I am a new Linux user.
I used ethernet to install endeavour os. (flash drive live boot method)
Currently using Gnome Desktop Enviornment.
Am using a USB wifi connector.
Wifi connections are visible but when i try to connect,
the loading animation happens but “Disconnected” message pops up everytime.
journalctl -f
mainly says
un 14 13:44:58 Peter NetworkManager[401]: [1655194498.2213] device (wlan0): state change: config → failed (reason ‘ssid-not-found’, sys-iface-state: ‘managed’)
Jun 14 13:44:58 Peter NetworkManager[401]: [1655194498.2292] device (wlan0): set-hw-addr: set MAC address to 3A:B7:3D:88:21:66 (scanning)
Jun 14 13:44:58 Peter NetworkManager[401]: [1655194498.2347] device (wlan0): Activation: failed for connection ‘JOY’
Jun 14 13:44:58 Peter NetworkManager[401]: [1655194498.2349] device (wlan0): supplicant interface state: scanning → interface_disabled
Jun 14 13:44:58 Peter NetworkManager[401]: [1655194498.2350] device (wlan0): state change: failed → disconnected (reason ‘none’, sys-iface-state: ‘managed’)
Jun 14 13:44:58 Peter iwd[402]: Could not register frame watch type 00d0: -114
Jun 14 13:44:58 Peter NetworkManager[401]: [1655194498.2358] device (wlan0): supplicant interface state: interface_disabled → inactive
[peter@Peter ~]$ systemctl status wpa_supplicant
● wpa_supplicant.service - WPA supplicant
Loaded: loaded (/usr/lib/systemd/system/wpa_supplicant.service; disabled; vendor preset: disabled)
Active: active (running) since Tue 2022-06-14 12:29:31 IST; 1h 26min ago
Main PID: 528 (wpa_supplicant)
Tasks: 1 (limit: 4610)
Memory: 5.0M
CPU: 1.165s
CGroup: /system.slice/wpa_supplicant.service
└─528 /usr/bin/wpa_supplicant -u
Jun 14 13:51:04 Peter wpa_supplicant[528]: wlan0: SME: Trying to authenticate with 28:3b:82:be:0f:f8 (SSID=‘JOY’ freq>
Jun 14 13:51:04 Peter wpa_supplicant[528]: BSSID 28:3b:82:be:0f:f8 ignore list count incremented to 2, ignoring for 1>
Jun 14 13:51:04 Peter wpa_supplicant[528]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid=“JOY” auth_failures=2 durat>
Jun 14 13:51:15 Peter wpa_supplicant[528]: wlan0: WPS-CANCEL
Jun 14 13:51:18 Peter wpa_supplicant[528]: wlan0: SME: Trying to authenticate with 28:3b:82:be:0f:f8 (SSID=‘JOY’ freq>
Jun 14 13:51:19 Peter wpa_supplicant[528]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid=“JOY” auth_failures=1 durat>
Jun 14 13:51:30 Peter wpa_supplicant[528]: wlan0: CTRL-EVENT-SSID-REENABLED id=0 ssid=“JOY”
Jun 14 13:51:30 Peter wpa_supplicant[528]: wlan0: SME: Trying to authenticate with 28:3b:82:be:0f:f8 (SSID=‘JOY’ freq>
Jun 14 13:51:30 Peter wpa_supplicant[528]: BSSID 28:3b:82:be:0f:f8 ignore list count incremented to 2, ignoring for 1>
Jun 14 13:51:30 Peter wpa_supplicant[528]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid=“JOY” auth_failures=2 durat>
[peter@Peter ~]$ systemctl iwd
Unknown command verb iwd.
[peter@Peter ~]$ systemctl status iwd
● iwd.service - Wireless service
Loaded: loaded (/usr/lib/systemd/system/iwd.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2022-06-14 12:29:30 IST; 1h 26min ago
Main PID: 402 (iwd)
Memory: 2.3M
CPU: 559ms
CGroup: /system.slice/iwd.service
└─402 /usr/lib/iwd/iwd
Jun 14 13:50:39 Peter iwd[402]: Unexpected connection related event – is another supplicant running?
Jun 14 13:50:49 Peter iwd[402]: Could not register frame watch type 00d0: -114
Jun 14 13:50:53 Peter iwd[402]: Unexpected connection related event – is another supplicant running?
Jun 14 13:51:04 Peter iwd[402]: Unexpected connection related event – is another supplicant running?
Jun 14 13:51:15 Peter iwd[402]: Could not register frame watch type 00d0: -114
Jun 14 13:51:19 Peter iwd[402]: Unexpected connection related event – is another supplicant running?
Jun 14 13:51:30 Peter iwd[402]: Unexpected connection related event – is another supplicant running?
Jun 14 13:51:41 Peter iwd[402]: Could not register frame watch type 00d0: -114
