I had to get creative, so I used the Steam system information popup.
Computer Information:
Manufacturer: ASUSTeK COMPUTER INC.
Model: FX505DT
Form Factor: Laptop
No Touch Input Detected
Processor Information:
CPU Vendor: AuthenticAMD
CPU Brand: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx
CPU Family: 0x17
CPU Model: 0x18
CPU Stepping: 0x1
CPU Type: 0x0
Speed: 2300 Mhz
8 logical processors
4 physical processors
HyperThreading: Supported
FCMOV: Supported
SSE2: Supported
SSE3: Supported
SSSE3: Supported
SSE4a: Supported
SSE41: Supported
SSE42: Supported
AES: Supported
AVX: Supported
AVX2: Supported
AVX512F: Unsupported
AVX512PF: Unsupported
AVX512ER: Unsupported
AVX512CD: Unsupported
AVX512VNNI: Unsupported
SHA: Supported
CMPXCHG16B: Supported
LAHF/SAHF: Supported
PrefetchW: Unsupported
Operating System Version:
"EndeavourOS Linux" (64 bit)
Kernel Name: Linux
Kernel Version: 6.3.8-arch1-1
X Server Vendor: The X.Org Foundation
X Server Release: 12101008
X Window Manager: KWin
Steam Runtime Version: steam-runtime_0.20230118.0
Video Card:
Driver: AMD AMD Radeon Vega 10 Graphics (raven, LLVM 15.0.7, DRM 3.52, 6.3.8-arch1-1)
Driver Version: 4.6 (Compatibility Profile) Mesa 23.1.2
OpenGL Version: 4.6
Desktop Color Depth: 24 bits per pixel
Monitor Refresh Rate: 120 Hz
VendorID: 0x1002
DeviceID: 0x15d8
Revision Not Detected
Number of Monitors: 1
Number of Logical Video Cards: 2
Primary Display Resolution: 1920 x 1080
Desktop Resolution: 1920 x 1080
Primary Display Size: 13.54" x 7.64" (15.51" diag)
34.4cm x 19.4cm (39.4cm diag)
Primary VRAM: 512 MB
Sound card:
Audio device: USB Mixer
Memory:
RAM: 7373 MB
VR Hardware:
VR Headset: None detected
Miscellaneous:
UI Language: English
LANG: en_US.UTF-8
Total Hard Disk Space Available: 478133 MB
Largest Free Hard Disk Block: 169482 MB
Storage:
Number of SSDs: 1
SSD sizes: 512G
Number of HDDs: 0
... please wait for Steam Runtime System Information report:
The dmesg reads as:
<4>[ 314.360072] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.390061] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.415019] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.420094] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.450038] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.480041] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.483295] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.510047] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.517415] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.540075] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.552774] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.565208] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.565229] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.571679] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.574947] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.600081] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.619819] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.630045] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.660074] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.690105] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.720064] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.723295] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.750069] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.780056] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.810030] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.824616] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.840108] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.870069] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.897311] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.900509] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.927008] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.930268] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.960074] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 314.990068] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.020077] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.029412] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.050073] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.080077] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.110054] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.131830] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.140072] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.170057] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.200073] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.230054] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.234236] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.260088] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.290080] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.320063] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.336616] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.350082] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.380059] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.410079] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.413340] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.439047] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.442267] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.470035] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.473242] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.541403] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.551294] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.557364] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.560612] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.590083] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.620063] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.643838] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.650075] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.680057] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.703848] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.707106] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.746233] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.749471] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.767505] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.848645] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.851868] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.860084] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.869543] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.951013] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.954268] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 315.971999] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.053466] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.056667] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.070067] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.074402] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.155822] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.159065] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.162328] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.176673] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.258219] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.261472] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.278961] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.360634] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.363863] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.370072] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.381858] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.463034] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.466267] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 316.484214] rtw_8822ce 0000:04:00.0: pci bus timeout, check dma status
<4>[ 317.938999] rtw_8822ce 0000:04:00.0: firmware failed to leave lps state
<3>[ 317.942261] rtw_8822ce 0000:04:00.0: failed to send h2c command
<3>[ 317.945376] rtw_8822ce 0000:04:00.0: failed to send h2c command
<4>[ 319.859008] rtw_8822ce 0000:04:00.0: firmware failed to leave lps state
<3>[ 319.862300] rtw_8822ce 0000:04:00.0: failed to send h2c command
<4>[ 321.779017] rtw_8822ce 0000:04:00.0: firmware failed to leave lps state
<3>[ 321.782291] rtw_8822ce 0000:04:00.0: failed to send h2c command
<4>[ 323.915698] rtw_8822ce 0000:04:00.0: firmware failed to leave lps state
<4>[ 325.835712] rtw_8822ce 0000:04:00.0: firmware failed to leave lps state
<4>[ 327.965757] rtw_8822ce 0000:04:00.0: firmware failed to leave lps state
<4>[ 329.885800] rtw_8822ce 0000:04:00.0: firmware failed to leave lps state
<4>[ 331.805748] rtw_8822ce 0000:04:00.0: firmware failed to leave lps state
<3>[ 331.809188] rtw_8822ce 0000:04:00.0: failed to send h2c command
<4>[ 333.942444] rtw_8822ce 0000:04:00.0: firmware failed to leave lps state
<4>[ 335.859108] rtw_8822ce 0000:04:00.0: firmware failed to leave lps state
<3>[ 335.862719] rtw_8822ce 0000:04:00.0: failed to send h2c command
<4>[ 337.992441] rtw_8822ce 0000:04:00.0: firmware failed to leave lps state
The error message is now: “wlan0 could not be configured.” whenever the disconnect happens
Please tell me if you need any more diagnostics.
