Video and Audio is choppy for a short period of time
Hello. I am experiencing an issue when i am gaming / watch media. The video and audio gets choppy, and it is choppy for around 2 seconds. After that, all is fine. It dosen’t happen that often, but it can happen multiple times a day when my pc is on, and i don’t know what can be done to solve this issue. I have included a hardware information log.
Hardware Information “output of inxi -Fxxc0z | eos-sendlog”: https://0x0.st/Hisz.txt
Boot Log “output of journalctl -k -b -0 | eos-sendlog”: https://0x0.st/Hisi.txt
I think I solved this issue by updating my asus motherboard bios firmware to latest non beta version. This was in one of the bug fix list: “Fix AMD fTPM issue causes random stuttering.”. I looked it up, and it seems that this resolves the problem I was having. I will mark this post as solved, after further testing.
yes it’s the fTPM, you can just disable it, if you don’t use encrypted disks(not sure if TPM is used at all with luks)
Ok, thanks for the answer.
