilla-common 1.4-5
Common Initialization Profile for Mozilla.org products
local/mpfr 4.0.2-2
Multiple-precision floating-point library
local/mpg123 1.25.13-1
Console based real time MPEG Audio Player for Layer 1, 2 and 3
local/mtdev 1.1.6-1
A stand-alone library which transforms all variants of kernel MT events to
the slotted type B protocol
local/mtools 4.0.23-1
A collection of utilities to access MS-DOS disks
local/mypaint-brushes1 1.3.0-1
Brushes used by MyPaint and other software using libmypaint (v1.x)
local/nano 4.7-1
Pico editor clone with enhancements
local/nbd 3.20-1
tools for network block devices, allowing you to use remote block devices
over TCP/IP
local/ncurses 6.1-7
System V Release 4.0 curses emulation library
local/ndctl 67-1
Utility library for managing the libnvdimm (non-volatile memory device)
sub-system in the Linux kernel
local/ndisc6 1.0.4-1
Collection of IPv6 networking utilities
local/neon 0.30.2-3
HTTP and WebDAV client library with a C interface
local/net-tools 1.60.20181103git-2
Configuration tools for Linux networking
local/netctl 1.20-2
Profile based systemd network management
local/nettle 3.5.1-2
A low-level cryptographic library
local/network-manager-applet 1.8.24-1
Applet for managing network connections
local/networkmanager 1.22.6-1 (gnome)
Network connection manager and user applications
local/networkmanager-openvpn 1.8.10-1
NetworkManager VPN plugin for OpenVPN
local/nfs-utils 2.4.2-1
Support programs for Network File Systems
local/nfsidmap 2.4.2-1
Library to help mapping IDs, mainly for NFSv4
local/nilfs-utils 2.2.8-2
A log-structured file system supporting continuous snapshotting (userspace
utils)
local/nm-connection-editor 1.8.24-1
NetworkManager GUI connection editor and widgets
local/nodejs 13.7.0-1
Evented I/O for V8 javascript
local/noto-fonts 20190926-4
Google Noto TTF fonts
local/noto-fonts-cjk 20190409-1
Google Noto CJK fonts
local/npth 1.6-2
New portable threads library
local/nspr 4.24-1
Netscape Portable Runtime
local/nss 3.49.2-3
Network Security Services
local/nss-mdns 0.14.1-2
glibc plugin providing host name resolution via mDNS
local/ntfs-3g 2017.3.23-3
NTFS filesystem driver and utilities
local/ntp 4.2.8.p13-2
Network Time Protocol reference implementation
local/nvidia-installer-db 2.1-5
Database for the script to setup nvidia drivers in EndeavourOS
local/nvidia-installer-dkms 3-2
Script to setup nvidia drivers (dkms version) in EndeavourOS
local/openal 1.20.1-1
Cross-platform 3D audio library, software implementation
local/openconnect 1:8.05-1
Open client for Cisco AnyConnect VPN
local/opencore-amr 0.1.5-3
Open source implementation of the Adaptive Multi Rate (AMR) speech codec
local/opendesktop-fonts 1.4.2-5
Chinese TrueType Fonts
local/openexr 2.4.0-7
An high dynamic-range image file format library
local/openjpeg2 2.3.1-1
An open source JPEG 2000 codec, version 2.3.1
local/openmpi 4.0.2-3
High performance message passing library (MPI)
local/openresolv 3.10.0-1
resolv.conf management framework (resolvconf)
local/openssh 8.1p1-2
Premier connectivity tool for remote login with the SSH protocol
local/openssl 1.1.1.d-2
The Open Source toolkit for Secure Sockets Layer and Transport Layer
Security
local/openssl-1.0 1.0.2.u-1
Security
local/openvpn 2.4.8-4
An easy-to-use, robust and highly configurable VPN (Virtual Private Network)
local/opus 1.3.1-1
Totally open, royalty-free, highly versatile audio codec
local/orage 4.12.1-4 (xfce4-goodies)
A simple calendar application with reminders for Xfce
local/orc 0.4.31-1
Optimized Inner Loop Runtime Compiler
local/os-prober 1.77-1
Utility to detect other OSes on a set of drives
local/p11-kit 0.23.20-2
Provides a way to load and enumerate PKCS#11 modules
local/pacman 5.2.1-4 (base-devel)
A library-based package manager with dependency support
local/pacman-contrib 1.3.0-1
Contributed scripts and tools for pacman systems
local/pacman-mirrorlist 20200103-1
Arch Linux mirror list for use by pacman
local/pam 1.3.1-2
PAM (Pluggable Authentication Modules) library
local/pambase 20190105.1-2
Base PAM configuration for services
local/pango 1:1.44.7-1
A library for layout and rendering of text
local/pangomm 2.42.0-1
C++ bindings for Pango
local/paper-icon-theme 1.5.0-2
Paper is an open source desktop theme and icon project by Sam Hewitt
local/parole 1.0.5-1 (xfce4-goodies)
Modern media player based on the GStreamer framework
local/parted 3.3-1
A program for creating, destroying, resizing, checking and copying
partitions
local/patch 2.7.6-8 (base-devel)
A utility to apply patch files to original sources
local/pavucontrol 1:4.0-1
PulseAudio Volume Control
local/pciutils 3.6.2-2
PCI bus configuration space access library and tools
local/pcre 8.43-2
A library that implements Perl 5-style regular expressions
local/pcre2 10.34-3
A library that implements Perl 5-style regular expressions. 2nd version
local/pcsclite 1.8.26-1
PC/SC Architecture smartcard middleware library
local/pcurses 5-2
A curses package management tool using libalpm
local/perl 5.30.1-1
A highly capable, feature-rich programming language
local/perl-error 0.17029-1
Perl/CPAN Error module - Error/exception handling in an OO-ish way
local/perl-mailtools 2.21-2
Various e-mail related modules
local/perl-timedate 2.31-1
Date formating subroutines
local/perl-uri 1.76-2
Uniform Resource Identifiers (absolute and relative)
local/pinentry 1.1.0-5
Collection of simple PIN or passphrase entry dialogs which utilize the
Assuan protocol
local/pixman 0.38.4-1
The pixel-manipulation library for X and cairo
local/pkcs11-helper 1.26.0-1
A library that simplifies the interaction with PKCS11 providers for end-user
applications using a simple API and optional OpenSSL engine
local/pkgconf 1.6.3-3 (base-devel)
Package compiler and linker metadata toolkit
local/pkgfile 21-1
a pacman .files metadata explorer
local/polkit 0.116-3
Application development toolkit for controlling system-wide privileges
local/polkit-gnome 0.105-4
Legacy polkit authentication agent for GNOME
local/poppler 0.85.0-1
PDF rendering library based on xpdf 3.0
local/poppler-data 0.4.9-1
Encoding data for the poppler PDF rendering library
local/poppler-glib 0.85.0-1
Poppler glib bindings
local/popt 1.16-12
A commandline option parser
local/portaudio 1:19.6.0-6
A free, cross-platform, open source, audio I/O library.
local/ppp 2.4.7-6
A daemon which implements the Point-to-Point Protocol for dial-up networking
local/pptpclient 1.10.0-2
Client for the proprietary Microsoft Point-to-Point Tunneling Protocol,
PPTP.
local/procps-ng 3.3.15-2
Utilities for monitoring your system and its processes
local/psmisc 23.3-2
Miscellaneous procfs tools
local/pulseaudio 13.0-3
local/pulseaudio-alsa 2-5
ALSA Configuration for PulseAudio
local/pulseaudio-bluetooth 13.0-3
Bluetooth support for PulseAudio
local/pulseaudio-jack 13.0-3
Jack support for PulseAudio
local/pygobject-devel 3.34.0-3
Common development files for pygobject
local/pygtk 2.24.0-8
Python bindings for the GTK widget set
local/python 3.8.1-4
Next generation of the python high-level scripting language
local/python-appdirs 1.4.3-5
A small Python module for determining appropriate platform-specific dirs,
e.g. a "user data dir".
local/python-dbus 1.2.16-1
Python bindings for DBUS
local/python-dbus-common 1.2.16-1
Common dbus-python files shared between python-dbus and python2-dbus
local/python-future 0.18.2-2
Clean single-source support for Python 3 and 2
local/python-gobject 3.34.0-3
Python Bindings for GLib/GObject/GIO/GTK+
local/python-ordered-set 3.1.1-1
A MutableSet that remembers its order, so that every entry has an index
local/python-packaging 20.0-1
Core utilities for Python packages
local/python-ply 3.11-4
Implementation of lex and yacc parsing tools
local/python-psutil 5.6.7-1
A cross-platform process and system utilities module for Python
local/python-pyparsing 2.4.6-1
General parsing module for Python
local/python-setuptools 1:44.0.0-1
Easily download, build, install, upgrade, and uninstall Python packages
local/python-six 1.14.0-1
Python 2 and 3 compatibility utilities
local/python-urwid 2.1.0-1
Curses-based user interface library
local/python2 2.7.17-1
A high-level scripting language
local/python2-cairo 1.18.2-4
Python bindings for the cairo graphics library
local/python2-gobject2 2.28.7-4
Legacy Python 2 bindings for GObject
local/qt5-base 5.14.1-1 (qt qt5)
A cross-platform application and UI framework
local/qt5-declarative 5.14.1-1 (qt qt5)
Classes for QML and JavaScript languages
local/qt5-wayland 5.14.1-1 (qt qt5)
Provides APIs for Wayland
local/qt5-x11extras 5.14.1-1 (qt qt5)
Provides platform-specific APIs for X11
local/raptor 2.0.15-12
A C library that parses RDF/XML/N-Triples into RDF triples
local/rasqal 1:0.9.33-2
A free C library that handles Resource Description Framework (RDF) query
syntaxes, query construction and query execution returning result bindings
local/readline 8.0.001-2
GNU readline library
local/redland 1:1.0.17-7
Library that provides a high-level interface to RDF data
local/refind-efi 0.11.3-1
Rod Smith's fork of rEFIt UEFI Boot Manager - Built with Tianocore EDK2 libs
local/reflector 2019.10-2
A Python 3 module and script to retrieve and filter the latest Pacman mirror
list.
local/reflector-simple 1.1-1
Simple GUI wrapper for 'reflector'.
local/reiserfsprogs 3.6.27-3
Reiserfs utilities
local/rest 0.8.1-1
Helper library for RESTful services
local/ristretto 0.10.0-2 (xfce4-goodies)
Fast and lightweight picture-viewer for Xfce4
local/rp-pppoe 3.13-1
Roaring Penguin's Point-to-Point Protocol over Ethernet client
local/rpcbind 1.2.5-3
portmap replacement which supports RPC over various protocols
local/rsync 3.1.3-3
A file transfer program to keep remote files in sync
local/rtkit 0.12-1
Realtime Policy and Watchdog Daemon
local/rtmpdump 1:2.4.r96.fa8646d-5
Tool to download rtmp streams
local/s-nail 14.9.16-2
Environment for sending and receiving mail
local/s-tui 1.0.0-1
Terminal UI stress test and monitoring tool
local/sbc 1.4-1
Bluetooth Subband Codec (SBC) library
local/screenfetch 3.9.1-1
CLI Bash script to show system/theme info in screenshots
local/sdl 1.2.15-13
A library for portable low-level access to a video framebuffer, audio
output, mouse, and keyboard
local/sdl2 2.0.10-1
output, mouse, and keyboard (Version 2)
local/sdparm 1.10-3
An utility similar to hdparm but for SCSI devices
local/sed 4.8-1 (base-devel)
GNU stream editor
local/serd 0.30.2-1
Lightweight C library for RDF syntax supporting reading/ writing Turtle and
NTriples.
local/sg3_utils 1.44-1
Generic SCSI utilities
local/shadow 4.8-1
Password and account management tool suite with support for shadow files and
PAM
local/shared-mime-info 1.15-2
Freedesktop.org Shared MIME Info
local/slang 2.3.2-1
S-Lang is a powerful interpreted language
local/smartmontools 7.1-1
Control and monitor S.M.A.R.T. enabled ATA and SCSI Hard Drives
local/smbclient 4.10.10-2
Tools to access a server's filespace and printers via SMB
local/sord 0.16.4-1
A lightweight C library for storing RDF data in memory
local/sound-theme-freedesktop 0.8-3
Freedesktop sound theme
local/soundtouch 2.1.2-1
An audio processing library
local/spandsp 0.0.6-2
A DSP library for telephony
local/speex 1.2.0-2
A free codec for free speech
local/speexdsp 1.2.0-1
DSP library derived from Speex
local/sqlite 3.31.1-1
A C library that implements an SQL database engine
local/sratom 0.6.4-1
An LV2 Atom RDF serialisation library
local/srt 1.4.1-1
Secure Reliable Transport library
local/startup-notification 0.12-6
Monitor and display application startup
local/stoken 0.92-3
RSA SecurID-compatible software token for Linux/UNIX systems
local/stress 1.0.4-5
A tool that stress tests your system (CPU, memory, I/O, disks)
local/sudo 1.8.31-1 (base-devel)
Give certain users the ability to run some commands as root
local/suitesparse 5.6.0-1
A collection of sparse matrix libraries
local/sysfsutils 2.1.0-11
System Utilities Based on Sysfs
local/systemd 244.1-1
system and service manager
local/systemd-libs 244.1-1
systemd client libraries
local/systemd-sysvcompat 244.1-1
sysvinit compat for systemd
local/taglib 1.11.1-3
A Library for reading and editing the meta-data of several popular audio
formats
local/talloc 2.3.1-1
Hierarchical pool based memory allocator with destructors
local/tar 1.32-3
Utility used to store, backup, and transport files
local/tcl 8.6.10-1
The Tcl scripting language
local/tcpdump 4.9.3-1
Powerful command-line packet analyzer
local/tdb 1.3.18-4
A Trivial Database similar to GDBM but allows simultaneous commits
local/tevent 1:0.9.39-4
An event system based on the talloc memory management library
local/texinfo 6.7-2 (base-devel)
GNU documentation system for on-line information and printed output
local/thin-provisioning-tools 0.8.5-3
Suite of tools for manipulating the metadata of the dm-thin device-mapper
target
local/thunar 1.8.12-1 (xfce4)
Modern file manager for Xfce
local/thunar-archive-plugin 0.4.0-2 (xfce4-goodies)
Create and extract archives in Thunar
local/thunar-media-tags-plugin 0.3.0-1 (xfce4-goodies)
Adds special features for media files to the Thunar File Manager
local/thunar-volman 0.9.5-2 (xfce4)
Automatic management of removeable devices in Thunar
local/thunderbird 68.4.2-1
Standalone mail and news reader from mozilla.org
local/thunderbird-i18n-de 68.4.2-1
German language pack for Thunderbird
local/tlp 1.2.2-1
Linux Advanced Power Management
local/transmission-gtk 2.94-2
Fast, easy, and free BitTorrent client (GTK+ GUI)
local/tslib 1.21-1
Touchscreen Access Library
local/ttf-bitstream-vera 1.10-12
Bitstream Vera fonts.
local/ttf-caladea 20130214-2
Google's Caladea font
local/ttf-carlito 20130920-4
Google's Carlito font
local/ttf-croscore 20190926-4
Chrome OS core fonts
local/ttf-dejavu 2.37-2
Font family based on the Bitstream Vera Fonts with a wider range of
characters
local/ttf-liberation 2.00.5-2
Red Hats Liberation fonts
local/ttf-opensans 1.101-1
Sans-serif typeface commissioned by Google
local/ttf-ubuntu-font-family 0.83-5
Ubuntu font family
local/tumbler 0.2.8-1 (xfce4)
D-Bus service for applications to request thumbnails
local/twolame 0.4.0-2
An optimized MPEG Audio Layer 2 (MP2) encoder
local/tzdata 2019c-3
Sources for time zone and daylight saving time data
local/udisks2 2.8.4-1
Disk Management Service, version 2
local/ufw 0.36-3
Uncomplicated and easy to use CLI tool for managing a netfilter firewall
local/unrar 1:5.9.1-1
The RAR uncompression program
local/unzip 6.0-13
For extracting and viewing files in .zip archives
local/upower 0.99.11-1
Abstraction for enumerating power devices, listening to device events and
querying history and statistics
local/usb_modeswitch 2.6.0-1
Activating switchable USB devices on Linux.
local/usbmuxd 1.1.0+66+g9af2b12-1
local/usbutils 012-2
USB Device Utilities
local/util-linux 2.35.1-1
Miscellaneous system utilities for Linux
local/v4l-utils 1.18.0-1
Userspace tools and conversion library for Video 4 Linux
local/vi 1:070224-4
The original ex/vi text editor
local/vid.stab 1.1-2
Video stabilization library
local/volume_key 0.3.12-2
A library for manipulating storage volume encryption keys and storing them
separately from volumes to handle forgotten passphrases
local/vpnc 1:0.5.3.r462.r78-1
VPN client for cisco3000 VPN Concentrators
local/vte-common 0.58.3-1
Common files used by vte and vte3
local/vte3 0.58.3-1
Virtual Terminal Emulator widget for use with GTK3
local/vulkan-icd-loader 1.2.132-1
Vulkan Installable Client Driver (ICD) Loader
local/wavpack 5.2.0-1
Audio compression format with lossless, lossy and hybrid compression modes
local/wayland 1.17.0-1
A computer display server protocol
local/wayland-protocols 1.18-1
Specifications of extended Wayland protocols
local/webkit2gtk 2.26.3-1
GTK+ Web content engine library
local/webrtc-audio-processing 0.3.1-1
AudioProcessing library based on Google's implementation of WebRTC
local/welcome 2.4.5-1
Welcome greeter for new EndeavourOS users.
local/wget 1.20.3-2
Network utility to retrieve files from the Web
local/which 2.21-5 (base-devel)
A utility to show the full path of commands
local/whois 5.5.5-1
Intelligent WHOIS client
local/wildmidi 0.4.3-1
Open Source MIDI Synthesizer
local/wine 5.0-1
A compatibility layer for running Windows programs
local/wireless-regdb 2019.06.03-2
Central Regulatory Domain Database
local/wireless_tools 30.pre9-3
Tools allowing to manipulate the Wireless Extensions
local/woff2 1.0.2-1
Web Open Font Format 2 reference implementation
local/wpa_supplicant 2:2.9-5
A utility providing key negotiation for WPA wireless networks
local/wpebackend-fdo 1.4.0-2
freedesktop.org backend for WPE WebKit
local/wvdial 1.61-7
A dialer program to connect to the Internet
local/wvstreams 4.6.1-16
A network programming library written in C++
local/wxgtk-common 3.0.4-2
Common libraries and headers for wxgtk2 and wxgtk3
local/wxgtk3 3.0.4-2
GTK+3 implementation of wxWidgets API for GUI
local/x264 3:0.159.r2991.1771b55-1
Open Source H264/AVC video encoder
local/x265 3.2.1-1
Open Source H265/HEVC video encoder
local/xcb-proto 1.13-4
XML-XCB protocol descriptions
local/xcb-util 0.4.0-2
Utility libraries for XC Binding
local/xcb-util-image 0.4.0-2
Utility libraries for XC Binding - Port of Xlib's XImage and XShmImage
functions
local/xcb-util-keysyms 0.4.0-2
Utility libraries for XC Binding - Standard X key constants and conversion
to/from keycodes
local/xcb-util-renderutil 0.3.9-2
Utility libraries for XC Binding - Convenience functions for the Render
extension
local/xcb-util-wm 0.4.1-2
Utility libraries for XC Binding - client and window-manager helpers for
ICCCM
local/xdg-dbus-proxy 0.1.2-1
D-Bus proxy
local/xdg-user-dirs 0.17-2
Manage user directories like ~/Desktop and ~/Music
local/xdg-user-dirs-gtk 0.10+9+g5b7efc6-2 (gnome)
Creates user dirs and asks to relocalize them
local/xdg-utils 1.1.3+18+g0547886-4
Command line tools that assist applications with a variety of desktop
integration tasks
local/xf86-input-libinput 0.29.0-1 (xorg-drivers)
Generic input driver for the X.Org server based on libinput
local/xf86-video-amdgpu 19.1.0-1 (xorg-drivers)
X.org amdgpu video driver
local/xf86-video-ati 1:19.1.0-1 (xorg-drivers)
X.org ati video driver
local/xf86-video-fbdev 0.5.0-1 (xorg-drivers)
X.org framebuffer video driver
local/xf86-video-intel 1:2.99.917+899+gf66d3954-1 (xorg-drivers)
X.org Intel i810/i830/i915/945G/G965+ video drivers
local/xf86-video-vesa 2.4.0-2 (xorg-drivers xorg)
X.org vesa video driver
local/xfce4-appfinder 4.14.0-1 (xfce4)
An application finder for Xfce
local/xfce4-battery-plugin 1.1.3-1 (xfce4-goodies)
A battery monitor plugin for the Xfce panel
local/xfce4-datetime-plugin 0.8.0-1 (xfce4-goodies)
A date and time display plugin for the Xfce panel
local/xfce4-mount-plugin 1.1.3-1 (xfce4-goodies)
Mount/umount utility for the Xfce4 panel
local/xfce4-netload-plugin 1.3.2-1 (xfce4-goodies)
A netload plugin for the Xfce panel
local/xfce4-notifyd 0.4.4-2 (xfce4-goodies)
Notification daemon for the Xfce desktop
local/xfce4-panel 4.14.3-1 (xfce4)
Panel for the Xfce desktop environment
local/xfce4-power-manager 1.6.5-2 (xfce4)
Power manager for Xfce desktop
local/xfce4-pulseaudio-plugin 0.4.2-2 (xfce4-goodies)
Pulseaudio plugin for Xfce4 panel
local/xfce4-screensaver 0.1.8-2 (xfce4-goodies)
Xfce Screensaver
local/xfce4-screenshooter 1.9.7-1 (xfce4-goodies)
Plugin that makes screenshots for the Xfce panel
local/xfce4-session 4.14.1-1 (xfce4)
A session manager for Xfce
local/xfce4-settings 4.14.2-1 (xfce4)
Settings manager of the Xfce desktop
local/xfce4-taskmanager 1.2.2-1 (xfce4-goodies)
Easy to use task manager
local/xfce4-terminal 0.8.9.1-1 (xfce4)
A modern terminal emulator primarily for the Xfce desktop environment
local/xfce4-wavelan-plugin 0.6.1-1 (xfce4-goodies)
Plugin to monitor wifi connectivity for the Xfce4 panel
local/xfce4-weather-plugin 0.10.0-1 (xfce4-goodies)
A weather plugin for the Xfce4 panel
local/xfce4-whiskermenu-plugin 2.3.5-1 (xfce4-goodies)
Menu for Xfce4
local/xfce4-xkb-plugin 0.8.1-2 (xfce4-goodies)
Plugin to switch keyboard layouts for the Xfce4 panel
local/xfconf 4.14.1-1 (xfce4)
Flexible, easy-to-use configuration management system
local/xfdesktop 4.14.2-1 (xfce4)
A desktop manager for Xfce
local/xfsprogs 5.4.0-1
XFS filesystem utilities
local/xfwm4 4.14.0-1 (xfce4)
Xfce's window manager
local/xfwm4-themes 4.10.0-3 (xfce4)
A set of additional themes for the Xfce window manager
local/xkeyboard-config 2.28-1
X keyboard configuration files
local/xl2tpd 1.3.15-1
an open source implementation of the L2TP maintained by Xelerance
Corporation
local/xmlsec 1.2.29-1
XML Security Library is a C library based on LibXML2
local/xorg-bdftopcf 1.1-1 (xorg xorg-apps)
Convert X font from Bitmap Distribution Format to Portable Compiled Format
local/xorg-font-util 1.3.2-1 (xorg-fonts xorg)
X.Org font utilities
local/xorg-font-utils 7.6-5
Transitional package depending on xorg font utilities
local/xorg-fonts-encodings 1.0.5-1 (xorg-fonts xorg)
X.org font encoding files
local/xorg-iceauth 1.0.8-1 (xorg-apps xorg)
ICE authority file utility
local/xorg-mkfontscale 1.2.1-2 (xorg-apps xorg)
Create an index of scalable font files for X
local/xorg-server 1.20.7-1 (xorg)
Xorg X server
local/xorg-server-common 1.20.7-1 (xorg)
Xorg server common files
local/xorg-setxkbmap 1.3.2-1 (xorg-apps xorg)
Set the keyboard using the X Keyboard Extension
local/xorg-xauth 1.1-1 (xorg-apps xorg)
X.Org authorization settings program
local/xorg-xdpyinfo 1.3.2-3 (xorg-apps xorg)
Display information utility for X
local/xorg-xinit 1.4.1-1
X.Org initialisation program
local/xorg-xinput 1.6.3-1 (xorg-apps xorg)
Small commandline tool to configure devices
local/xorg-xkbcomp 1.4.2+7+g29fda8e-1 (xorg-apps xorg)
X Keyboard description compiler
local/xorg-xkill 1.0.5-1 (xorg-apps xorg)
Kill a client by its X resource
local/xorg-xmodmap 1.0.10-1 (xorg-apps xorg)
Utility for modifying keymaps and button mappings
local/xorg-xprop 1.2.4-1 (xorg-apps xorg)
Property displayer for X
local/xorg-xrandr 1.5.1-1 (xorg-apps xorg)
Primitive command line interface to RandR extension
local/xorg-xrdb 1.2.0-1 (xorg-apps xorg)
X server resource database utility
local/xorg-xset 1.2.4-1 (xorg-apps xorg)
User preference utility for X
local/xorgproto 2019.2-2
combined X.Org X11 Protocol headers
local/xplc 0.3.13-8
Cross-Platform Lightweight Components
local/xvidcore 1.3.7-1
XviD is an open source MPEG-4 video codec
local/xz 5.2.4-2
Library and command line tools for XZ and LZMA compressed files
local/yad 5.0-1
A fork of zenity - display graphical dialogs from shell scripts or command
line
local/yay 9.4.4-1
Yet another yogurt. Pacman wrapper and AUR helper written in go.
local/zbar 0.23-2
Application and library for reading bar codes from various sources
local/zeromq 4.3.2-1
Fast messaging system built on sockets. C and C++ bindings. aka 0MQ, ZMQ.
local/zip 3.0-8
Compressor/archiver for creating and modifying zipfiles
local/zita-alsa-pcmi 0.3.2-2
The successor of clalsadrv, provides easy access to ALSA PCM devices.
local/zita-resampler 1.6.2-2
A C++ library for resampling audio signals
local/zlib 1:1.2.11-4
Compression library implementing the deflate compression method found in
gzip and PKZIP
local/zstd 1.4.4-1
Zstandard - Fast real-time compression algorithm
local/zvbi 0.2.35-3
VBI capture and decoding library
where is the epicgame launcher ? if you do middel of nowhere wine epicxxx , it probably cannot find it
i think ? system32 is the system windows folder dont think it should be there… if you do in ctrl+h in your thunar filemanager etc… search for .wine i think ~/.wine/ if you have installed…
I renamed the file to EpicGamesLauncher. And put a copy of it into my /Downloads folder. I already tried to open it through wine /home/sandro/Downloads/EpicGamesLauncher But the file couldn’t be found by Wine.
I installed wine correct, i can use winecfg to alter the settings.
oh it was not installed ? it is a installer ? in a filemanager check with right click what it wil start you can also start that way. and for each ‘exe’ file you can create with winecfg an custom config with needed dll’s etc… sofar im not into wine actually epic basicly not so linux friendly i think…
@ricklinux I have to admit, that i didn’t have to update the multilib repo. When i wanted to change it, i saw that it already were enabled. So i don’t have to update it, right?
@ringo It is installed. But i can’t open it, it is a library compared to Steam or Origin. After open this program i can download and install the game finally. But it seems that i wouldn’t come this far.
