Using FIDO2 keys to unlock LUKS on EndeavourOS
Posting this as I couldn’t find a good single source of how to enable a FIDO2 hardware token to authenticate and unlock encrypted partitions on an encrypted EndeavourOS installation.
This information is applicable to Galileo Neo 2024.1 and may not work on other versions (or indeed, at all).
Please be sure you have a tested verifiably restorable backup of your system before attempting any of this, I am not responsible for your system or data.
That out of the way.
The first problem is that EndeavourOS when installed with encryption, will use LUKS1 format header. I did not know this would be a barrier at the time, but it is.
For many of these steps you need to know what your encrypted block devices are. Mine were /dev/nvme1n1p1 and also /dev/nvme1n1p3
You can find these before starting by using
lsblk
you should see information something like
nvme1n1                                       259:2    0   1.8T  0 disk
├─nvme1n1p1                                   259:3    0   250G  0 part
│ └─luks-807ec89e-ec42-4507-bda0-xxxxxxxxx 254:3    0   250G  0 crypt /
├─nvme1n1p2                                   259:4    0  64.5G  0 part  [SWAP]
├─nvme1n1p3                                   259:5    0   1.5T  0 part
│ └─luks-064a0641-f53e-4cb9-8c77-xxxxxxxxx 254:4    0   1.5T  0 crypt /home
The above would tell me that nvme1n1p1 and nvme1n1p3 are my encrypted devices, you should note yours in a similar way.
UPDATE: there is a suggestion that EndeavourOS might actually install LUKS2 as default in some circumstances. You can check by:
sudo cryptsetup luksDump /dev/nvme1n1p1
If you see:
LUKS header information
Version:        2
Then you already have a LUKS2 installation and you can skip the next section and go to STAGE 2 below.
If the Version is 1, then continue with the conversion.
So step 1 is to convert your encrypted partitions from LUKS1 header to LUKS2. This is necessary because the later steps require LUKS2 and won’t work on LUKS1 encryption.
  • STAGE 1
  • Boot from the 2024.1 USB media
Convert to luks2
  1. mount a USB flash drive or other location to hold header backups
  2. make header backups (substitute devices as from above)
sudo cryptsetup luksHeaderBackup /dev/nvme1n1p1 --header-backup-file /path/to/backups/nvme1n1p1.bin
sudo cryptsetup luksHeaderBackup /dev/nvme1n1p3 --header-backup-file /path/to/backups/nvme1n1p3.bin
And now convert to LUKS2
sudo cryptsetup convert --type luks2 /dev/nvme1n1p1
sudo cryptsetup convert --type luks2 /dev/nvme1n1p3
Answer the prompts in the appropriate manner (YES) or anything else to abort.
This does not take long (instant)
  • reboot back into your regular system
This should proceed just as before, as all we have done is converted to the LUKS2 format. EndeavourOS already supports booting from both, but will only create LUKS1 at install time.
  • STAGE 2
  • install FIDO2 support package
pacman -Sy libfido2
  • enrol each partition with the FIDO2 key
systemd-cryptenroll --fido2-device=auto --fido2-with-user-verification=true --fido2-with-client-pin=false /dev/nvme1n1p1
systemd-cryptenroll --fido2-device=auto --fido2-with-user-verification=true --fido2-with-client-pin=false /dev/nvme1n1p3
I configured mine to NOT require PIN (–fido2-with-client-pin=false), but to REQUIRE button press ( –fido2-with-user-verification=true )
You can change these options as you see fit. I might re-enroll with PIN but for now, I’m happy with the token being present, and button press only.
  • modify /etc/crypttab
Change your /etc/crypttab to append fido2-device=auto to each encrypted device you enrolled
The fourth column on each line probably has:
luks
and this is changed to
luks,fido2-device=auto
  • Set up initrd via dracut to allow the fido2 key to work
Create file /etc/dracut.conf.d/fido2.conf
install_items+=" /usr/bin/fido2-token "
add_dracutmodules+=" fido2 "
Spaces are significant there, be sure to include them. Use the calamares-luks.conf one as an example if you have it
  • rebuild the init.d using dracut
dracut -f
Make sure there are no errors, and you should also see fido2 in the list of included modules.
Reboot and hope for success
For me, the token flashes at root mount stage, I click it to authenticate, then it flashes again at home partition mount stage, click again, and boot continues.
Hope it works for you , I practised all of this in an EndeavourOS VM first, but it was still a bit sweaty palm doing it for real, even with all the backups.
Hope it’s useful to someone, I’ve been wanting to do this for a couple of years now, and finally bit the bullet.
Any errors or suggestions please do say and I’ll edit the post with corrections.
Thanks for sharing!
Just a quick note that for newer installs, this is only true for grub users. When systemd-boot is selected luks2 is the default.
I installed using systemd-boot right now, in a VM, and very recently on a physical machine, and I got LUKS1 both times.
Is there anything else that triggers it to use LUKS2?
efibootmgr -v
Boot0002* Linux Boot Manager    HD(4,GPT,**d73b7226-3d70-402d-bbb6-c7f9b26a628a**,0x800,0x2f4000)/\*EFI\SYSTEMD\SYSTEMD-BOOTX64.EFI*
and
/dev/nvme1n1p4: UUID="A7A4-95AB" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="**d73b7226-3d70-402d-bbb6-c7f9b26a628a**"
is my /efi mount for this installation
You need to use a Galileo ISO. Are you using an older one?
No, it’s this one:
2760355840 Feb 13 16:22 EndeavourOS_Galileo-Neo-2024.01.25.iso
md5sum
f80e131fa9fb5c28246e6e7d70186589 EndeavourOS_Galileo-Neo-2024.01.25.iso
Just for my own sanity and in the interests of science, I’ll install another VM from this ISO and see what kind of encrypted partitions I get.
Offline Install
One of my partitions:
And the other one:
Giving:
booting:
And we got LUKS1
Anything else I can troubleshoot (if indeed this is an actual problem here), happy to.
:thinking:
Either it was somehow broken with Neo or it doesn’t work with manual partitioning for some reason.
My laptop had 2023.03.26 installed on it, with automatic partitioning and systemd-boot
That also is LUKS1 but that was a bit of an older build.
As far as getting FIDO2 working though, the note to check the LUKS header before doing the conversion step if necessary should do the job.
Interesting. When I try this command with my luks drive I get access denied. What does this mean?
[g@g-x ~]$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sr0 11:0 1 1024M 0 rom
nvme0n1 259:0 0 953.9G 0 disk
├─nvme0n1p1 259:1 0 1000M 0 part /boot/efi
├─nvme0n1p2 259:2 0 944.1G 0 part
│ └─luks-cfd8d4b2-ce6c-4f41-97f8-4c4d5d32e1da 254:1 0 944.1G 0 crypt /
└─nvme0n1p3 259:3 0 8.8G 0 part
└─luks-36cb994f-accb-4571-8b54-a3a47c5cae05 254:0 0 8.8G 0 crypt [SWAP]
[g@g-x ~]$ sudo cryptsetup luksDump /dev/nvme1n1p1
[sudo] password for g:
Device /dev/nvme1n1p1 does not exist or access denied.
[g@g-x ~]$ sudo cryptsetup luksDump /dev/nvme1n1p3
Device /dev/nvme1n1p3 does not exist or access denied.
Your device is nvme0n1p3 . @sempterobit
So you need to substitute that in here:
sudo cryptsetup luksDump /dev/nvme0n1p3
You had my original device ( nvme1n1p3 ) in there.
I think I need to be better at writing examples. I should use more obvious substitutions instead of actual devices.
Yeah, that was before we switched to luks2 so that is normal.
Your tutorial is fine. I changed the last char to 3 in my 2nd try, but forgot to change the other char :face_with_diagonal_mouth:
Hello, unfortunately, it didn’t work for me.
I successfully converted from luks1 to luks2 and enrolled my fido2 device but when I reboot with my fido2 device plugged-in, it just ignores it and ask to enter my passphrase.
Here’s my /etc/crypttab:
luks-b8455122-3e78-4e8d-9aed-b528b43cf73d UUID=b8455122-3e78-4e8d-9aed-b528b43cf73d luks,fido2-device=auto
[eaa@eaa ~]$ ls /etc/dracut.conf.d
10-hostonly.conf  calamares-luks.conf  eos-defaults.conf  fido2.conf
[eaa@eaa ~]$ cat /etc/dracut.conf.d/fido2.conf
[eaa@eaa ~]$ cat /etc/dracut.conf.d/eos-defaults.conf
omit_dracutmodules+=" network cifs nfs nbd brltty "
compress="zstd"
[eaa@eaa ~]$ cat /etc/dracut.conf.d/calamares-luks.conf
# Configuration file automatically written by the Calamares system installer
# (This file is written once at install time and should be safe to edit.)
# Enables support for LUKS full disk encryption with single sign on from GRUB.
# force installing /etc/crypttab even if hostonly="no"
install_items+=" /etc/crypttab "
[eaa@eaa ~]$ cat /etc/dracut.conf.d/10-hostonly.conf
“hostonly=yes”
Here’s my dracut -f result :
[sudo] Mot de passe de eaa :
/etc/dracut.conf.d/10-hostonly.conf: line 1: $'\342\200\234hostonly=yes\342\200\235': command not found
dracut: Executing: /usr/bin/dracut -f
dracut: dracut module 'dash' will not be installed, because command 'dash' could not be found!
dracut: dracut module 'mksh' will not be installed, because command 'mksh' could not be found!
dracut: dracut module 'systemd-pcrphase' will not be installed, because command '/usr/lib/systemd/systemd-pcrphase' could not be found!
dracut: dracut module 'busybox' will not be installed, because command 'busybox' could not be found!
dracut: dracut module 'rngd' will not be installed, because command 'rngd' could not be found!
dracut: dracut module 'connman' will not be installed, because command 'connmand' could not be found!
dracut: dracut module 'connman' will not be installed, because command 'connmanctl' could not be found!
dracut: dracut module 'connman' will not be installed, because command 'connmand-wait-online' could not be found!
dracut: dracut module 'network-wicked' will not be installed, because command 'wicked' could not be found!
dracut: dracut module 'tpm2-tss' will not be installed, because command 'tpm2' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'lldpad' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoemon' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoeadm' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'lldpad' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsi-iname' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsiadm' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsid' could not be found!
dracut: dracut module 'nvmf' will not be installed, because command 'nvme' could not be found!
dracut: dracut module 'biosdevname' will not be installed, because command 'biosdevname' could not be found!
dracut: dracut module 'memstrack' will not be installed, because command 'memstrack' could not be found!
dracut: memstrack is not available
dracut: If you need to use rd.memdebug>=4, please install memstrack and procps-ng
dracut: *** Including module: systemd ***
dracut: *** Including module: systemd-initrd ***
dracut: *** Including module: systemd-udevd ***
dracut: *** Including module: modsign ***
dracut: *** Including module: i18n ***
dracut: *** Including module: btrfs ***
dracut: *** Including module: crypt ***
dracut: *** Including module: dm ***
dracut: Skipping udev rule: 64-device-mapper.rules
dracut: Skipping udev rule: 60-persistent-storage-dm.rules
dracut: Skipping udev rule: 55-dm.rules
dracut: *** Including module: dmraid ***
dracut: *** Including module: kernel-modules ***
dracut: *** Including module: kernel-modules-extra ***
dracut: *** Including module: lvm ***
dracut: Skipping udev rule: 56-lvm.rules
dracut: Skipping udev rule: 60-persistent-storage-lvm.rules
dracut: *** Including module: mdraid ***
dracut: Skipping udev rule: 64-md-raid.rules
dracut: *** Including module: multipath ***
dracut: Skipping udev rule: 40-multipath.rules
dracut: *** Including module: nvdimm ***
dracut: *** Including module: qemu ***
dracut: *** Including module: qemu-net ***
dracut: *** Including module: fido2 *** #################### HERE WE GO
dracut: *** Including module: lunmask ***
dracut: *** Including module: resume ***
dracut: *** Including module: rootfs-block ***
dracut: *** Including module: terminfo ***
dracut: *** Including module: udev-rules ***
dracut: Skipping udev rule: 40-redhat.rules
dracut: Skipping udev rule: 50-firmware.rules
dracut: Skipping udev rule: 50-udev.rules
dracut: Skipping udev rule: 91-permissions.rules
dracut: Skipping udev rule: 80-drivers-modprobe.rules
dracut: *** Including module: virtiofs ***
dracut: *** Including module: dracut-systemd ***
dracut: *** Including module: usrmount ***
dracut: *** Including module: base ***
dracut: *** Including module: fs-lib ***
dracut: *** Including module: shutdown ***
dracut: *** Including modules done ***
dracut: *** Installing kernel module dependencies ***
dracut: *** Installing kernel module dependencies done ***
dracut: *** Resolving executable dependencies ***
dracut: *** Resolving executable dependencies done ***
dracut: *** Hardlinking files ***
dracut: Mode:                     real
dracut: Method:                   sha256
dracut: Files:                    2148
dracut: Linked:                   9 files
dracut: Compared:                 0 xattrs
dracut: Compared:                 486 files
dracut: Saved:                    1.39 MiB
dracut: Duration:                 0.012385 seconds
dracut: *** Hardlinking files done ***
dracut: *** Generating early-microcode cpio image ***
dracut: *** Constructing GenuineIntel.bin ***
dracut: *** Store current command line parameters ***
dracut: *** Stripping files ***
dracut: *** Stripping files done ***
dracut: *** Creating image file '/efi/3a4d08d89b4a44cc89c5bc24a9dcf9f0/6.8.1-arch1-1/initrd' ***
dracut: *** Creating initramfs image file '/efi/3a4d08d89b4a44cc89c5bc24a9dcf9f0/6.8.1-arch1-1/initrd' done ***
As you can see, fido2 module is supposed to work, but nothing changed:
(On this picture, my fido2 device was plugged before the bios start up)
Have you got any idea where can be my fault?
Have a nice day :slight_smile:
Hi, trying to do same thing with tpm2 but no luck any help will appreciated? still asking passphrase.
Thanks for this!
How would I go about using a second token as a backup?
And also, how can I delete the luks password so login would only be possible if the token is present?
@skarpinis and @anon73278606 Please do not necro an old thread and start your own with your issue. You have a greater chance of receiving help.
So people are asked to first search for existing topics and solutions before just posting new ones. Then when they find one, they’re told to create a new topic to get help. If mods don’t want users replying to old topics, they should set automatic close dates. You cannot have both and, especially for new users who are unfamiliar with mod preferences.
Their posts were not even the same topic, LUKS2 using FIDO2 key. The first post was using a tpm2 module. The second was further configuration, and not set up. This thread is a how-to for using a specific encryption - decryption solution as stated in the title of the thread.
I am neither a mod, nor do I claim to be one. I was just offering some friendly advice from experience.
This is encouraged because a lot of solutions are already documented in the forum. Having 100 topics asking the same question and getting the same answer is kind of a waste of time. If a simple search can turn up a solution to a common problem, this avoids forum helpers needing to reiterate the same instructions for a fix over and over.
Better than adding a comment to an old thread would be linking to the old thread in a new topic. Sometimes bumping an old topic is fine, but often it is better to create a new topic.
Here is the guidance from the Arch forum, which I think is relevant: https://wiki.archlinux.org/title/General_guidelines#Old_threads/"necro-bumping"
Old threads/“necro-bumping”
Do your part to keep the forums tidy. As the wiki is where Arch is documented, posting in old threads (“necrobumping”) is generally discouraged in the technical issue subforums, since it can potentially create disjointed “zombie” information; outdated posts with data which is no longer relevant due to Arch’s rolling nature, combined with more recent posts reflecting more current circumstance.
Rules of thumb:
  • If you have a question, start a new thread and link to the old if relevant. You can also report the old thread so staff can close it.
  • If you have something to add and judge that your information is related, but more up-to-date, start a new thread and link to the old if desired, but avoid duplicating effort by posting information already contained in the Arch wiki.
  • If you have a version-agnostic or corresponding solution, necrobumping may be appropriate if the thread is not more than a year or two old.
Additionally, a new topic will have better visibility and can increase the chances of getting help, as @linesma mentioned.
I appreciate the points you make and the reference to Arch. Those are understandable. But also gets back to my point that it would then (in my opinion), be better for mods to put closing dates on topics. Similar to how is done when someone ticks the ‘answer’ box and the topic closes two days after final response. Nor does this address really long topics that go on for months and sometimes years, that include outdated information.
The point was that there could also be a more unified (to the EOS forum) and friendly way of doing this that’s set out in the forum guidelines or terms of use or wherever mods felt it best to include. It’s just not particularly inviting or encouraging to users new to EOS or Linux.
I know some forums that do this. It does prevent old topics from getting new comments, but comes with its own set of drawbacks as well. For example, I often see a user has to DM the moderator group to re-open a thread so they can add the solution they finally found, because the topic auto-closed after two weeks. It’s not a terrible chore, but it is a bit clunky. Probably plenty of folks would sooner not even bother posting the solution because it seems like a hassle.
Honestly, sometimes adding a new comment to an old topic is the most appropriate thing. :point_down:
Although necrobumped topics frequently earn an eye-roll or a snarky comment, in my opinion they aren’t such a terrible nuisance that we need to go to any extra bother to stop it from happening.
People who are not accustomed to the forum etiquette are bound to make a few blunders until they learn the ropes, whether it’s commenting on an old topic, posting a wall of terminal output without formatting it as a code block, opening an issue topic without including any relevant information, or whatever. The more experienced users might mention how the new person can improve the quality of their post, the new user will either take the advice or not, and through it all the world still turns.
