Following my travails last week trying to solve a perplexing WIFI problem ( Wifi interface no longer shows) the problem recurred yet again today. The same fix I applied last time has worked yet again (disabling the WIFI adapter and re-enabling it), and I can use WIFI now - but I wonder why this problem occurs at all in the first place?
As on the previous occasions, it occurred when the laptop woke from suspend. The problem also does not seem to affect my external RALINK wifi adapter, and does not occur when I boot from a live USB. If anyone has any suggestions at all that can help me find a permanent solution to this issue, I would appreciate it.
Thanks for the suggestion - I haven’t, largely because I thought that this was a recipe for bricking your computer but I’ll look into it now. This computer is over two years old now though and I’ve only had this problem for the past week so it didn’t occur to me that the BIOS might be the culprit.
If I remember right, you had to disable / re-enable your wifi in Bios, to make it work again, temporarily.
Your computer doesn’t have a hardware-switch (or Fn key) to toggle Wifi on / off, does it?
I will do some more reading into how to update the BIOS safely and look into doing it this week. Do you think the problem is BIOS related, even though it occurs only when the laptop wakes from suspend?
Also note: I haven’t updated the BIOS since I bought this PC in 2020.
I would like to help you with the process of updating the Bios. Normally it is not dangerous at all, if certain precautions are taken. Those are usually given in the manufacturer’s manual, or on their support-website, where you can download potential system-updates for software and Bios.
What computer are we talking about? Can you give make, model, etc.?
Also, a look into the manufacturer’s manual of your computer can save you a lot of other things to worry about… like hardware-switches for Wifi, e.g. (see above).
The F8 key is supposed to enable or disable WiFi. However, curiously I found just now that when I click FN-F8 it does quite efficiently disable WiFi but clicking it again does not re-enable it. When my WiFi adaptor stopped functioning I tried enabling it using Fn-F8 but it did nothing, hence I thought it was not the issue.
Please do so. It’s really almost a must-do. Your bricking worries are too rooted in the past. This is still a “new” machine, and new machines tend to need revised BIOS’ the most.
Also–if you’ve ever had Windows on this machine–Windows like to “capture” hardware peripherals and experience shows it sometimes takes a bit of effort to break Windows’ hold on them.
