Hi, after my system updated I find my wifi adapter is no longer working.
I’m using alfa usb wifi adapter, the driver is rtl8812au.
I have not had this problem before.
Any help would be much appreciated
It’s likely due to the update to kernel 5.18; there are several threads about this. Until the driver gains support for 5.18 switch to the LTS kernel.
Thank you problem solved.
Glad you got your issue resolved!
Please check the “solution” box under @jonathon's
post which pointed you to the solution.
Thanks!
As a lesson, you could detail what the solution was.
hi zoli62, good point.
sudo pacman -S linux-lts
Then you can choose to run the long term stable kernel from the startup screen.
Hope that is a good explanation.
