Usually around 20-30% of the time, my wifi card is not found, rebooting usually fixes it but its getting annoying now
inxi -Naz output
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200 Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2725 class-ID: 0280
Are you dual booting with Windows? You need to make sure the Fast Start Up feature in Windows under power management is disabled if you are.
yep its disabled, problem still shows up
Have you tried disabling power management for the wifi card in /etc/modprobe.d/wifi.conf
add
options iwlwifi power_save=0
Did not work, also another interesting i found is that i can not restart or shut down through software, if i type reboot in the terminal, it mentions something about a sleep or shutdown operation already in progress. So i have to shutdown by pressing and holding the power button
I guess you already checked the Windows settings.
Edit: You should set up the Magic SySRq Key
The Linux kernel authors have provided a very nice feature of issuing low-level commands to the kernel directly, regardless of the state the system is in. This is called the “Magic SysRq Key”, because these commands are issued by pressing the SysRq key on the keyboard (if you can’t find it, typically, it shares the same physical key as the Print Screen key, but on some laptops it can be elsewhere).
A common use is to reboot when the computer freezes and becomes unresponsive due to some software…
Maybe try the following
sudo pacman -S linux-firmware
sudo modprobe -r iwlwifi && sudo modprobe iwlwifi
reboot
Try this: nmcli network on
Linux-firmware is upto date so it just reinstalls
Modprobe does not work because iwlwifi is in use
Need more information. Post the urls
inxi -Faz | eos-sendlog
Edit: Also
sudo dmesg | eos-sendlog
journalctl -b -0 | eos-sendlog
class-ID: 0280
The output shows that the proper module is loaded for the WiFi? Is it working?
[ 4.681063] Intel(R) Wireless WiFi driver for Linux
[ 4.681340] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
4.724077] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
[ 4.724118] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[ 4.724609] iwlwifi 0000:03:00.0: loaded firmware version 74.fe17486e.0 ty-a0-gf-a0-74.ucode op_mode iwlmvm
It’s loading the firmware.
Nothing stands out. It should be working.
By the way, i dont think i can do logs while offline, so i got these by restarting several times to get the card working again
Maybe it’s something to do with the Gnome desktop causing the issue?
mbod
June 26, 2023, 5:43am
17
gaming123:
Have you investigated why this is happening?
I am not sure if I read the journal correctly that you have provided, but it starts a shutdown sequence and a minute later it starts the gnome tracker:
Jun 25 18:40:29 gamingmachine systemd[820]: Reached target Shutdown.
Jun 25 18:41:39 gamingmachine systemd[1265]: Starting Tracker metadata extractor...
This is really weird. I would try to understand why this shutdown sequence is being started. It can well be the root cause for a deactivated wifi.
[ 0.000000] Linux version 6.3.9-zen1-1-zen
i would suggest to bail out kernel regression by booting into main kernel or LTS
Did you tried nmcli network on as I told you above? I had the same problem more than one time…
I am having the same issue. Has anyone found a solution yet?
Output of inxi -Fz:
Kernel: 6.8.9-arch1-2 arch: x86_64 bits: 64
Desktop: LXDE v: 0.10.1 Distro: EndeavourOS
Type: Portable System: Dell product: Inspiron 3542 v: N/A
serial: <superuser required>
Mobo: Dell model: 0KHNVP v: A12 serial: <superuser required> BIOS: Dell
v: A12 date: 05/13/2016
Battery:
ID-1: BAT0 charge: 22.1 Wh (94.4%) condition: 23.4/41.4 Wh (56.4%)
Info: dual core model: Intel Core i3-4005U bits: 64 type: MT MCP cache:
L2: 512 KiB
Speed (MHz): avg: 865 min/max: 800/1700 cores: 1: 798 2: 798 3: 880 4: 984
Device-1: Intel Haswell-ULT Integrated Graphics driver: i915 v: kernel
Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6 driver: X:
loaded: modesetting unloaded: vesa dri: crocus gpu: i915 resolution:
1: 1366x768~60Hz 2: N/A
API: EGL v: 1.5 drivers: crocus,swrast platforms: x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.7-arch1.3
renderer: Mesa Intel HD Graphics 4400 (HSW GT2)
Device-1: Intel Haswell-ULT HD Audio driver: snd_hda_intel
Device-2: Intel 8 Series HD Audio driver: snd_hda_intel
API: ALSA v: k6.8.9-arch1-2 status: kernel-api
Server-1: PipeWire v: 1.0.6 status: active
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
driver: ath9k
Device-2: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
IF: enp7s0 state: down mac: <filter>
Bluetooth:
Device-1: Qualcomm Atheros AR9462 Bluetooth driver: btusb type: USB
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: disabled
Local Storage: total: 465.76 GiB used: 75.9 GiB (16.3%)
ID-1: /dev/sda vendor: Toshiba model: MK5059GSXP size: 465.76 GiB
ID-1: / size: 457.38 GiB used: 75.9 GiB (16.6%) fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 51.0 C mobo: 49.0 C
Fan Speeds (rpm): cpu: 2386
Memory: total: 4 GiB available: 3.73 GiB used: 2.1 GiB (56.2%)
Processes: 162 Uptime: 9m Shell: Bash inxi: 3.3.34
