You saw this?
Yes, posted #5 before, are you talking about something specific i may have missed?
Sorry crazy morning…I am reading through it now. Of course i have to filter out the normal snarkiness of the posts lol.
That’s just part of 0,01% Arch experience we lack here at EndeavourOS
I have really hard time reading this stuff, not because of snarkiness even, but due to some weird language, maybe that’s just me
What do you have (sorry if already posted) on this line in /boot/grub/grub.cfg
linux /boot/vmlinuz-linux root=UUID=b321c71c-efa6-4225-8d97-87d75afe6250 rw quiet loglevel=3 nowatchdog
Yep, we already came through this (just quickly scan this and 6 posts below)
That works for removing message, but this is not a solution really if you think about it…
Just trying to follow that thread…what about here:
linux ${rel_dirname}/${basename} root=${linux_root_device_thisversion} rw ${args}
in /etc/grub.d/10_linux
So far looks like an old bug came back not sure…
There is also this…
"In /etc/default there is a grub.pacsave
I have restored this file grub.pacsave as the original grub (rename grub file)
The warning message has disappeared"
I don’t have a .pacsave but there is a grub.bak
/etc/grub.d/_linux
Not sure…need to check more, give me a minute
- In /etc/default there is a grub.pacsave
I’ve carefully followed all .pacnew / .pacsave cahnges, besides it happened after freeze so if that would be the case probably i’d see this on each boot after last update, but i haven’t seen this message before mentioned freeze
The last page of that thread talks about this happening from a .pacnew file. i think your freeze was coincidental and the resulting reboot brought out the message.
If that meaning 10_linux, then here’s mine:
linux ${rel_dirname}/${basename} root=${linux_root_device_thisversion} ${grub_root_fs_mode} ${args}
What’s yours?
sorry about the typo yes /etc/grub.d/10_linux
That’s interesting…In my other 2 systems i don’t have rw
as well, but you have it
That thread is hard to follow even for me a native english speaker lol some of those people are using testing branch some not…Man i miss @gohlip at times like this lol.
Just checked on an EndeavourOS and pure Arch system. Both have rw
in that line as shown by @BONK.
Well…I guess i should follow you then guys, however i really don’t understand what is going on and why things are after freeze as they are
However, i’m certain that disks and RAM are totally fine
I think you just missed a .pacnew somewhere along the line. Mostly they are harmless until something like this. It is even easier to keep up on them now that we have the handy new button on the welcome app.
Oh and your hardware is fine. From what i can gather from that thread the warning is because your system is fscking itself twice.
Adding rw
to /etc/grub.d/10_linux
and updating grub removed the message.
I really hope it haven’t removed the auto-fsck on failure features…
I’ve marked @BONK as solution, but thank you all for help, really appreciate it!
I really doubt it, since i was using hooks to report pacnew stuff & meld all along
But who knows, it’s still possible i guess…
Exactly, my system for some reason just couldn’t be satisfied with fscking itself just once
After some reading on the ArchWiki I’ve come to the conclusion that using the rw
option on the kernel line is the way to go. It’s the recommended default and should be safe to use.
mkinitcpio uses
ro
as default value when neitherrw
orro
is set by the boot loader. Boot loaders may set the value to use, for example GRUB usesrw
by default […]
Boot time checking
Mechanism
There are two players involved:
- mkinitcpio offers you the option to fsck your root file system before mounting it via the
fsck
hook. If you do this, you should mount root read-write via the appropriaterw
kernel parameter.[1]- systemd will fsck all file systems having a fsck pass number greater than 0 (either from
/etc/fstab
or a user-supplied unit file). For the root file system, it also has to be mounted read-only initially with the kernel parameterro
and only then remounted read-write from fstab (note that thedefaults
mount option impliesrw
).The first option is the recommended default, and what you will end up with if you follow the Installation guide.
Add an annoying warning in case the root device is fsck’d and about to
be mounted RO.
# ensure that root is going to be mounted rw. Otherwise, systemd
# might fsck the device again. Annoy the user so that they fix this.
if [ “${rwopt:-ro}” != ‘rw’ ]; then
echo “********************** WARNING *********************"
echo " "
echo " The root device is not configured to be mounted "
echo " read-write! It may be fsck’d again later. "
echo " *”
echo “*****************************************************”
fi
I especially like the “Annoy the user so that they fix this.” part. At least in your case this seems to work
WTF!!!
They literally just trolled the crap out of me?!
That was not straightforward at all…
