Check again as before with journalctl -f
while connecting and see if you get some relevant info.
Also, reboot once. It can make miracles sometimes
Just for clarification: Did you install the latest driver?
Should be this one I guess:
https://aur.archlinux.org/packages/rtl8192eu
It didn’t work…
and the return from the journalctl -f
is the same as before
how do i do it
Should be
yay -S rtl8192eu
what do i do when asked diffs to show
Ignore that, just press enter (or type “N”)
ok ty.
Doesn’t seem to work. But thank you for all the help and patience…
I have to call it a day for now. Hopefully I figure out how to do it.
What type of authentication do you use?
If WEP, it is not supported by wpa_supplicant.
If you mean wifi security type
then WPA/WPA2 personal.
After enabling services, a reboot is always needed!
