Well, i agree that it doesn’t feel right. I guess there is still something wrong due to the hard reset, unfortunately. Maybe you need to take a deeper look into your disk(s).
let it run when you have the time for it
i have no experience with that, but i don’t think so. Did you run from a recovery shell / a live environment?
Regarding the fsck you ran manually. Did you actually repair anything?
Maybe try running fsck.ext4 -p to automatically repair or try to force a check with fsck.ext4 -f to mark the device as clean.
[Edit] Oh, and you should unmount the device before checking or repairing file systems. But you probably know that.
Might still be worth running with fsck -f so it runs a check even if the FS is marked as “clean”. -c (check for bad blocks) might also be useful, though that will take a while.
It definitely actually runned this time, took at least some time (although pretty fast)
System disk was totally fine
On two of my 4 Tb storage drives (one of which was the one which i used to watch movie in VLC), i had been asked few times about:
Inode <some number> extent tree (at level 1) could be narrower. optimize <y>?
Inode <some number> extent tree (at level 2) could be narrower. optimize <y>?
I’ve said y to everything, although from what i have read - it’s not a major error / problem.
At the end both disks had message:
***** FILE SYSTEM WAS MODIFIED *****
After reboot still got the fscking message!
So i guess should try with -fc now…?
30% of system disk, so far (0/0/0 errors)
I was asking because it messes up with hard drives if you shut it down or restart pressing the actual buttons. I made a shortcut with a command that shuts it down without messing my drives in the start menu.
Meaning SATA?
Yep cap, and also if there would be a problem SMART would’ve been full of UltraDMA CRC error types, but there’s 0 (however i still need to do full long SMART check, will do after Memtest)
