Updated my system and now it gives me a black screen with a blinking underscore cursor
i did a system upgrade earlier and when booting into my system it gives me a black screen. my default kernel is lts-kernel. i have no idea on what the problem is so i appreciate any insight of help available.
though i noticed a few things on the terminal while upgrading:
1.==> eos-update --yay
eos-update: package updater with additional features
Updating native and AUR apps…
[sudo] password for yuujin:
:: Synchronizing package databases…
endeavouros 14.5 KiB 16.7 KiB/s 00:01 [----------------------] 100%
core 117.7 KiB 79.6 KiB/s 00:01 [----------------------] 100%
extra 7.5 MiB 1283 KiB/s 00:06 [----------------------] 100%
multilib 133.7 KiB 79.3 KiB/s 00:02 [----------------------] 100%
:: Starting full system upgrade…
:: Replace tracker3 with extra/tinysparql? [Y/n]
  1. => dkms remove --no-depmod vboxhost/7.1.0_OSE -k 6.10.10-arch1-1 ==> dkms remove --no-depmod vboxhost/7.1.0_OSE -k 6.6.51-1-lts ==> dkms remove vboxhost/7.1.0_OSE ==> depmod 6.6.51-1-lts depmod: ERROR: could not open directory /lib/modules/6.6.51-1-lts: No such file or directory depmod: FATAL: could not search modules: No such file or directory ==> WARNING: depmod 6.6.51-1-lts' exited 1==> depmod 6.10.10-arch1-1
  2. => Warning about https://endeavouros.ip-connect.info/repo/$repo/$arch:
    Update level is 2244/2250, some [endeavouros] packages may be outdated if this mirror is in use.
    Continuing.
    ==> Warning about https://fastmirror.pp.ua/endeavouros/repo/$repo/$arch:
    Connection to this mirror failed.
    Continuing.
    ==> Warning about https://mirror.jingk.ai/endeavouros/repo/$repo/$arch:
    Update level is 2240/2250, some [endeavouros] packages may be outdated if this mirror is in use.
    Continuing.
Try getting into a tty and updating your mirrors first. Then run an update.
uh how do i update mirrors through tty?
Try reflector-simple
alright, gonna try it
nope, can’t access tty. it’s still a blank screen that has an underscore flashing with my actual cursor flashing as well
i can’t describe it well without uploading a video
Does just running an update from the tty work?
sudo pacman -Syu
https://bunkrrr.org/v/T9gzDMGEgc0Zm
here’s a vid of what im currently experiencing. hopefully it gives some insight. i cannot do anything here like a tty. but the REISUB does work so… @ricklinux
I don’t see anything other than the blinking cursor disappear. You could use the live ISO and arch-chroot into the installed system which then would allow you to update if it runs on the live ISO.
i accessed a snapshot i had and booted into a tty. here is the result
Can you just try sudo pacman -Syyu from the tty.
here you go
Does it complete? Then reboot and see if it loads the desktop or not.
https://bunkrrr.org/v/wQYY47LEcVFyB
i apologize for the noise, but as you can see in the vid…yeah. also there this one error that i did not quite catch earlier, maybe it’s something important?
It looks like it completed? Did it boot to the desktop? Should be good.
still the same problem as per the vid
Well at least it’s updated by the looks of the output. Not sure what the issue is. What is the hardware from a tty.
inxi -Fz
It looks like SDDM is not showing. Try to enter your password blindly in the black screen and hit Enter, or even switch to a different TTY (i.e. Ctrl+Alt+F3).
If you succeed on a TTY, login and check DM status:
systemctl status display-manager
