Wifi not working in Dual Booting
Hello, I recently installed EndeavorOS on my laptop, dual-booting with both OSs on the same drive. Everything has been working perfectly normal for the past week until today when I booted into Windows, my laptop cannot connect to the internet. After realizing the simple fixes did not work, I decided to boot into EndeavorOS and found the wifi to work perfectly normal which stumped me. I’ve tried the following so far but not in order:
  • Uninstall and reinstall drivers
  • Manually change time rather than set to automatic
  • Disabled both fast boot and fast startup
  • Flushed DNS
  • Sfc Scan
  • Network reset
  • Delete wifi profile
  • Power flush
I’m quite stuck. Does anyone have an idea on what I can do to fix this? Also I may be late to some replies so I ask for some patience, I appreciate all help.
Welcome @RAPLAMA
Does your motherboard have WiFi onboard? Is this a desktop? Post the url for your hardware.
inxi -Faz | eos-sendlog
Edit: If this is a desktop with onboard WiFi and dual boot then the best thing to do is shutdown and unplug the desktop. Then hold the power button down for more than 30 seconds to drain power. Then plug the desktop back in and power it on. You may also have to turn off power management on your WiFi hardware.
Edit: If booting with Windows make sure that the fast startup feature in Windows power management is turned off.
The fast startup feature in windows power management has already been turned off as well as fast boot in BIOS. I am currently on a laptop, NOT a desktop. I’ve tried draining the power, waited around 5 minutes to be sure that it’s drained only for it to still not work. Also, just to clarify, yes, I am using dual boot.
For the motherboard, im currently using the ASUS TUF GAMING A16 FA617NS, and I believe it does have WiFi on board. Any other ideas? I really appreciate the help again.
Lets see what the WiFi chip is?
Edit: Could you post the output? @RAPLAMA
inxi -Na
TUFs have WiFi on board; I have had one and my wife currently has one.
Have you tried reinstalling driver or enabling/disabling the WiFi card?
It may be one of those Mediatek WiFi 6 or 7 chips that can be problematic?
Edit: Looks like it’s this hardware but is it Intel or Mediatek or some other?
Wi-Fi 6(802.11ax) (Dual band) 2*2 + Bluetooth® 5.3 Wireless Card
I don’t recall that right now… I think it’s Mediatek. My wife’s laptop has AMD processor, but if I don’t remember wrong, there are also Intel ones out there… :thinking:
Hi I didn’t think I’d get so much help so quickly! I’ll post the output as soon as I can and get to it when possible, im just currently at work. I really appreciate the patience and help overall!
My laptop is an AMD processor, not the Intel model.
Well, the only solution that comes to my mind is trying to uninstalling and reinstalling driver on Windows (if I understood issue being on Windows, not EOS) and enabling/disabling device from Device Manager.
I had something similar happening long while back during reinstall of Windows. I think it was sound card, but it decided not to work, and I had to do it like this.
I’ll try that. If nothing works, would a complete renewal of EndeavorOS help? I don’t have anything important on the OS since I’m still brand new to it so I don’t mind losing the very little data I have on that partition.
Looks like disabling and renabling as well as uninstall and reinstalling the wifi cards and adapters hasn’t fixed this issue. I really don’t know what’s causing this, but I honestly have a feeling it might be because both my windowsOS and EOS are on the same SSD. I don’t know how likely that is, but nothing seems to be working so that could just be the case. By any chance would you guys still have an idea as what to do?
Does it work in Windows? Also could you post inxi -Na from endeavouros?
Edit: Hard to help until we know what the WiFi chip actually is.
Sorry, forgot to post the wifi chip. What I get after inputting that is this:
Edit: sorry, it doesn’t show what you’re exactly replying to, what do you mean by “does it work in windows”? It’s vague since again, it doesn’t show what exactly you’re replying to
Try installing this package and reboot.
yay -S rtw89-dkms-git
I was just asking if WiFi works on Windows?
My issue is that wifi does not work on windows at all. However, on EOS, it works perfectly. Sorry I should’ve clarified earlier.
Edit: I installed the package and rebooted. Windows still can’t connect to wifi.
Oh well then never mind installing that package right now!
Edit: I thought you meant it wasn’t working on endeavouros.
yeah exactly, I understand this isn’t necessarily an EOS problem so I apologize if I’m not asking the right people for help, but I wasn’t sure where else to go, especially since this only occured after installing EndeavorOS. By any chance would you still know the cause of the issue?
On Windows did you go into device manager and remove the WiFi and then reboot and let it find it again? Do you know exactly what i mean?
