Context
- It worked mostly fine (there was an issue, see issues section)
- Then I broke it by me getting muddle-headed and uninstalling a bunch of pipe-wire related packages, I’m a bit scatter-brained and I wasn’t sure if I was running pipe-wire or pulseaduio and made a bad-assumption
- I reinstalled pipe-wire and friends
- I didn’t begin experience the issues mentioned in the title until after I tried to fix what I broke
- I have pipe-wire running again, I’ve tried to remove everything pulse-audio related that needed to be removed
Issues
- Original issue that still persists: If I try to watch any video in any web-browser (FireFox, steam store page via chrome, etc) with my headphones the sound plays but the video is like a slide-show with a frame every few seconds, then it locks up, the problem goes away if i mute the sound or switch to my blue-tooth sound-bar, movies (E.G. intro cinematics) in games however worked fine, Incidentally, this specific issue went away with “PuleAudio”
- New sounds comes out all garbled and takes a few seconds to smooth out
- I can hear a pop or hitch in the sound every few seconds
- Sound quality is now bad, is tinny and can hear strange subtle (very subtle indeed) distortion (I honestly can’t describe it)
- System volume icon is missing and I can’t find the name of it’s package to re-install, found a package called volumeicon but I’m pretty sure it’s not the same (different right click properties, not the same volume mixer, etc) as the EOS volume icon
Additional Context
- I did find this issue about “Audio being choppy for a few seconds” but my system’s fTPM has been disabled since day one (and as I said I had no sound quality issues before)
- I also found this issue about “missing audio icon” but I do have sound and alsamixer works fine
Log Outputs:
- Output of inxi -Fxxc0z | eos-sendlog
- Output of journalctl -k -b -0 | eos-sendlog
- Output of pactl info | eos-sendlog
- Output of aplay -l | eos-sendlog (Is it wierd that it doesn’t show the blue-tooth sound bar? It’s definitely connected)
I think that’s everything?
