Watchdog didn't stop at shutdown
Blacklist the modules in /etc/modeprobe.d/blacklist.conf (create this file if you don’t have it).
On one of my computers, I had to do this.
For example, the watchdogs I had in use were 2 modules, iTCO_wdt and mei_wdt; mei-wdt is part of Intel’s Management Engine Interface. I have blacklisted both; this is what my /etc/modeprobe.d/blacklist.conf looks like:
# disable intel mei (including mei_watchdog)
blacklist mei
blacklist mei_me
blacklist mei_hdcp
blacklist mei_wdt
# Do not load the 'iTCO_wdt' watchdog module on boot.
blacklist iTCO_wdt
That’s for my modules; you’ll want to use the ones that you have instead.
(I’m not familiar with intel_pmc_bxt - you may want to try just blacklisting the 2 iTCO modules first, as I know it is safe to do so)
Found some info on it:
This driver provides support for the PMC (Power Management Controller) on Intel Broxton and Apollo Lake. The PMC is a multi-function device that exposes IPC, General Control Register and P-unit access. In addition this creates devices for iTCO watchdog and telemetry that are part of the PMC.
https://cateee.net/lkddb/web-lkddb/MFD_INTEL_PMC_BXT.html
Disabling the iTCO watchdog modules might be all you need, then.
And also this in my case: iTCO_vendor_support. Since with only blocking iTCO_wdt I had still those “error” messages.
We had the same problem :smiling_face_with_three_hearts:
I have this done and it works for me:
blacklist intel_pmc_bxt          16384  1 iTCO_wdt
blacklist iTCO_vendor_support    16384  1 iTCO_wdt
blacklist iTCO_wdt
How do I recognize that this might not be necessary with any later kernel version or in other words: is this a permanent solution for the future?
This should continue working, unless there is a major change in the kernel.
Then we’ll have to start all over again :grin:. But I wouldn’t worry about it.
One minor technicality: you didn’t disable intel-mei, but intel_pmc_bxt - it doesn’t really matter, but you might want to change this comment in your blacklist file for future clarity:
This file shouldn’t be touched by kernel updates/installations.
Ok, thanks @anon3337769 @pebcak :+1:t2:
I’ve never even thought to look into it. I always think “awesome my watch dog is on guard while I’m away from my computer”
I’ll probably leave it and not fix it because of that.
The problem is, with some people, on some systems, it hangs for 90 seconds or so at reboot or shutdown.
You can shorten the timer to a few seconds, or go deep-diving to try and figure out what is misconfigured, but since watchdogs aren’t particularly useful for personal computers, I find it more efficient to simply disable them.
The topic has been up before, and there is a solution here:
The nowatchdog boot parameter doesn’t always work, though. Sometimes you have to blacklist the modules.
It certainly is.
Old topic but one that has finally fixed the issue that has plagued me …like forever. It stalled shutdowns on both my desktop and laptop. Just a :raised_hands:, and maybe a :+1: and a couple of :kissing_heart: to all those above for the fixes. Thank you.
I run this command but it gives no output even though watchdog not stopped messages appear when I shut down system.
sorry, I didn’r read the whole thread, simply do this.
To disable watchdog timers (both software and hardware), append nowatchdog to your boot parameters.
sudo nano /etc/modprobe.d/blacklist.conf
blacklist iTCO_wdt
I don’t have Intel chip it’s AMD, does that make a difference?
This is what I see at every shutdown…
Screenshot_20210620_150949
I do not know, just try it :wink:
I was getting those as well. I remembered something I used to do to fix it but had to dig into my notebook. Try this:
Make this file:
sudo nano /etc/modprobe.d/sp5100_tco.conf
Put this in the file:
blacklist sp5100_tco
hit ctrl+o to write
enter to save
ctrl+x to exit
Then
sytemctrl reboot
I don’t see those messages anymore. As well as journal warnings.
If this fixes it for you I will come back and clean this thread up and make a new one as the original has been marked solved. Some are going to say there is a better way to do this and they are right i just can’t find it anymore. If it works it works!
