Elnath
July 24, 2021, 7:12am
#1
Particulary 1-on-1. I’m using Plasma.
Never used ffmpeg
but I found this reddit post which states:
Use pactl list sources short
to get IDs of your devices. Pick out the numbers for your output device.monitor and microphone. You can specify pulse devices as input in ffmpeg using -f pulse -i deviceid
Then use the amerge
filter to merge the two sources together, and output to your filetype of choice.
[juris@juris-aspiree1571 ~]$ pactl list sources short
0 alsa_input.hw_0_0 module-alsa-source.c s16le 2ch 44100Hz RUNNING
2 alsa_output.pci-0000_00_1b.0.hdmi-stereo.monitor module-alsa-card.c s16le 2ch 44100Hz RUNNING
But I don’t know what should I type in step 2.
I would appreciate some guidance.
As far as i understand
aplay -l will give you list of your devices as card 0:
, card 1:
etc
The number itself should be the device id
Elnath
July 24, 2021, 9:39am
#3
[juris@juris-aspiree1571 ~]$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC269VB Analog [ALC269VB Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Both items as card 0 .
Btw, do I need to type ffmpeg -f pulse -i deviceid
twice? One for input (microphone) other time for output (or sound from the person im talking with).
Yeah seems so, you can try just default system capture device btw:
ffmpeg -f pulse -i default "output.wav"
Although for device you can choose subdevice with dot:
-i :0.0
Oh turns out you can also do stuff like that by name from pactl list sources short
ffmpeg -f pulse -i alsa_input.hw_0_0 "output.wav"
Elnath
July 24, 2021, 9:53am
#5
Thanks for code examples.
I will try this later today.
Elnath
July 24, 2021, 2:18pm
#6
I did ffmpeg -f pulse -i default "test2.wav"
, but where does ffmpeg save output file? Searching google like 15min can’t find the answer.
Well wherever you’ve started terminal in, i assume it’s your home directory if you haven’t cd
anywhere.
btw, you can enter absolute path of where you want output file to go:
"/something/something/test2.wav"
dalto
July 24, 2021, 2:29pm
#8
It would be more efficient to search your machine for that answer than google.
sudo find / -type f -name test2.wav
Elnath
July 24, 2021, 2:38pm
#9
Yes, silly mistake - was in Home
directory. The command works, but I think quality is low, also sound seems lower than from speakers.
@keybreak @dalto I uploaded short test here: https://easyupload.io/ml17az Forgive my english, but isn’t sound too low?
Terminal full log
[juris@juris-aspiree1571 ~]$ ffmpeg -f pulse -i default "test1.wav"
ffmpeg version n4.4 Copyright (c) 2000-2021 the FFmpeg developers
built with gcc 11.1.0 (GCC)
configuration: --prefix=/usr --disable-debug --disable-static --disable-stripping --enable-amf --enable-avisynth --enable-cuda-llvm --enable-lto --enable-fontconfig --enable-gmp --enable-gnutls --enable-gpl --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libdav1d --enable-libdrm --enable-libfreetype --enable-libfribidi --enable-libgsm --enable-libiec61883 --enable-libjack --enable-libmfx --enable-libmodplug --enable-libmp3lame --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librav1e --enable-librsvg --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libv4l2 --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxcb --enable-libxml2 --enable-libxvid --enable-libzimg --enable-nvdec --enable-nvenc --enable-shared --enable-version3
libavutil 56. 70.100 / 56. 70.100
libavcodec 58.134.100 / 58.134.100
libavformat 58. 76.100 / 58. 76.100
libavdevice 58. 13.100 / 58. 13.100
libavfilter 7.110.100 / 7.110.100
libswscale 5. 9.100 / 5. 9.100
libswresample 3. 9.100 / 3. 9.100
libpostproc 55. 9.100 / 55. 9.100
Guessed Channel Layout for Input Stream #0.0 : stereo
Input #0, pulse, from 'default':
Duration: N/A, start: 1627138056.671769, bitrate: 1536 kb/s
Stream #0:0: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (pcm_s16le (native) -> pcm_s16le (native))
Press [q] to stop, [?] for help
Output #0, wav, to 'test1.wav':
Metadata:
ISFT : Lavf58.76.100
Stream #0:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 48000 Hz, stereo, s16, 1536 kb/s
Metadata:
encoder : Lavc58.134.100 pcm_s16le
size= 7580kB time=00:00:38.58 bitrate=1609.1kbits/s speed=0.989x
video:0kB audio:7580kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.001005%
