Use Audacity plugins for Tenacity?
So I’ve been getting into immersive audio remakes lately, and I’ve been using tenacity in place of audacity. I’ve been using the default, but I’m trying to find plugins and am unable to. In specific I would like to get Ambeo Orbit plugin to work, but no idea how to. Any help appreciated.
I don’t use it, but it should be exactly the same in that regards.
  1. Install program
  2. Install plugin
  3. Scan plugins directory
  4. If everything is fine - apply it to whatever you need to.
P.S. If it’s Windows VST plugin - you’ll need to use wine + vst bridge (for example LinVst) so it can be scanned in Linux native program like Tenacity
Having trouble installing linVst, all of the packages are out of date and/or orphaned. I’m going to see if there are any other vst managers.
I just compile it from source personally :upside_down_face:
Yeah there is good one, not as fast…but good.
