I’m running KDE for my DE but i"m running into a problem. The only time I have an active internet connection in the last few days is by having the Knetwork applet on the panel open. otherwise it goes to sleep even when I’m doing updates or installing an app.
[edward@Dragon ~]$ inxi -Fxxxza --no-host
Kernel: 5.16.16-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux
root=UUID=7c59bb4c-1c4e-47c2-9df7-d3d6fa74a147 rw rootflags=subvol=@
quiet loglevel=3 nowatchdog nvme_load=YES
Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1
dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP 2000 Notebook PC
v: 0888110003305910000620100 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 188B v: KBC Version 69.18
serial: <superuser required> UEFI: Insyde v: F.48 date: 12/20/2017
Battery:
ID-1: BAT0 charge: 38.8 Wh (100.0%) condition: 38.8/38.8 Wh (100.0%)
volts: 12.5 min: 10.8 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: full
Info: model: AMD E-300 APU with Radeon HD Graphics bits: 64 type: MCP
arch: Bobcat family: 0x14 (20) model-id: 2 stepping: 0 microcode: 0x5000119
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
Speed (MHz): avg: 1291 high: 1293 min/max: 780/1300 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1293 2: 1290
bogomips: 5192
Flags: ht lm nx pae sse sse2 sse3 sse4a ssse3 svm
Vulnerabilities:
Type: spec_store_bypass status: Vulnerable
Type: spectre_v1
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: AMD Wrestler [Radeon HD 6310] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu ports: active: LVDS-1
empty: HDMI-A-1,VGA-1 bus-ID: 00:01.0 chip-ID: 1002:9802 class-ID: 0300
Device-2: Suyin HP TrueVision HD Integrated Webcam type: USB
driver: uvcvideo bus-ID: 2-1:2 chip-ID: 064e:e263 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: radeon unloaded: modesetting alternate: fbdev,vesa gpu: radeon
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 mapped: LVDS model: Samsung 0x4752 built: 2012
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
OpenGL: renderer: AMD PALM (DRM 2.50.0 / 5.16.16-arch1-1 LLVM 13.0.1)
v: 3.3 Mesa 21.3.7 compat-v: 3.1 direct render: Yes
Device-1: AMD Wrestler HDMI Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:1314
class-ID: 0403
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.16.16-arch1-1 running: yes
Sound Server-2: sndio v: N/A running: no
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp3s0 state: down mac: <filter>
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: Hewlett-Packard AR9485/HB125 802.11bgn 1×1 Wi-Fi driver: ath9k
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0
chip-ID: 168c:0032 class-ID: 0280
Local Storage: total: 465.76 GiB used: 43.23 GiB (9.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-1DG142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: YAM1
scheme: GPT
ID-1: / raw-size: 465.26 GiB size: 465.26 GiB (100.00%)
used: 43.23 GiB (9.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 465.26 GiB size: 465.26 GiB (100.00%)
ID-4: /var/log raw-size: 465.26 GiB size: 465.26 GiB (100.00%)
System Temperatures: cpu: 70.0 C mobo: N/A gpu: radeon temp: 70.0 C
Fan Speeds (RPM): N/A
Processes: 181 Uptime: 53m wakeups: 1 Memory: 7.37 GiB
used: 1.23 GiB (16.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: 1256 pacman: 1253 lib: 407 flatpak: 3 Shell: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.14
here is my latest journal log
Mar 28 13:03:02 Dragon systemd[1]: Starting Network Manager...
Mar 28 13:03:03 Dragon NetworkManager[339]: <info> [1648490583.6340] NetworkManager (version 1.36.4-1) is starting... (for the first time)
Mar 28 13:03:03 Dragon NetworkManager[339]: <info> [1648490583.6362] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Mar 28 13:03:03 Dragon systemd[1]: Started Network Manager.
Mar 28 13:03:03 Dragon NetworkManager[339]: <info> [1648490583.6743] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Mar 28 13:03:03 Dragon NetworkManager[339]: <info> [1648490583.7265] manager[0x55a0cc0fb020]: monitoring kernel firmware directory '/lib/firmware'.
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.1406] hostname: hostname: using hostnamed
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.1408] hostname: static hostname changed from (none) to "Dragon"
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.1424] dns-mgr[0x55a0cc0cb250]: init: dns=default,systemd-resolved rc-manager=symlink
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.1491] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:15.1/0000:07:00.0/ieee8>
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.1514] manager[0x55a0cc0fb020]: rfkill: Wi-Fi hardware radio set enabled
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.1515] manager[0x55a0cc0fb020]: rfkill: WWAN hardware radio set enabled
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.3313] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.36.4-1/libnm-device-plugin-adsl.so)
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.4995] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.36.4-1/libnm-device-plugin-blueto>
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.6247] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.36.4-1/libnm-device-plugin-ovs.so)
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.7617] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.36.4-1/libnm-device-plugin-team.so)
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.8309] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.36.4-1/libnm-device-plugin-wifi.so)
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.8341] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.36.4-1/libnm-device-plugin-wwan.so)
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.8356] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.8381] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.8387] manager: Networking is enabled by state file
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.8716] settings: Loaded settings plugin: keyfile (internal)
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.8810] dhcp-init: Using DHCP client 'internal'
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.8811] device (lo): carrier: link connected
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.8824] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.8925] manager: (enp3s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.9087] settings: (enp3s0): created default wired connection 'Wired connection 1'
Mar 28 13:03:04 Dragon NetworkManager[339]: <info> [1648490584.9097] device (enp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'exte>
Mar 28 13:03:05 Dragon NetworkManager[339]: <info> [1648490585.2752] device (wlan0): driver supports Access Point (AP) mode
Mar 28 13:03:05 Dragon NetworkManager[339]: <info> [1648490585.2793] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Mar 28 13:03:05 Dragon NetworkManager[339]: <info> [1648490585.2817] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'exter>
Mar 28 13:03:05 Dragon NetworkManager[339]: <info> [1648490585.3176] device (wlan0): set-hw-addr: set MAC address to AA:3F:21:8F:6B:EC (scanning)
Mar 28 13:03:05 Dragon NetworkManager[339]: <info> [1648490585.3558] ovsdb: disconnected from ovsdb
Mar 28 13:03:05 Dragon NetworkManager[339]: <info> [1648490585.6343] device (wlan0): supplicant interface state: internal-starting -> disconnected
Mar 28 13:03:05 Dragon NetworkManager[339]: <info> [1648490585.6348] Wi-Fi P2P device controlled by interface wlan0 created
Mar 28 13:03:05 Dragon NetworkManager[339]: <info> [1648490585.6366] manager: (p2p-dev-wlan0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
